What Causes Antennas to Radiate?
  • Thread starter shankar
  • Tags
    Antenna
In summary, the basic principle of making an antenna radiate is by passing radio-frequency alternating currents through it, causing the electrons in the antenna to jostle and create electromagnetic fields, also known as radio waves. This phenomenon is covered by Maxwell's equations and cannot be achieved without producing some radiation. Additionally, the electrons jostling against ions in the crystal lattice of the conductor can also produce electric fields. However, this is not necessary and any ion vibration will most likely be in the infrared energy region.
shankar
what makes antenna to radiate,the basic principle...
:smile:
You pass radio-frequency alternating currents through the antenna. The electrons in the antenna get jostled back and forth. Jostling electrons create jostling electromagnetic fields. Jostling electromagnetic fields are what we call "radio waves."
- Warren
Currents induced in the antenna by the transimtter, produce a Electro magnetic field. This is all coverd by Maxwells equations. Due a web search on that key word for more information.
the alternating current produce fiels...then what about the induction principle...where electric field produce only magnetic field no radio waves?
Changing electric fields create magnetic fields. Changing magnetic fields create electric fields. You cannot jostle an electron around without producing SOME radiation.
- Warren
- Warren
To elaborate , electrons jostle against ions which are held in a fixed position in the crystal lattice of the conductor , causing the ions to vibrate and produce electric fields.
ya its true E&M are there but at what condition they the element radiates field?
What?
- Warren
Ionic motion is not needed, electron motion alone will do the trick. In fact any ion vibration will probably be in the infra red energy region.
1. How do antennas work?
Antennas work by converting electrical energy into electromagnetic waves, which can then be transmitted through the air or space. This conversion is made possible by the use of conductive materials, such as metal, that can create an oscillating electromagnetic field when an alternating electrical current is applied.
2. What factors affect the radiating efficiency of an antenna?
The radiating efficiency of an antenna can be affected by several factors, including the length and shape of the antenna, the frequency of the signal being transmitted, the material used to construct the antenna, and the presence of any nearby objects that may interfere with the radiation pattern.
3. How does the size of an antenna affect its ability to radiate?
The size of an antenna is directly related to its ability to radiate. Generally, the larger the antenna, the more efficient it is at radiating electromagnetic waves. This is because larger antennas have a longer physical length, allowing them to resonate at lower frequencies and radiate more energy.
4. Can antennas be used to receive signals as well as transmit them?
Yes, antennas can be used for both transmitting and receiving signals. In fact, many antennas are designed to be bi-directional, meaning they can both transmit and receive electromagnetic waves. This is commonly seen in devices such as radios, TVs, and cell phones.
5. How does the design of an antenna impact its performance?
The design of an antenna plays a crucial role in its performance. Factors such as the shape, length, and material of the antenna can all affect its ability to radiate efficiently. Additionally, the design of the antenna can also determine its directional properties, which can impact the direction and range of the signals it transmits and receives.
  • Other Physics Topics
  • Electrical Engineering
