Homework Help: Which is Less Material Given Deflection due to Force?
  1. Nov 10, 2014 #1
    You are considering two different designs for a walking cane. Both designs use hollow metal tubes, but design A has a circular cross section (outer diameter h) whereas design B has a square cross section (outer width and length h). Both canes are designed to withstand an end deflection of exactly 5mm with 2kN of force applied to one end, normal to the force, while the other end is held fixed. Show which design will require less material to meet these specifications.
    2. Relevant equations
    Deflection with a circular cross section = (4FL^3)/(3Epir^4)
    Deflection with a rectangular cross section = (4FL^3)/Eh^3B
    I = ∫∫r2dA
    Icircle = πR4/4
    Irectangle = h3/12
    d = (FL3)/(3EI)
    3. The attempt at a solution
    5000 = (4(2000)L^3)/(Eh^4)
    L^3 = (5000Eh^4)/8000
    5000 = (4(2000)L^3)/(3Epi(h/2)^4)
    ((5000)(3Epi)(1/16)h^4)/(8000) = L^3
    Therefore ((L_r)^3)(3pi/16) = ((L_c)^3), so the circular cross section will require less material.
    My solution assumes that there is a relationship between volume and surface area. Is this assumption okay? Did I use the correct formulas? Should I have done something different to take into account that the canes are hollow?
  3. Nov 15, 2014 #2
    Thanks for the post! This is an automated courtesy bump. Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
Have something to add?
Draft saved Draft deleted
