Understanding Elastic and Head-On Collisions: What's the Difference?
  • Thread starter gunblaze
  • Tags
    Difference
In summary, an elastic collision is a type of collision where the energy and momentum of the system are conserved, while a head on collision is a type of collision based on the geometry of the objects involved. An elastic collision can be head on or not, but a head on collision can be either elastic or inelastic.
gunblaze
187
Whats the difference between an elastic collision and a head on collision.
I noe that energy and momentum is conserved in an elastic collision but what about head on collision?
Can anyone pls help?
Why can't an elastic collision be a head on collision? Surely you mean inelastic collision and elastic collision.
In an elastic collision, the energy of the system is conserved, while for an inelastic collsion, energy in not conserved.
http://en.wikipedia.org/wiki/Elastic_collision" [Broken]
http://en.wikipedia.org/wiki/Inelastic_collision" [Broken]
To clarify further, you are trying to draw a comparison between two different classifications. It's like asking how an American is different from a white (Caucasian) man. Some Americans are white, and some whites are American, but while one is a racial grouping, the other is a national grouping.
To get to the point :
A collision is "head-on", if the point of contact is the point of intersection of the lines of motion of the center of masses. If one of the bodies is stationary (in some frame), or if both bodies are traveling along the same line, then the collision is head-on if the point of contact lies along this line.
Thus a collision is classified as "head-on" only based on the geometry of the bodies and their motions. A head on collision may be elastic or inelastic.
A collision is elastic if energy is conserved (as well as momentum). A collision between steel balls is far more elastic than a collision between two lumps of putty.
Thus the classification of an "elastic collision" depends only on the nature of the materials that make up the objects, and nothing else. An elastic collision may, or may not be head on.
1. What's the difference between qualitative and quantitative data?
Qualitative data is descriptive and subjective, while quantitative data is numerical and objective. Qualitative data is often used to explore and understand complex phenomena, while quantitative data is used to measure and analyze data.
2. What's the difference between a hypothesis and a theory?
A hypothesis is an educated guess or prediction made based on observations and evidence. A theory is a well-supported and widely accepted explanation for a phenomenon based on multiple lines of evidence and extensive testing.
3. What's the difference between accuracy and precision?
Accuracy refers to how close a measurement is to the true or accepted value, while precision refers to how close multiple measurements are to each other. A measurement can be precise without being accurate, but it cannot be accurate without being precise.
4. What's the difference between a control group and an experimental group?
A control group is a group in an experiment that does not receive the treatment or intervention being tested, while an experimental group is a group that does receive the treatment or intervention. The control group allows for comparison and helps determine the effectiveness of the treatment.
5. What's the difference between correlation and causation?
Correlation means that two variables are associated or related in some way, but it does not necessarily mean that one causes the other. Causation refers to a direct cause-and-effect relationship between two variables, where one variable directly influences the other.
