What limits to telescopes?
  1. Sep 29, 2010 #1
    Looking over CSI's "zoom and enhance" silliness, are there telescopes that could show a recognizable reflection off a small object, even a good mirror, at a mile or so? What range limits are there for reflection using high-powered scopes?
  3. Sep 29, 2010 #2
    Chi Meson
    There are a few limiting factors when it comes to the lenses involved, but there is an absolute limit on resolution for a single aperture.
    It's called the Rayleigh Criterion: basically, due to the diffraction of light as it passes through the opening of a camera or telescope, you cannot resolve two objects (that is, you can't tell there are two and not one single object) if the ratio of their separation over the distance to the objects is less than the ratio of the wavelength of light over the size of the opening.
    That ratio s/d (object separation over distance to the object) also equals the sine of their angular separation, so the Rayleigh criterion is usually written as
    sin theta = 1.22 x lambda/ D
    The 1.22 is a factor thrown in for circular openings.
    So a good SLR type camera, with about a 2 cm aperture with f-stop open wide, cannot possibly resolve two dots half a mile away unless they are more than 2 cm apart, and that's with a perfect lens.
  4. Sep 29, 2010 #3
    Thank you.
  5. Sep 29, 2010 #4
    Staff: Mentor
    ....also assuming the atmosphere is perfectly still and of even temperature distribution, which it isn't.
  6. Sep 30, 2010 #5
    Russ nailed it above. Air temp and haze (moisture/dust/pollution) often mess with any long range sight picture.
  7. Oct 1, 2010 #6
    The biggest limitations of telescopes is that
    1. You're looking through the atmosphere
    2. You're only being up objects that reflect light, where the large majority of mass in the universe is not visible.
Similar Threads - limits telescopes Date
A Calculating a Telescope's Limiting Magnitude Mar 12, 2016
What are the upper physical resolution limits on telescopes? Oct 7, 2015
Stargazing Telescope Resolving Power Limits Nov 11, 2012
Stargazing Limits of a telescope Apr 4, 2011
Bottom limit of telescopes Jan 7, 2010
