When do you use ≡ and = in equations?
  • Thread starter autodidude
  • Tags
    Symbol
In summary, the three bar equal sign, ≡, is used in mathematics for different purposes. In geometry, it can represent congruence between two triangles. In algebra, it can be used for definitions or identities, such as the formula for density, p ≡ m/v. It can also be used for equivalent propositions in logical statements. However, it should not be used for equations, as in F≡ma, as the two sides are not equal, but rather related by the equation of motion. Other symbols, such as := or =:, can be used for definitions, and the exclamation mark above an equal sign can represent imposed equality in physical problems.
autodidude
333
How do you know when to use ≡ or =? I've seen the the formula for density written with that = and ≡.
Also, whilst we're on the topic of symbols, what does an inequality sign with two lines beneath it mean? Is it the same as with one line (greater/less than or equal to)
Thanks
Mathematics news on Phys.org
I think you use the special three-line equality symbol:
1. If it's a definition
2. If it's an identity
When you see a three bar equal sign it means by definition it is equal to something. For instance you could say x=3 and that would be for a particular circumstance.
But when you say for instance, Ampere's law, ∫B dot ds, that is by definition(three bar equal sign) equal to current enclosed multiplied by η naught.
Likewise greater than or less than signs with two bars underneath mean it is greater or less than by definition.
I apologize I still haven't quite figured out how to use symbols properly.
Here's the code for you if you are wondering:
Code:
[itex]
\equiv \\
\geqq \\
\leqq
[/itex]
[itex]
\equiv \\
\geqq \\
\leqq
[/itex]
that symbol is read "is defined as"
it's simply used to save space in text. instead of keep writing "is defined as" in words...
get what i mean? lol
Additionally, sometimes you might see something like [itex]:=[/itex] or [itex]=:[/itex] where the thing closest to the colon is defined as the thing on the other side. For example, take the Euclidean Norm in 2 space, where [itex]x=(x_1,x_2)[/itex]:
[tex]|x| := \sqrt{x_1^2 + x_2^2}[/tex]
or
[tex] \sqrt{x_1^2 + x_2^2} =: |x|[/tex]
≡ is used for congruency, e.g., ΔABC ≡ ΔDEF
To me, it seems little different from = in this usage. I'm not sure why = isn't sufficient.
Because it isn't the same triangle, it can be rotated for example.
I have also seen [itex]\equiv[/itex] used a lot as "equivalent to".
For example, if you have two systems of equations S1 and S2 that have the same set of solutions, you can write [itex]S1 \equiv S2[/itex], but not [itex]S1=S2[/itex] because strictly speaking they are different systems.
Also I've seen it used for combining written expressions with mathematical expressions, for example:
Integral of f over an interval [a,b] [itex]\equiv \int^{b}_{a} f(x)dx [/itex]
For "is defined as" I've always used [itex]:=[/itex] or [itex]=:[/itex] as someone mentioned above.
Another notation I've seen and doesn't seem to be a global convention is puting an exclamation mark "!" right above an equal sign meaning "imposed to be equal to". Like when you have a physical problem, get two separate expressions, and because of some given conditions they must be equal to each other.
Perfect.
The neatest "is defined as" symbol I've seen (IMHO) is in elec eng journals, and comprises an equals sign with a triangle atop it. Picture = capped with a small ∆ of base slightly shorter in length than the equals sign.
I like ##\overset{def}{=}## for definitions, since it eliminates the ambiguity (and obscurity) of what the symbol means.
There's even a unicode symbol () for it.
In this case it means "is defined as". :rolleyes:
I share your sentiment about eschewing ambiguity, but I don't like the "def" idea because it's (prone to be) small indecipherable print. (Absolute certainty by the stage it reaches a second generation photocopy.)
Worse, it doesn't lend itself to being handwritten (legibly and without deliberate exaggeration). https://www.physicsforums.com/images/icons/icon9.gif
[itex]\equiv[/itex] is used when you want to mention that two things are equivalent/congruent. I think the notation is due to Gauss in Disquisitiones Arithmeticae and maybe Legendre before him. In the first page of Disquisitiones Arithmeticae Gauss says that he has adopted this symbol from Legendre but Legendre used this symbol to show both equality and congruence while Gauss uses this symbol only for congruence to distinguish it from equality.
Anyway, I don't think that this symbol is meant to be used for 'is defined as' naturally. If two propositions are logically equivalent, then they are congruent, but not equal because they are not the same propositions. For example you can define something in mathematics in one way and then prove other logically equivalent propositions in theorems after it. Since logically equivalent propositions are congruent you can use this symbol to define something as well I guess.
That is also my experience with the triple-rod, as introducing&defining a handy, short notation for some complex object that can be defined in a more langorous fashion.
So if I understand correctly...in physics, for density, you can write p ≡ m/v because the definition of density is just that but you can't write F≡ma because force isn't defined as mass times acceleration?
I'm not familiar with the usage of the symbol in geometry as I never took the subject at that level but it seems like that's where most people first encounter it
Well, I suppose you could, but I can't recall seeing that. I'd be happier with it being made more explicit, e.g.,
density ρ ≡ mass ÷ volume​
(Besides, I think v in a physics formula is more commonly velocity.)
That makes sense.
^ Thanks
Yeah, I'm sure I saw it in Serway's text but have seen it with an equal sign elsewhere
I just noticed that latex has it as \ triangleq , e.g., [itex]A \triangleq length \times width[/itex]
There is also a unicode symbol ≜
Way back in time when I was doing my 'A' levels (last centuary) I was taught it was an equivalence sign as in
(x+2)(x+1) ≡ x2 + 3x +2, ie true for all values of x
wheres as = was for an equation, true for some x but not all, as in x2 + 3x +2 = 12
x2 + 3x +2 = 12 is an example of a conditional equation, as opposed to an equation that is identically true (your first example).
FAQs about the use of the symbol ≡
1. When do you use the symbol ≡?
The symbol ≡ is typically used in mathematics and logic to indicate equivalence or congruence between two objects. It can also be used in computer programming to represent identical values or data types.
2. What does the symbol ≡ mean?
The symbol ≡ means "identical to" or "equivalent to." It is often used as an alternative to the equal sign (=) when comparing two values or objects.
3. How is the symbol ≡ different from the equal sign (=)?
The symbol ≡ is used to indicate equivalence or congruence between two objects, while the equal sign (=) is used to denote equality or sameness between two values. Additionally, the symbol ≡ is often used in specific mathematical or logical contexts, while the equal sign (=) is more commonly used in general equations.
4. Can the symbol ≡ be used in everyday language?
While the symbol ≡ is not commonly used in everyday language, it can be used in certain contexts to represent identical or equivalent things. For example, the phrase "my love for you ≡ infinity" could be interpreted as "my love for you is equivalent to infinity."
5. Are there any other uses for the symbol ≡?
In addition to its mathematical and logical uses, the symbol ≡ can also be used in chemistry to represent a triple bond between two atoms. It is also used in linguistics to denote a morpheme that is always pronounced the same way regardless of its surrounding sounds or letters.
  • General Math
  • General Math
