Which will buckle first?
  1. Nov 21, 2014 #1
    Hi, guys!
    I am trying to work out with beam will buckle first, either a beam with a square cross section, 5x5 or a beam with a square cross section, 6x6 with a 1x1 square removed from the middle of the section.
    2. Relevant equations
    3. The attempt at a solution
    Well I'm not really sure as they have the same dimensions in a way, 5 for the 5x5 and 6-1 for the 6x6. But I am think that as a hollow cylinder is stronger than a full cylinder, the 6x6 with a hole in the middle will buckle second.
    Any help would be greatly appreciated!
  3. Nov 21, 2014 #2
    SteamKing
    Staff Emeritus
    You really can't say what will buckle first, just going by the cross section of the member. The unsupported length of the member, the end conditions, any eccentricities in the applied load all influence calculating the critical load beyond which buckling can be expected.
  4. Nov 21, 2014 #3
    Hi SteamKing,
    Yeah I'm not given much expect those are the two cross sections of long and slender bars which are loaded in compression with a pin ended support. They are both subjected to the same force and are the same length.
  5. Nov 21, 2014 #4
    SteamKing
    Staff Emeritus
    The critical buckling load is given by Euler's formula:
    F = π2E I / (K L2), where for pinned-pinned columns, K = 1.0
    L = unsupported span
    E = Young's modulus for the column material
    I = second moment of area of the cross section
    In calculating I, you must find the axis about which the second moment of area is a minimum. For sections which have axes of symmetry, the second moment calculated about one of those axes will have a minimum value, and this value must be used in Euler's formula.
    You should be able to calculate the second moments for the two beam cross sections given in the OP and decide which figure gives the smallest second moment value.
  6. Nov 21, 2014 #5
    correct me if i'm wrong but the 6x6 even removing the 1x1 core would outweigh the 5x5 increasing its total downward force on the span.
  7. Nov 21, 2014 #6
    SteamKing
    Staff Emeritus
    It's not a matter of weight, insofar as buckling is concerned. It's how the material in the cross-section is distributed around the centroid of the section.
  8. Nov 22, 2014 #7
    So I calculated the second moment of areas and found that 6x6 one has a much greater I than the 5x5. So I think that from the formula that the 5x5 would bend first? Thanks!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Which will buckle first?
  1. Euler Buckling (Replies: 1)
  2. Liner buckling (Replies: 2)
Loading...
