Comparing Deck Beams: 4"x10" vs. 4"x12" with Same Material and Load Conditions
  • Thread starter walt88
  • Tags
    Beam
In summary, when comparing the strength of two beams with different cross-section dimensions and lengths, it is important to consider both the moment of inertia and the section modulus. However, in this specific scenario where the beams are both simply supported at the ends, have the same material and load type, and are under the same load, beam A is stronger than beam B due to its smaller deflection and lower stress. It is also worth noting that the longer beam may experience higher stress and deflection under the same load, despite having a larger section modulus.
walt88
This is for a deck:
Which beam is stronger?
A) a beam with cross-section dimensions 4"x10" and 8' long
B) a beam with cross-section dimensions 4"x12" and 12' long
Both beams are same material and are both simply supported at the ends. Same load type (either concentrated or distributed doesn't really matter) and same load location.
Here are my thoughts:
Moment of inertia for beams: A: 333.33 in^4; B: 576 in^4
Lengths of beams: A: 96 in; B: 144 in
Using the equation for a concentrated load at the center: P = (deflection*48*E*I)/(L^3)
The deflection of beam A is about half the deflection of B. Does this mean A is stronger with the given loads?
A good way to compare is to use what is known as the section modulus (usually given the symbol Z or S)
Values of Z are often tabulated in structural tables, but can easily be computed as the ratio of the moment of intertia to the distance from the neutral axis to the edge of the beam (c).
[tex]Z = \frac{I}{c}[/tex]
In the case of a rectangular beam c=h/2 where h is the height of the beam.
If M is the maximum moment on the beam ( computed directly from the loads and geometry of the beam) and f is the allowable maximum stress in the material, a particularly simple equation then results.
[tex]Z = \frac{M}{f}[/tex]
does this help?
walt88 said:
Does this mean beam A is stronger with the given loads?
walt88: Yes, that is correct. If both beams have exactly the same material strength, beam A is 1.953 times stiffer than beam B with respect to (w.r.t.) deflection, and 1.042 times stronger than beam B w.r.t. stress.
Don't confuse member strength and stiffness with performance under load. The larger section is both stronger and stiffer, but because it is on a longer span, it may be more highly stressed and may deflect more under the same load.
It's true, with some quick calcs it looks like the stress under the same load will be 4.2% higher in the longer beam. In other words, the shorter beam is stronger under the same load.
It takes more than just the section modulus to compare beam strengths when the length changes too...
  • Mathcad - Beam Strength Comparison.pdf
Yes indeed, but this is taken care of in the comparison to the section modulus to the actual applied moment.
1. Which beam is stronger, wood or steel?
This depends on the specific properties of the wood and steel being compared. Generally, steel is stronger and has a higher tensile strength than wood, but wood can be more resistant to certain types of loads such as compression. It is important to consider the specific requirements and intended use of the beam when determining which is stronger.
2. What factors affect the strength of a beam?
The strength of a beam is influenced by several factors, including the material it is made of, its shape and dimensions, the method of support, and the type of load it will be subjected to. Other factors such as temperature, moisture, and quality of construction can also impact the strength of a beam.
3. Can a beam be too strong?
Yes, a beam can be too strong for its intended use. This can lead to unnecessary costs and resources being used, as well as potential safety hazards. It is important to carefully consider the strength requirements of a beam and not over-design it.
4. How is the strength of a beam calculated?
The strength of a beam is typically calculated using mathematical equations based on its dimensions, material properties, and load conditions. Finite element analysis and other computer-based methods may also be used to determine the strength of a beam.
5. What is the strongest type of beam?
There is no single "strongest" type of beam, as different materials and shapes have strengths and weaknesses depending on the specific requirements. For example, an I-beam may be stronger than a solid rectangular beam in certain situations, while a truss beam may be stronger in others. It is important to consider the specific needs of a project when determining the strongest type of beam to use.
  • STEM Academic Advising
10K
17K
33K
13K
  • Mechanical Engineering
