Homework Help: Which rod is harder to spin?
  1. Feb 17, 2017 #1
    Consider one rod of length L which is spun at its center perpendicular to its length; it will have a certain moment of inertia. Now, if the same rod is folded in the middle creating a certain angle and still spun at its center, what happens to its moment of inertia?
    2. Relevant equations
    Thin rod about axis through center perpendicular to length
    $$I = \frac{1}{12}ML^2$$
    Thin rod about one edge
    $$I = \frac{1}{3}ML^2$$
    3. The attempt at a solution
    For a rod that is not folded its moment of inertia will be:
    $$\frac{1}{12}ML^2$$
    For a folded one, I tried using L to be the length divided by two so:
    $$I = 2(\frac{1}{3}\frac{M}{2}(\frac{L}{2})^2) = \frac{1}{12}ML^2$$
    So the moment of inertia will be the same.
  3. Feb 17, 2017 #2
    kuruman
    You mean increase to twice of its former value according to your equation. Think about your answer again.
    On edit: Also think about TomHart's suggestion.
  4. Feb 17, 2017 #3
    What if you calculated the inertia of the one long rod. Then you cut it in half but didn't change the angle between the halves. What would you expect to happen to the moment of inertia?
  5. Feb 17, 2017 #4
    Then it should remain the same right?
  6. Feb 17, 2017 #5
    Yes, I meant decrease by the former value.
  7. Feb 17, 2017 #6
    kuruman
    Yes, because in your solution you doubled the moment of inertia of two half rods of mass M instead of doubling the moment of inertia of two half rods of mass M/2.
  8. Feb 17, 2017 #7
    Oh yeah, missed that. So theoretically, whatever angle I fold, the rod's moment of inertia will just be the same?
  9. Feb 17, 2017 #8
    kuruman
    Yes, because you have the same amount of mass at the same distance from the reference point regardless of angle.
  10. Feb 17, 2017 #9
    Oh, that's an interesting concept :smile:
  11. Feb 17, 2017 #10
    kuruman
    Here is a related concept you might also find interesting. A thin ring of mass ##m## and radius ##R## has moment of inertia ##mR^2##. If you squeeze that mass into a semicircle of the same radius, the moment of inertia of the semicircle will still be ##mR^2##. Keep squeezing into a quarter-circle down to a point and the moment of inertia will not change while you do so.
Have something to add?
Draft saved Draft deleted
