I What's the difference between graph, locus & manifold?
  • Thread starter swampwiz
fresh_42
Mentor
Insights Author
2018 Award
9,490
6,502
241217
No. Closed alone makes no sense, i.e. needs a specification by an adverb or by context. You used closed as closed under arithmetic operations, but this is trivially given by definition of a field. In Galois theory we consider algebraically closed fields, which are fields in which any polynomial ##p(x)=a_n+a_{n-1}x+\ldots + a_1x^{n-1}+x^n## can be written as ##p(x)=(x-\alpha_1)\cdot \ldots \cdot (x-\alpha_n)##.
OK, I think I understand this now. If I have an established field F and I add a new number that is a root G(1/n) as a field extension to F, because I can do any of the arithmetic operations, adding the new number G is equivalent to adding any number that would result from using that number G(1/n) as the argument for a polynomial having coefficients that are in F. This is so because the only extra numbers that are added are those that have terms that contain the original numbers in F and any power of G(1/n), or G(k/n), with k being in the range [0,n) since the power of a root repeats as per a DeMoivre root around a circle.
A locus can be more than 1 dimension. Perhaps it is that a surface manifold has a 2-dimensional locus of points for the surface and 1-dimensional locus for the edge of the surface? This sounds like the idea of the surface integral used in Maxwell's Equations.
fresh_42
Mentor
Insights Author
2018 Award
9,490
6,502
Sure. That was an illustration of the basic usage. I could as well have given you the correct definitions, but
  1. Wikipedia already has them.
  2. You don't read them anyway:
    I provided definitions of rings and fields in the other thread. If your research had been more careful, you would have seen that these terms didn't mean the same thing.
This is also half baked and needed precision. The notation ##G^{1/n}## should be avoided, it is misleading. Maybe you should first examine how we constructed the following tower:
$$\mathbb{N} \subseteq \mathbb{Z} \subseteq \mathbb{Q} \subseteq \mathbb{Q}[\sqrt[5]{7},\sqrt{2}] \subseteq \mathbb{R} \subseteq \mathbb{C} \subseteq \mathbb{H}$$
and learn at each step what it is called: from half group to division ring.
mathwonk
10,663
842
irresistible to try to answer such a vague question!
a locus is any set of points.
a graph (of a function) is a subset of a product space AxB which has at most one pair for each point of A.
the graph of a smooth function (defined on euclidean space and with values in a euclidean space) is an example of a (smooth) manifold.
In fact the previous example of a manifold is general in the sense that a (smooth sub-) manifold (of euclidean space) is everywhere locally just the graph of a smooth function.
this has no overlap whatsoever with stewart's galois theory.
Want to reply to this thread?
"What's the difference between graph, locus & manifold?" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Top Threads
