Which answer is correct? Please check my work
  • Thread starter Math10
Find a second solution y2 for x^2*y"+xy'-y=0; y1=x that isn't a constant multiple of the solution y1.
None.
Here's my work:
I divided by x^2,
y"+(1/x)y'-(1/x^2)y=0
P(x)=1/x and Q(x)=-1/x^2
Let y(x)=v(x)*x
y'(x)=v'(x)*x+v(x)
(1/x)y'(x)=v'(x)+v(x)/x
y"(x)=v'(x)+v"(x)*x+v'(x)=xv"(x)+2v'(x)
xv"(x)+2v'(x)+v'(x)+v(x)/x-v(x)*x/(x^2)=0
xv"(x)+3v'(x)=0
Let w=v'
w'=v"
xw'+3w=0
w'=-3w/x
dw/dx=-3w/x
dw/w=-3/x dx
integrate
ln abs(w)=-3ln abs(x)+C
Don't count C, the constant.
w=1/x^3
w=v'=1/x^3
dv/dx=1/x^2
don't count c, the constant.
v=-1/2x^2
y=v*x
y=-1/2x^2*x=-1/2x
But the answer in the book is y2=1/x. I got y=-1/2x, which answer is right?
Answers and Replies
HallsofIvy
41,833
956
Both are correct. If "y" is a solution to a "linear homogenous differential equation", which this is, then "Ay" is also a solution for any constant, A.
SammyS
Staff Emeritus
1,011
None.
Here's my work:
I divided by x^2,
Let y(x)=v(x)*x
y'(x)=v'(x)*x+v(x)
xv"(x)+3v'(x)=0
Let w=v'
w'=v"
xw'+3w=0
w'=-3w/x
dw/dx=-3w/x
dw/w=-3/x dx
integrate
w=1/x^3
w=v'=1/x^3
dv/dx=1/x^2
v=-1/2x^2
y=v*x
y=-1/2x^2*x=-1/2x
If you include a much needed set of parentheses in your solution, y = -1/(2x) , then both are correct.
Instead of throwing out C, use C = ln(2) .
LCKurtz
Insights Author
766
What stops you from plugging the answers back in the DE and checking for yourself?
5,782
I agree. @Math10, at this point in your studies, any problem that you can check, you should check. You have already done the hard work of find the second solution. It's a simple matter to verify that what you have found actually is a solution.
But when do I use C=ln(2)? After integrating dw/w=-3/x dx? But how did you get C=ln(2)?
SammyS
Staff Emeritus
1,011
I assume that you are referring to my response somewhere above.
Notice that most of the previous respondents used the 'Reply' feature which includes a quote from the post they reference.
integrate
w=1/x^3
C is an arbitrary constant, Right?
Suppose you keep it, rather than discarding it.
You then have ##\displaystyle e^{\,\ln|w|}=e^{\,\ln(|x|^{-3})+C}\ ##.
So that ##\displaystyle w=\pm e^Cx^{-3}\ ## .
Carry that on through.
Then, ##\displaystyle v=\pm\frac{1}{2}e^Cx^{-3}+c_2 ## .
In your solution, you let c2 = 0. That's fine.
You can choose C = ln(2), so that ## e^C ## cancels the ##\displaystyle \frac{1}{2}\ ##.
This together with choosing the - sign from the ± gives the book solution.
Related Threads on Which answer is correct? Please check my work
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
