Homework Help: Who can confirm this for me?
  1. Apr 11, 2012 #1
    A railroad car of mass 12,000 kg collides and couples with a second car of mass 18,000 kg that is initially at rest. After the collision, both move at a speed of 4.8 m/s.
    What is the initial momentum and initial speed of the first car?
    2. Relevant equations
    The formulas that I´ve used are:
    Pi = pf = mv
    vi = pf/m
    3. The attempt at a solution
    So, I´d like someone to confirm my answers:
    For Pi (initial momentum) I did:
    Pi = pf = mv = (12,000kg + 18,000kg)(4.8m/s) = 144,000kg.m/s
    For Vi (initial speed) = Pf/m = 144,000/12,000 = 12m/s.
    Are my answers correct?
  3. Apr 11, 2012 #2
    They appear to be correct. Nice job.
  4. Apr 11, 2012 #3
    Thankss!!! =D
  5. Apr 11, 2012 #4
    I have another question. Could you confirm the other as well? Please??
    A rifle with a mass 2.2kg fires a bullet with a mass of 5g. The bullet moves with a velocity of 600m/s.
    1) What is the momentum of the bullet after it´s fired?
    2) What is the recoil velocity of the rifle assuming that no external forces act on the rifle?
    P = mv
    For question 1) P = 0.005kg x 600m/s = 3kg. m/s.
    For question 2) I wrote 0.
  6. Apr 11, 2012 #5
    1) Should be 30 kgm/s, not sure if you just had a typo.
    2) 0 is incorrect. You have the 30 kgm/s of momentum from the bullet, right? Therefore, there must be an equal and opposite momentum acting on the rifle.
  7. Apr 11, 2012 #6
    I wish it were at typo. Actually, the calculation is correct. Am I using the wrong information?
    Now for question number 2, you mean p = -p, so the answer would be -30?
  8. Apr 11, 2012 #7
    I just would like to say that I am truly appreciating your help!! :)
  9. Apr 11, 2012 #8
    Whoops, my bad on number 1. MY typo on the calculator xD. As for 2), yes, the momentum of the rifle would be -3, but you're looking for the velocity.
  10. Apr 11, 2012 #9
    help me with this 1 please
    A teddy bear of mass 400 grams is hung from the end of a spring. The spring measures 51.0cm long in the rest position; when the teddy bear is attached to the end of the spring, the spring extends to 72.0cm. Calculate the elastic potential energy stored in the spring when extended to 72.0cm.
  11. Apr 11, 2012 #10
    hahaha no problem :) You are still being EXTREMELY helpful.
    The question: A rifle with a mass 2.2kg fires a bullet with a mass of 5g. The bullet moves with a velocity of 600m/s.
    I am looking for recoil velocity,
    would that be 2.2 divided by 600m/s ?
  12. Apr 11, 2012 #11
    I am sorry but I am not sure about I should find the recoil velocity.
  13. Apr 11, 2012 #12
    No, your momentum is -3, right? P=mv. Mass of the rifle is 2.2kg. What is your velocity?
    As for Tom, you should probably post your problem in your own thread. You also need to post an attempt at a solution first.
  14. Apr 11, 2012 #13
    v = p/m
    v = -3kg.m/s divided by 2.2kg = -1.36 m/s.
    So to find recoil velocity I should just use v=p/m. That´s how I find it, right?
  15. Apr 11, 2012 #14
    Divide, not multiply ;)
    Edit: Yes, that's correct :)
  16. Apr 11, 2012 #15
    Thank you so much (again!) xD
  17. Apr 11, 2012 #16
    You did most of the work yourself ;), nice work. Now I'm off to bed :zzz:
  18. Apr 11, 2012 #17
    have a good night! :)
