Homework Help: What wrong with this problem?
  1. Sep 21, 2009 #1
    What wrong with this problem???
    A ball is traveling horizontally over a volleyball net when a player "spikes" it, driving it straight down to the ground. The ball's mass is 0.24 kg, its speed before being hit is 6.4 m/s and its speed immediately after the spike is 21 m/s. What is the magnitude of the impulse from the spike?
    J=(.24kg)(21m/s)-(.24kg)(6.4m/s)=3.5
    this is wrong, whats wrong
  3. Sep 22, 2009 #2
    Re: What wrong with this problem???
    Still need some input on this please?
  4. Sep 22, 2009 #3
    Doc Al
    Staff: Mentor
    Impulse and momentum are vectors--you must take direction into account. Subtract them as vectors, not just numbers.
  5. Sep 22, 2009 #4
    This probably sounds stupid but what do u mean by subtract them as vectors.
    I know know what vectors are but...
  6. Sep 22, 2009 #5
    Doc Al
    Staff: Mentor
    You just subtracted them as numbers--which means you treated them as if they pointed in the same direction.
    To subtract vectors, draw yourself a diagram. The two vectors are perpendicular to each other. Or you can find their components and subtract them.
    Hint: Subtracting is the inverse of adding. How would you add two perpendicular vectors?
  7. Sep 22, 2009 #6
    again this sounds dumb, but would add these as vectors give you
    (.48kg, 27.4m/s)
  8. Sep 23, 2009 #7
    Doc Al
    Staff: Mentor
    No, that doesn't quite make sense.
    I'll start you off. Lets call horizontal and vertical the x and y axes (like usual).
    The initial momentum is:
    mv = (.24 kg)*(6.4 m/s) = 1.54 kg-m/s in the + x direction
    Expressed as a vector using components, it would be:
    (1.54, 0)
    The final momentum is
    mv = (.24 kg)*(21 m/s) = 5.04 kg-m/s in the - y direction
    (0, -5.04)
    Now subtract those two momentum vectors and find the magnitude of the impulse.
  9. Sep 23, 2009 #8
    Alright got it
Loading...
