Solving the Mystery: Which Tank Fills First?
  • I
  • Thread starter fahraynk
  • Tags
    Tank
In summary, the area of the water tank does not matter in determining how the water will flow through the pipe connecting the tanks.
  • #106
If this discussion in this thread was to continue I didn't want to be part of it but a few minutes ago and out of curiosity I did a search and found this .It shows that the answer depends on flow rates. Similar results would be obtained if the flow rate in was kept constant ,for example water dripping in and the flow rate out reduced sufficiently for example by using thinner pipes.
Likes fahraynk
  • #107
I don't know how to describe it but there seems to be something wrong with how water flows out of C into J and at the same time into L ? overall I think the video confuses the real lesson of flow rate. :confused:
  • #108
I agree, it goes at a speed such that it's difficult to see it in detail.
  • #109
Flow rate should not be a factor. Obviously if you dump water in, A will fill up immediately. But the picture shows a slow drip into A and the instructions say to pay attention to the details of the drawing. The slow drip and the closed paths need to be accounted for in the answer.
  • #110
I think F will fill up first.
  • #111
The picture.
Likes FactChecker and jerromyjon
  • #112
I know the video is not a particularly good representation of the situation shown by the original question but it's the best I can find. I posted it here because it shows that the answer depends on the difference between the flow rate into the tank and the flow rate out of the tank.
The video shows that the tank fills up first when the water flows in quicker than it leaves The same applies no matter how quickly the water flows in because it's the difference in flow rates that matters. When the water level in the tank rises the rate at which water leaves increases. Equilibrium is reached if the level reaches a value such that water leaves as quickly as it enters. If that level is not reached, for example if the tank is not tall enough, the tank will fill up and then overflow.
  • #113
I think g. The water from c will go to d first, before j.
But that's just an educated guess.
Edit: scratch that, didnt notice that it was blocked.
Go k!
  • #114
BL4CKB0X97 said:
Go k!
See @Jacqueline 's attachment in post #111 and notice how high the exit of the line from J to I is.
  • #115
Got it[emoji106]
  • #116
The tanks in this video are definitely tilted which is messing up the results. In tank A all the water flows out at the rate it enters (mostly). Yet in other pipes/tanks it flows at a different rate. Is this just a bad set up with the bottom pipes not being identical in area?
  • #117
That and several other things go to demonstrate that the only way to deal with this problem is at the simplest level - with a slow water supply and everything 'ideal'. We just finished a marathon about a 747 taking off on a conveyor belt. As with this thread, it only required a single reply but both threads would just no lie down.
  • #118
Read the question with no assumptions. The FIRST tank to be filled up is A. Nowhere does it specify how full the tank needs to be.
Likes jerromyjon
  • #119
Firstly you have to assume the water is flowing into A slower than it is exiting to B otherwise the whole question is pointless as A fills first. With that F must fill first: Water will exit J-L before J-I and so K cannot fill, therefore L and F will self-level and F will fill before L.
  • #120
Hmm. That same argument applies to when you 'boil' a kettle of water. Is it boiling as soon as you switch it on? Our language is not really precise enough for this. If you asked the barman to "fill your glass", you wouldn't be happy if he handed it back to you with a splash of beer in the bottom. :wink:
Likes FactChecker
  • #121
Asking for a beer you would expect a full glass filled to the top. But your expectations will change when you order a whiskey "straight up".
  • #122
I only drink 'proper whisky, neat or with a dash of water.
I sometimes offer a guest "two or three fingers?". They don't take offence!
Likes Jamison Lahman and Pie Ban
  • #123
F is the only one which will fill up. So F will not only fill up first, but be the only one.
All other remains empty or partially filled.
ABCJLF is the path.
Vidar
fahraynk said:
I originally thought tank K because the area in tank J is much larger than the area in the pipe connecting J to I
But then I realize Bernoulli's equation does not include volume but only includes height.
H_1, H_2 = height of water tank J, height of water in pipe between tanks J and I
P, p, V = pressure, density, velocity
$$P_1+pgH_1+\frac{1}{2}pV_1^2=P_2+pgH_2+\frac{1}{2}pV_2^2$$
Pressure terms are the same, so is density. Velocity = 0, gravity cancels out ##H_1=H_2##
So even in the small pipe connecting J to I, the water level is going to be the same as the height of water in the tank J.
Is this correct?
Also note the pipe from C to D is blocked off.
Also I assume A would be trivial solution so water must exit pipe faster than the tap fills tank A
  • #124
jerromyjon said:
I say F will fill up (overflowing) first!
Same here; in fact it probably will be the only one to fill properly at all (depending on flow rate and whether someone opens the tap to cause A to overflow!)
  • #125
My thought because of levels in and out: A to B to C to J to L to F. Funny how the mind can miss the blocks to D and H. I certainly missed the block at D :)
  • #126
sorry i only read first and last page here so if its been explained aldready forgive me
my thoughts is L would fill up and be the only one to do so due to the "pressure?"
cause watter will fill the botoms as needed then "bleed out" till certian capacities are met
F is lower but bottom filling
F would get only so full before the pressure starts equaling tween L and F
(pipe gets full then needs higher pressure from L to push water into F)
meaning L needs to get fuller for the pressure to push the water up into tank F
so in my thinking L would over flow before F, meaning L is full first
and overflow means F won't get any fuller, nor will watter continue to fill any previous tanks
also i know that the answer is some formulae of hydrolics, but please explain it in laymans terms
oh... i looked at the spoiler answer on first page, now it makes sense a bit more
how F fills, but would i be correct in my thinking if L and F were same height?
(cause L being placed higher means the water level dosent need to be higher to push into F
and its that placement of L that dictates the results in this setup)
  • #129
A or F depending how fast the water is flowing from the faucet and what it means to "fill up". Assuming dripping and completely filled, F. The latter definitions give A, but do not seem to be what OP is looking for.
EDIT: I am surprised no one has brought up the fact A is directly under the faucet hence the first water from the faucet will "fill" this bucket first.
  • #130
Is this correct?
Yes.
  • #131
No need for surprise. Read the thread to find the discussion you expect.
  • #132
any waters goes to A first and 'fills it up' regardless of flow rate of A.
We have been there several times in this thread. "Filling up" was clearly(?) to do with a bucket becoming 'Full" - same as Boiling a Kettle does not happen within seconds of it being switched on.
Why can't this just lie down and die?
Likes Nidum, 256bits and jbriggs444
  • #133
It was asserted numerous times (never by OP), but never explicitly given.
Why not unwatch the thread if you want it to die?
  • #134
The point is this was not supposed to be a science question in the first place. It was designed just to test how closely the candidate observes the setup and whether he manages to evade the trickery. In fact there is a real possibility that any tank except the ones that have been shut out: D, E, G and H can fill up and in any sequence depending upon dimensions, material properties, fluid properties, flow rates. Some may never fill up.
Likes Nidum and sophiecentaur
  • #135
Think of the problem as a hydraulic open circuit pumped by pressure in tank A and all other tanks as accumulators along the line. Even if you assume all accumulators to be of similar construction and all pipes to be frictionless, you need some more details such as the lengths of the pipes and ratio of cross section area of the tank to the inflow rate to be able to comment on which accumulator gets most pressure. Then you can use some industrial software and simulate.
  • #136
Is it not possible the trickery is the assumption that "fill up" does not necessarily imply filling up all of the way?
  • #137
After just running across this and reading the whole thread, there seems to be at least three answers.
1) Newcomers don't read the whole thread
2) Different people start off with slightly different assumptions
3) Some posters seem to feel that showing themselves to be 'right' is the main point of participation
As for the third observation, I am not pointing at those that brought up and supported other possible interpretations/starting assumptions. I point more to those that refused to consider that those other interpretations/starting assumptions could be valid. At the risk of being ostracized, there seems to be a few of us scattered throughout PF that are guilty. Unfortunately, we don't always recognize when we fall into that trap.
Well, that's my two cents worth.
Tom
Likes Dadface and fresh_42
  • #138
@Tom.G That just about sums it up and we are all guilty of 1,2 and 3.
My problem is when people read the OP and failed to see it for what it is - a 'fun' / intelligence-test / common-sense type of question. It absolutely screams "Not Technical" at you and it is not a vehicle for being a smartypants and bringing in Physics to it. That's only really ok if the Full set of assumptions in a smartypants answer is made clear, from the start. This never happens, of course and we end up shouting at each other in quadrature.
  • #139
Do you seriously think this problem is meant as a grammar exercise? Well, let's go with it. Here's what I found as relevant definitions:
fill (third-person singular simple present fills, present participle filling, simple past and past participle filled)
  1. (transitive) To occupy fully, to take up all of.
  2. (transitive) To add contents to (a container, cavity or the like) so that it is full.
  3. To enter (something), making it full.
  4. (intransitive) To become full. the bucket filled with rain; the sails fill with wind
  • #140
Now that we have obviously and utterly discussed every aspect of this riddle, I will close this thread. Off-topic posts and jokes have recently become more likely than anything new to the problem. To all who are still interested in the debate, I suggest to post a new riddle of the kind (or a similar one), as I'm almost certain there can be found many on the internet (and even in our archive).
Thread closed.
Likes Tom.G, davenn, jbriggs444 and 4 others
<h2>1. How do you determine which tank fills first?</h2><p>The tank that fills first is determined by the rate at which water is entering and exiting each tank. The tank with the highest inflow rate and the lowest outflow rate will fill first.</p><h2>2. What factors affect the filling rate of each tank?</h2><p>The factors that affect the filling rate of each tank include the size of the tank, the size of the inflow and outflow pipes, and the pressure of the water entering the tank.</p><h2>3. Can you predict which tank will fill first every time?</h2><p>While it is possible to make predictions based on the factors mentioned above, there are other variables that could affect the filling rate, such as changes in water pressure or blockages in the pipes. Therefore, it is not always possible to accurately predict which tank will fill first.</p><h2>4. How does the shape of the tank affect the filling rate?</h2><p>The shape of the tank can affect the filling rate by changing the surface area of the water exposed to the air. A taller, narrower tank will have a smaller surface area and therefore a slower filling rate compared to a wider, shallower tank with a larger surface area.</p><h2>5. Can the order of the tanks be changed to affect the filling rate?</h2><p>Yes, the order of the tanks can be changed to affect the filling rate. Placing the tank with the highest inflow rate first and the tank with the lowest outflow rate last will result in the fastest overall filling time.</p>
  • Classical Physics
