Why Does Osmosis Stop in Animal Cells?
In summary, the question is whether the water entering an animal cell in a slightly hypotonic solution will increase the pressure on the membrane and cause osmosis to stop before the concentrations fully equilibrate. It is also noted that for cells with a rigid cell wall, osmotic pressure is the main factor that stops the net diffusion of water into the cells. Additionally, the role of aquaporins in stopping osmosis is mentioned, as they may reach a substrate-saturation point.
liroj
I have a question about osmosis that goes a bit deeper than most basic textbooks so I cannot find the answer.Here's the problem:
Imagine an animal cell, say a red blood cell, in a slightly hypotonic solution. The water starts to flow in osmotically. The concentration of solute in the cell decreases. The cell slowly starts to swell but does not burst.
The question is: Does this water entering increases the pressure on the membrane (similar to turgor in plant cells only less, because the cell can increase in volume - comparable to elastic energy that must be overcome when blowing a baloon...) and does this cause osmosis to stop BEFORE the concentrations come to equilibrum (meaning that cytoplasm still has a bit more solute concentration than outside of cell) or do the concentrations perfectly match?
Thanx in advance.
Biology news on Phys.org
Is it not already defined? Homeostasis. The limits to osmosis isn't assumed to be the elasticity necessarily. I am not a biologist, but in my first year university we shared common courses. Osmoregulation -osmoconformers and osmoregulators. You need to look here i believe -if they still call them that. Not much help but points you in the right direction to help your self.
Forget cell's input - let's keep it as simple as possible. Imagine that instead of a real cell we have a phospholipide bilayer - liposome, impermeable to solutes. When does osmosis stop in a SLIGHTLY hypotonic solutions. Do the concentrations match equally or osmotic pressure matches pressure inside of liposome so inside is still more hypertonic than outside?
Since pressure can stop or reverse osmosis, then presumably any small increase in pressure will cause equilibrium while there is still a small difference in concentration.
The strength and elastic properties of the membrane should determine what happens for the given concentration difference.
I know nothing about the strength of cell membranes. Are blood cells really much more elastic than plant cells? Can they sustain much pressure?
Can a cell say double in size? If so, isn't it safe in solutions up to half the concentration of its intracellular fluid.
Likes liroj
From Lodish's Molecular Cell Biology textbook:
Animal cells will swell when they are placed in a https://www.ncbi.nlm.nih.gov/books/n/mcb/A7315/def-item/A7580/ solution (i.e., one in which the concentration of solutes is lower than it is in the https://www.ncbi.nlm.nih.gov/books/n/mcb/A7315/def-item/A7438/). Some cells, such as erythrocytes, will actually burst as water enters them by osmotic flow. Rupture of the https://www.ncbi.nlm.nih.gov/books/n/mcb/A7315/def-item/A7727/ by a flow of water into the cytosol is termed osmotic lysis.
https://www.ncbi.nlm.nih.gov/books/NBK21739/
If the swelling does not result in bursting, there will be some combination of dilution and osmotic pressure that balances out the initial difference in solute concentration between the inside and outside of the cell. My intuition would be that osmotic pressure is the bigger factor (since cell volume cannot increase too much without bursting), but I'm not sure whether the relative contribution of each has been quantified. Cells may also possesses some active transport mechanisms to pump ions out of the cell to help prevent osmotic lysis.
For cells with a rigid cell wall (e.g. plant cells), it is definitely the case that osmotic pressure is the main factor that stops the net diffusion of water into the cells.
Likes liroj and jim mcnamara
(Edited ot an incomplete sentence here.)
liroj said:
... When does osmosis stop in a SLIGHTLY hypotonic solutions. Do the concentrations match equally or osmotic pressure matches pressure inside of liposome so inside is still more hypertonic than outside?
If your liposome can expand without increase of internal pressure, osmosis stops when the concentrations match.
If there is any increase in pressure, surely osmosis must stop when the pressure difference equals the osmotic pressure.
Although osmotic pressures can be large, many atmospheres, if the radius is small small enough, bubbles (like cells) can support large pressure differences with modest skin tension.
Likes liroj
Thanx in advance.
If aquaporins are involved, then the osmosis stops when the acquaporins reach their substrate-saturation point, which may be different from osmotic equilibrium. If acquaprosins are not involved and it is all spontaneous diffusion, then it stops are equilibrium.
1. Why does osmosis stop in animal cells?
Osmosis stops in animal cells because of the presence of a semi-permeable membrane, which only allows certain substances to pass through. When the concentration of solutes inside and outside the cell is equal, the cell is in a state of equilibrium and osmosis no longer occurs.
2. What causes the stop of osmosis in animal cells?
The stop of osmosis in animal cells is caused by the balance of water and solutes on either side of the cell membrane. When the concentration of solutes is equal, there is no longer a gradient for water to move across the membrane, and osmosis stops.
3. Can osmosis start again in animal cells?
Yes, osmosis can start again in animal cells if the concentration of solutes changes on one side of the cell membrane, creating a gradient. This gradient will cause water to move across the membrane, and osmosis will resume.
4. How does osmosis stop affect animal cells?
The stop of osmosis can affect animal cells in different ways depending on the concentration of solutes inside and outside the cell. If there is a higher concentration of solutes outside the cell, water will move out of the cell causing it to shrink. If there is a higher concentration of solutes inside the cell, water will move into the cell, causing it to swell or even burst.
5. What other factors can affect the stop of osmosis in animal cells?
Other factors that can affect the stop of osmosis in animal cells include temperature, pressure, and the type of solutes present. Higher temperatures can increase the rate of osmosis, while increased pressure can prevent osmosis from occurring. Additionally, the size and charge of solutes can also impact osmosis in animal cells.
  • Biology and Medical
17K
  • Chemistry
26K
