Why are Clouds white?
  • Thread starter cragar
Why are clouds white and rapids white, same kind of thing. I was reading about it and it said something about the EM wave inducing a dipole in the water. If white light shines through a large body of water it doesn't look white. So does it have something to do with them being in droplet form. I am looking for an answer on the atomic scale and how Maxwells equations describe the interaction with the water. Any input will be much appreciated. I guess i just don't understand the mechanism behind scattering.
Answers and Replies
Dale
Mentor
Insights Author
2020 Award
31,520
8,281
Water is transparent to visible light, so clouds are white because they scatter all wavelengths approximately equally.
thanks for your answer, what causes something to scatter light?
A proper surface and a refractive index. In this case, the ice in the clouds are refracting light.
When the EM wave travels through the ice, does it create surface currents?
Dale
Mentor
Insights Author
2020 Award
31,520
8,281
Probably not much free currents, but polarization currents certainly. However, any time the speed of a wave is different in one medium vs another you will get refraction, and if you refract and reflect off of a bunch of surfaces in different directions then you get scattering.
DaveC426913
3,010
For the record, almost all clouds do not have ice, they have water droplets. (For ice, you're looking at cirrus clouds - the high altitude wispy mare's tails that portend a cold front.)
By polarization currents you mean [tex] D=\epsilon_0E+P
[/tex]
When the EM wave is in the medium it is constantly inducing electric dipoles, And do these dipoles affect the E and B components of the EM wave?
Dale
Mentor
Insights Author
2020 Award
31,520
8,281
Yes. That is essentially the reason why the E field is different from the D field.
ok thanks for your answer
D H
Staff Emeritus
Insights Author
15,415
687
Those water droplets are very, very small. Average size is about 10 microns, but some are micron-sized or less -- about the same size as typical visible light wavelength. This means that Mie scattering is significant in clouds, and it is Mie scattering that explains why clouds are white.
I don't konw either. BUt my guess is that there are so many of the small droplets. The light dispersed by droplets would simply mix together.
Color of sky is caused by polarization of reflection, where as polarization of refraction in the water droplets are mixed (exactly the seven colors of rainbow which combine into white).
I'm not quite with this explanation, because this contradicts with phenomenon of rainbows. So in my guess, Rainbow is because of a very thin layer or spherical shell of water that light doesn't mix that much.
Here I think it's just the difference between free E field and net E field
Anyways, just some guesses.
D H
Staff Emeritus
Insights Author
15,415
687
Don't just guess! Google is your friend. A simple search would cut down on the guessing.
Rainbows form when light scatters just once (primary rainbow) or twice (double rainbow). Clouds are white because light passing through a cloud scatters many, many times, and does so in a complex manner due to the tiny size of the droplets. Those tiny droplets are about the same size as a typical visible light wavelength, so Mie scattering is a key feature of what is going on inside of clouds.
But I still don't think that explanation from DaleSpam is sufficient for this question. I know about physics behind primary and double rainbow, they are caused by refraction and total internal reflection. So what I'm thinking here is that these monochromatic lights mix into white light, as cloud is much thicker than layers of single droplets.
D H
Staff Emeritus
Insights Author
15,415
687
I gave the answer, two times now. Google the term "Mie scattering".
Dale
Mentor
Insights Author
2020 Award
31,520
8,281
My answer doesn't contradict rainbows. Those are generally caused by larger droplets of water where there is nice clean refraction and internal reflection rather than scattering. They are different processes that depend on different sizes of the droplets. This is why you see rainbows more around your sprinkler than around your teapot.
But rainbow is similar to prism also. How can rainbow be created if droplet diffract different frequencies exactly the same? Like what I said total internal reflection, refraction only create primary and secondary rainbows. But the difference in color is dispersed by droplets.
DaveC426913
3,010
Zeal: clouds are formed of droplets in the microns size, very close to the wavelength of light where Mie scattering occurs. Rainbows are formed of droplets many times larger than the wavelength of light, where normal refraction occurs.
You see clouds all the time but you only tend to see rainbows when there's actual rain.
I learned about Mie scattering with a 30 second visit to Wiki.
Dale
Mentor
Insights Author
2020 Award
31,520
8,281
Diffraction is not relevant AFAIK. The small water droplets scatter all frequencies approximately the same. The larger droplets refract different wavelengths differently. You are mixing up different phenomena. Refraction is different from scattering is different from diffraction.
Sorry, I mean refract, misprinted. But why doesn't scattering like that won't cause polarization of light? Because light scattered by air molecules is polarized.
Dale
Mentor
Insights Author
2020 Award
31,520
8,281
I don't know anything about the polarization of scattered light. Sorry. Perhaps the link on Mie scattering has something.
Sorry, I don't know either, I just can't quite understand it, so I'm asking it. Because air molecules polarizes light by reflection. But the reflection of light is similar pattern to the mie scattering that I looked at. Sorry for my deficiency of knowledge in this area. But I just don't quite get it. Probably I can start a thread about that.
Redbelly98
Staff Emeritus
Insights Author
12,133
160
The number of scattering events is important too. For just one scattering event (rainbows, blue sky), polarization and color-separating effects are easily visible.
For many many scattering events (clouds, whitewater), the polarization gets randomized, and colors get mixed together.
Related Threads on Why are Clouds white?
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
