Which Expression is Larger in This Mathematical Comparison?
  • MHB
  • Thread starter anemone
In summary, $(2^{\frac{1}{3}}-1)^{\frac{1}{3}}$ and $\left( \dfrac{1}{9} \right)^{\frac{1}{3}}-\left( \dfrac{2}{9} \right)^{\frac{1}{3}}+\left( \dfrac{4}{9} \right)^{\frac{1}{3}}$ are equal.
anemone
MHB
POTW Director
3,883
115
Which is larger?
$(2^{\frac{1}{3}}-1)^{\frac{1}{3}}$ or $\left( \dfrac{1}{9} \right)^{\frac{1}{3}}-\left( \dfrac{2}{9} \right)^{\frac{1}{3}}+\left( \dfrac{4}{9} \right)^{\frac{1}{3}}$
Mathematics news on Phys.org
[sp]Let $\alpha = 2^{1/3}$. Then $$\begin{aligned}\left( \left( \tfrac{1}{9} \right)^{1/3}-\left( \tfrac{2}{9} \right)^{1/3}+\left( \tfrac{4}{9} \right)^{1/3}\right)^{\!\!3} = \tfrac19(1-\alpha+\alpha^2)^3 &= \tfrac19(1-3\alpha +6\alpha^2 -7\alpha^3 +6\alpha^4 -3\alpha^5 +\alpha^6) \\ &= \tfrac19(1-3\alpha +6\alpha^2 -14 +12\alpha -6\alpha^2 + 4) = \tfrac19(-9+9\alpha) = -1+\alpha.\end{aligned}$$ So $(2^{1/3}-1)^{1/3}$ and $ \left( \tfrac{1}{9} \right)^{1/3}-\left( \tfrac{2}{9} \right)^{1/3}+\left( \tfrac{4}{9} \right)^{1/3}$ are equal.[/sp]
Thanks for participating, Opalg! I often get the feeling that you solve all the challenging problems like a breeze and I admire your ability and capability very much!
My solution:
I first let
$y=(2^{\frac{1}{3}}-1)^{\frac{1}{3}}$
and we can now undo cube root by cubing both sides of the equation and get
$y^3=2^{\frac{1}{3}}-1$
I then let $x=\left( \dfrac{1}{9} \right)^{\frac{1}{3}}-\left( \dfrac{2}{9} \right)^{\frac{1}{3}}+\left( \dfrac{4}{9} \right)^{\frac{1}{3}}$
Notice that $\left( \dfrac{1}{9} \right)^{\frac{1}{3}}-\left( \dfrac{2}{9} \right)^{\frac{1}{3}}+\left( \dfrac{4}{9} \right)^{\frac{1}{3}}$ is a geometric series with first term and common ratio of $\left(\dfrac{1}{9} \right)^{\frac{1}{3}}$ and $-(2)^{\frac{1}{3}}$ and $x$ is the sum of the first three terms of the series, hence, by using the sum of the first $n$ terms of a geometric series, we have
$x=\dfrac{\left( \dfrac{1}{9} \right)^{\frac{1}{3}}\left( 1-(-(2^{\frac{1}{3}})^3 \right)}{1-(-(2^{\frac{1}{3}})}=\dfrac{3^{\frac{1}{3}}}{1+2^{ \frac{1}{3}}}$
$\therefore x^3=\dfrac{3}{(1+2^{ \frac{1}{3}})^3}=\dfrac{3}{3+3(2^{ \frac{1}{3}}+2^{ \frac{2}{3}})}=\dfrac{1}{1+2^{ \frac{1}{3}}+2^{ \frac{2}{3}}}$
and notice again that $1+2^{ \frac{1}{3}}+2^{ \frac{2}{3}}$ is another geometric series with first term and common ratio of $1$ and $(2)^{\frac{1}{3}}$ hence
$x^3=\dfrac{1}{1+2^{ \frac{1}{3}}+2^{ \frac{2}{3}}}$
$\;\;\;\;=\dfrac{1}{\dfrac{1((2^{ \frac{1}{3}})^3-1)}{2^{ \frac{1}{3}}-1}}$
$\;\;\;\;=\dfrac{1}{\dfrac{1}{2^{ \frac{1}{3}}-1}}$
$\;\;\;\;=2^{ \frac{1}{3}}-1$
$\;\;\;\;=y^3$
This implies $x=y$.
Therefore, we can conclude now that $(2^{\frac{1}{3}}-1)^{\frac{1}{3}}=\left( \dfrac{1}{9} \right)^{\frac{1}{3}}-\left( \dfrac{2}{9} \right)^{\frac{1}{3}}+\left( \dfrac{4}{9} \right)^{\frac{1}{3}}$
1. Which is larger: a meter or a yard?
A meter is larger than a yard. One meter is equal to 1.0936 yards.
2. Which is larger: an atom or a molecule?
A molecule is larger than an atom. A molecule is made up of two or more atoms, whereas an atom is the smallest unit of an element.
3. Which is larger: a virus or a bacteria?
A bacteria is larger than a virus. Bacteria are single-celled organisms that can be seen under a microscope, while viruses are much smaller and can only be seen using an electron microscope.
4. Which is larger: a galaxy or a solar system?
A galaxy is larger than a solar system. A solar system typically consists of one star and its orbiting planets, while a galaxy can have billions of stars and other celestial objects.
5. Which is larger: a mountain or a hill?
A mountain is larger than a hill. While there is no strict definition for the difference between a mountain and a hill, a mountain is generally taller and steeper than a hill.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
