What is Voltage
  1. Jan 9, 2012 #1
    I learnt Potential but could not understand what Potential Difference is. Some define it as Work Done per unit charge. I am confused what per unit charge is. Does that mean electrons or protons ? As much as I know, electric current is the flow of negatively charged electrons to the positive electrode. But, that's natural and won't require any work to be done on it because unlike charges attract each other. Please explain this concept. Thanks.
  3. Jan 9, 2012 #2
    Hello physics kiddy,
    Listen to my analogy :
    We are neglecting the resistance of the wire ok .
    Potential difference is defined as the amount of work done in moving a unit *positive* or 1 coulomb of charge from one point to another in an electric circuit.
    Ok ,
    lets say on Q coulombs of charge W joules of work is done.
    So on 1 coulomb of charge W/Q of work will be done.
    But work done on 1 coulomb of charge is potential difference.
    1 Volt = 1 Joule / 1 coulomb
    per unit charge means on 1 coulomb of charge ( or unit positive charge). Per is / sign here.
    Code (Text):
    +7 units charge        - 9 units of charge
    The difference between charges is work done or the difference in potential between two points.
    V2-V1 = W/Q
    Original definitions are made on basis of positive charges but that doesn't make sense. Look here : http://amasci.com/amateur/elecdir.html and http://amasci.com/miscon/eleca.html#frkel
    Take a metal. Obviously the electrons move but not randomly. This shows that electromotive force is required for their one directional movement. Talking about electrolysis , there has to be unidirectional flow. The force of attraction of two electrodes isn't enough. There exist electromotive force between two terminals of battery.
    Why do we name it electromotive "force" ? Its unit is but Volts. 1 Volt = 1 joule / 1 coulomb.
    You say force = 1 joule * 1 metre / 1 coulomb ? That's absurd , I think.
  4. Jan 9, 2012 #3
    sophiecentaur
    You were told exactly right. When there is a PD of 1Volt and 1 Coulomb has passed, 1 Joule of energy has been transferred. Volts are a Potential Difference in exactly the same way as a height difference corresponds to a change in Gravitational Potential.
    So
    GPE = mgh (from School)
    and
    Electrical Potential Energy = QV
    "What about the FORCE?" is what people ask.
    Gravitational force on a Mass (m) is the rate at which GPE changes with distance. That is actually mg (weight). 1kg 'weighs' 1times g or 9.81N.
    The Electric Field is the rate that the Electrical PD changes with distance and, as PD is Volts, the field is in Volts per metre. So 1V over a 1m gap would exert 1N of force on 1 Coulomb.
    So it isn't the Volts that are the Force - it's the Volts per metre. If there is 1,000,000V PD between two plates, separated by 100km, there is still only 1N of force on 1 Coulomb.
    P.S. You don't normally (ever) come across any 'object' charged with 1 Coulomb.
  5. Jan 12, 2012 #4
    So, shall I conclude that Voltage is based on the convention that protons constitute the flow of electricity ?
  6. Jan 12, 2012 #5
    sophiecentaur
    How could have got that message?
    The Definition of One Volt is that One Joule of Energy is transferred when One Coulomb of Charge changes its Potential by One Volt. Just get that sorted out first. The Volt was set long before anyone had the microscopic experience of electrons and you really don't need to consider the little devils when talking about 'Charge', any more than you consider molecules when you are drinking a Pint. 'Positive' and 'Negative' were just signs that someone decided to paint on an early battery and there's no point in changing it now.
    IT JUST SO HAPPENS that, in metal wires, the charge is carried by mobile electrons and they happen to have a negative charge (as defined and established long ago). But an electron going in one direction is totally equivalent to a positive charge going in the other direction. Already, 'people' are making groups of AntiHydrogen atoms. It may be only a matter of time before someone makes a circuit of 'AntiCopper', in which the charge is carried by Positrons. Then you'll be happy?:wink:
  7. Jan 12, 2012 #6
    Just remember that two different things are measured in volts.
    Potential
    This is like saying that the height of Mt Everest is 8850m but the height difference between Mt Everest and Mt Kilimonjaro is 955m - both are measured in metres, but are different.
  8. Jan 12, 2012 #7
    sophiecentaur
    And, furthermore, knowing your height (above sea level, say) tells you nothing about how well your Hydroelectric System will work until you know the new height to which your water will flow. PD is of much more interest than just plain Potential..
    Electric Potential (without the "difference") refers to the energy transferred when a unit charge is brought from an infinite distance to the point of interest. The actual potential of a point in space refers to the total effect of all the charges in space. It's a pretty useless quantity in many respects. It is, in fact, always referred to 'somewhere' and that tends to be Earth (a large body that is handy to strap things to).
    @physics-kiddy: Despite your first words on this thread, I think you are more likely to 'understand' PD than Potential, in fact - because it is a more tangible idea.
  9. Jan 13, 2012 #8
    This definition has confused me ! How can we define volt using volt ?
  10. Jan 13, 2012 #9
    physics kiddy , there you go : you'll get your answer :
    http://en.wikipedia.org/wiki/Volt#Definition
    http://en.wikipedia.org/wiki/Voltage
    Here is my definition of voltage :
    Voltage is just defined as the difference in electric potential energies of charges at any two points in a circuit. It is a common term for electromotive force , potential difference and electric potential as well.
    @ sophiecentaur and Studiot
    It makes sense to consider the current flowing from positive terminal to negative terminal of battery because mathematics work by this fact. Moreover I don't think that current is flow of electrons in the metallic circuit. Please I know I am going against and correct me if I am wrong.
    Current is the flux which is produced due to back attraction force of electrons and positive lattice in metal. When metal atoms loose electrons then there develops a positive charge on them. This positive charge tend to attract electrons back but electrons due to their high speed are not attracted yet an electrodynamic flux is produced between electron and positive ion. That flux is current. Attraction force of this ion is more directed than force by which electron tends to attract it. As positive ion cannot move !
    Please read this , I found a very interesting page here : http://amasci.com/miscon/eleca.html#frkel
  11. Jan 13, 2012 #10
    Bobbywhy
    sankalpmittal, regarding the website page (amasci) you cited as "very interesting" I caution you about trusting everything you find on the internet. The reference you give, written by William J. Beaty, has some extremely controversial and doubtful statements about electricity.
    Please learn how to use reliable and trusted sources. One example is to use Michael Shermer's "Baloney Detector". You apply his ten items to a source and the results help you decide it the source is beleivable or not. Check it out: http://homepages.wmich.edu/~korista/baloney.html
    Also you may use "Carl Sagan's Baloney Detection Kit" at: http://www.carlsagan.com/index_ideascontent.htm
    Lastly, trust no one who claims "Newton was mistaken" or "The 2nd Law of Thermodynamics is wrong", or "most textbooks say...,but the real truth is ..."
  12. Jan 13, 2012 #11
    sophiecentaur
    As in " the metre is the distance between two points, separated by one metre"?
    Self referencing is not a definition of something.
  13. Jan 13, 2012 #12
    You are pretty close.
    Potential is defined at a point in a circuit.
    Potential difference is defined at a PAIR of points in a circuit, (as the two individual potentials subtracted).
    The height analogy is good; if I tell you Everest is 8848m high you will say "ok, what does that mean?" because a length is meaningless without a reference point. If you say "it is 8848m above sea level" then that makes sense. It's the same with voltage. If you say "the potential here in a circuit is 3.2V" then it doesn't make sense. If you say "the potential difference across this light bulb is 3.2V" then it makes sense: the voltage across it is 3.2V.
    ie. 1 coulumb of electrons will expend 3.2 J of energy when they move across the bulb.
  14. Jan 13, 2012 #13
    sophiecentaur
    And how would you actually measure that potential? With a lead to outer space? No. What you are calling Potential is the PD BETWEEN your point and another arbitrarily selected point, somewhere else on EARTH. It is still a Potential Difference. Potential and PD are not only quantities in a Circuit.
    OK, here- you are making the point that 'difference is what counts'. The only time one could argue that it doesn't is when charged particles fall out of space onto a planet with a non-zero net charge..
    But WHY???? do you insist on using the word "Electrons" here? How many electrons will actually get all the way from input to output terminal of a circuit when a Coulomb passes? Are we to have an entirely different description when we are dealing with an electro-plating circuit when positive metal ions flow to the Cathode and negative Ions could be flowing towards the Anode? The word that includes all possible scenarios is CHARGE so why not use it?.
    I thought that PF had some sort of aim to get people thinking in the most fruitful way (note, I haven't used the word "right") in order to stand a chance of improving their understanding. Why perpetuate the misconceptions that naff Science teachers bombard kids with?
    If a contributor asks for a definition of the Volt but inappropriately specifies exactly the terms in which the definition should be made then, perhaps, it is up to Him to make the compromises and to come to terms with things and not up to someone to bend the facts in order to make him happy.
    The 'consumer society' doesn't always apply and the customer isn't always right.
  15. Jan 13, 2012 #14
    I am close to the answer but every time I get confused why 1 coulomb of electrons expend energy when they move across the bulb. That's something natural and won't require work. How's that possible ?
  16. Jan 13, 2012 #15
    For a simplistic understanding of electricity, you can imagine it as water running through pipes. The voltage is the result of an imbalance in the circuit; the negative end of a cell has an excess of electrons, whilst the positive end does not have enough to be electrically stable. This is equivalent to putting pressure into a pipe that is blocked off.
    Once you remove the blockage the water will flow until it reaches equilibrium, this is equivalent to putting the cell in a closed circuit and letting it run flat. Essentially you can think of voltage as the pressure in the pipe and resistance as the pipe diameter.
    Conservation of energy means that you lose energy when you pass current through a bulb, it is sort of like having a small hole somewhere in the pipe. (Considering no electrons actually leave the circuit it would probably be more accurate to describe a water wheel or something that obstructs flow.) I hope this shed's light on why electrons lose energy as they pass through a component.
  17. Jan 13, 2012 #16
    sophiecentaur
    If you lift a mass against gravity, you put energy in. If it falls, you get energy out. With charge, if a +charge flows from + to -, you get energy out, if it flows from - to +, you have put energy in. One way is, as you say, "natural", the other needs you do 'do something'. But either way, energy is 'transferred'.
  18. Jan 13, 2012 #17
    rcgldr
    Going back to the gravitational analogy, if you lower a weight by some height and then hold it still, it's kinetic energy hasn't changed, but it's gravitational potential energy is less than it was before because of the reduced height.
  19. Jan 13, 2012 #18
    sophiecentaur
    If you lower a mass and it is stationary at the bottom then you must have taken that GPE and used it to, perhaps, heat up a brake or move a clock mechanism. The Energy has to go somewhere or come from somewhere Always. Current will flow through a wire without dissipating much energy (low resistance) and the PD will be small. Across a motor / lamp / heater the energy is transferred so the PD is high.
  20. Jan 13, 2012 #19
    rcgldr
    The analogy I was trying to convey was that the decrease in potential across motor / lamp / heater is similar to a decrease in GPE due to a decrease in height. I wasn't trying to convey the magnitude of that decrease. I should have clarified that energy can be extracted by reducing potential energy even if kinetic energy isn't changed.
  21. Jan 13, 2012 #20
    sophiecentaur
    I appreciate that but the OP seems not to get the significance of energy conservation laws.
