Homework Help: Where am I going wrong
  1. Sep 28, 2007 #1
    I stumbled at the answer of a problem solved in Reily-Hobson-Bence.Please check if I am wrong:
    Find the parts of the z-plane for which the following series is convergent:
    ∑[(1/n!)(z^n)] where n runs from 0 to ∞
    2. Relevant equations
    3. The attempt at a solution
    Cauchy's radius: (1/R)=Lt (n->∞) [(1/n!)^(1/n)]
    Changing variables as 1/n=t,the limit becomes (1/R)=Lt(t->0) [(t!)^t]
    I am having the limit as 1 and hence,R=1...but the book says Since
    [(n!)^(1/n)] behaves like n as n → ∞ we find lim[(1/n!)^(1/n)] = 0. Hence R = ∞ and the series is convergent for all z
  3. Sep 28, 2007 #2
    Why do you think you're wrong?
  4. Sep 28, 2007 #3
    I do not really think IO am wrong...But I am not the author,you know...might be I am missing something.
    Also,in the very next problem [with (1/n!) in this problem replaced by (n!)] the author uses the same principle to say the limit is infinity...
  5. Sep 28, 2007 #4
    NateTG
    Which one is larger:
    [tex](2m^2)![/tex]
    or
    [tex]m^{2m^2}[/tex]
  6. Sep 28, 2007 #5
    HallsofIvy
    It really doesn't make a whole lot of sense to say that (t!)t goes to 1 as t goes to 0. How are you defining t! for t< 1?
  7. Sep 28, 2007 #6
    yes,i was wrong there...
  8. Sep 28, 2007 #7
    NateTG,I get your point...I think there is no other calculus method other than this observation rule...(I was refering to some limit method...)Because,the function is discrete,possibly no standard calculus will evaluate this...
    I may frame the logic like this:
    n! increases more rapidly than n
    =>(1/n!) decreases more rapidly than (1/n)
    here n is integer...for n--->∞, (1/n!)--->0 (also<1) and its rate of fall must be more than that of
    (1/n).
    Clearly, the limit--->0
  9. Sep 28, 2007 #8
  10. Sep 29, 2007 #9
    NateTG
    I would be careful with stirling's approximation. It's a nice magic bullet, but it may not help you understand things.
