Why is 1/G Used in GR Lagrangian?
In summary: The Lagrangian is proportional to 1/G if G is small, and the gravity term is proportional to 1/G if G is large.
nickyrtr
93
I have started reading about the Lagrangian in General Relativity, in relation to the Einstein-Hilbert action, and there is something that does not make sense to me. The Lagrangian is split into two pieces, one derived from the Ricci curvature and the other labeled L_matter, so far so good.
What I find odd is that the Ricci curvature part of the Lagrangian is proportional to 1/G. This seems a contradiction with the way gravity is always described as much weaker than the other forces, as represented by a very small value for G. Why then is the gravitational part of the Lagrangian proportional to 1/G, which would be a very large number if G is small. I would have expected the gravity contribution to the Lagrangian to be smaller than the other forces' contribution. What am I missing?
You need to look at the overall picture. In general, multiplying the Lagrangian by a constant will not change the EoMs. The term with the Ricci scalar is not going to affect the EoMs of the matter fields simply because it does not depend on them. In a world without matter, the G does not matter for the EoM of the metric and therefore the matter interaction terms arise from the matter Lagrangian. For these terms to be suppressed for small G, you need the matter Lagrangian to be suppressed by G wrt the Ricci scalar term.
A Lagrangian has units of energy (or energy density), so this question about the Lagrangian is equivalent to the following. Suppose we write an expression for the energy density of a field in terms of the field strength. Expressions like this are always of the form (energy density)=(1/k)(field)2, where k is a coupling constant. Why is it the inverse of the coupling constant that appears here? The answer is that for a field created by a given source, the field strength is proportional to k. Therefore if we have a fixed source, the energy of its field is actually proportional to ##(1/k)(k^2)=k##.
OK, that helps. If you double G, then (1/G) is cut in half, but the Ricci curvature is four times stronger, so the Lagrangian is doubled. Is that right?
Right.
1. Why is 1/G used in the GR Lagrangian?
The constant 1/G, also known as the gravitational constant, is used in the GR Lagrangian because it represents the strength of the gravitational force. This value is necessary to accurately describe the behavior of objects under the influence of gravity.
2. How is the value of 1/G determined?
The value of 1/G is determined through experimental measurements and calculations. Scientists use various methods, such as measuring the deflection of light around massive objects or observing the orbits of planets, to accurately determine the value of 1/G.
3. What is the significance of 1/G in general relativity?
In general relativity, 1/G plays a crucial role in the equations that describe the curvature of spacetime and the behavior of matter under the influence of gravity. It is a fundamental constant that helps us understand the fundamental nature of the universe.
4. Why does the value of 1/G differ from planet to planet?
The value of 1/G can vary slightly from planet to planet due to differences in the distribution of mass and density. This can affect the strength of the gravitational force and therefore the value of 1/G.
5. Can the value of 1/G change over time?
Based on current scientific understanding, the value of 1/G is considered to be a constant. However, some theories, such as those related to the expansion of the universe, suggest that the value of 1/G may have changed over time in the past and could continue to change in the future.
