The Significance of C in Einstein's Famous Equation E=MC^2
  • Thread starter Darwin
  • Tags
    E=mc^2
In summary, the special property of the speed of light is its invariance for all inertial reference frames, and this, along with the postulate of relativity that the laws of physics are the same for all inertial reference frames, leads to the derivation of the time dilation and length contraction formulas. With these, the formula for the kinetic energy of a moving object according to relativity can be derived, which involves the square of velocity. This is why the speed of light is squared in the famous equation E=mc^2.
Darwin
Why "C" in E=MC^2
What special property of the speed of light imposes itself on the amount of energy in a mass? Why should that energy be an exact multiple of the speed of light squared? Why not a multiple of some other constant like the Bohr radius, the Boltsmann constant, or the free electron g factor, or just some other number, such as my shoe size?
The special property of Light is that its relative velocity is invarient for inertial reference frames. IOW, no matter who measures the speed of light, or what their relative velocity to each other is, or their relative velocity to the source of the light, they will always get the same value for the speed of light relative to themselves.
With this and the other postulate of Relativity, that the laws of Physics are the same for all inertial reference frames, you can derive the time dilation and length contraction formulas. In turn, with these you can derive the formula for the kinetic energy of a moving object according to Relativity.
(as energy is measured in units of [itex]\frac{md^2}{t^2}[/itex] and time(t) and distance(d) are effected by relative velocity, it stands to reason that the kinetic energy of the object will likewise be effected.)
If you then set v in this formula to 0, (for an object at rest) you are left with
[tex]e=mc^2[/tex]
Darwin, i would suggest learning a little something about basic dimensional analysis (dimensionally, it has to be some velocity squared) and also Planck units. Wikipedia has articles in both.
To add to Janus' post...
Although we call "c" the "speed of light", it might be better to think of "c" as the "[invariant] maximum signal speed", which is a property of structure of space-time. It just so happens that "light", a phenomena of the electromagnetic field, propagates at this maximum signal speed.
With the issue framed in this way, those other parameters you mentioned [Bohr radius, Boltzmann constant, g-factor, your shoe size,...] are not distinguished in any way.
It might be interesting to note that Galilean/Newtonian physics has no analogous [finite, dimensionful] parameter like "c".
In addition to these sage comments, the c in mc^2 comes from the "gamma" function: (I hope the LaTeX works this time!)
[tex] \gamma = \frac{1}{\sqrt{1-v^2/c^2}} [/tex]
(It worked! Yay!)
Anyway, that's the definition of gamma. When we express the energy function we get an expansion in terms of c^2.
The other way to do it is to look at the 4-vectors. The energy-momentum 4-vector always takes the form: (E/c,px,py,pz) The c is required here to make sure that the "square" of this 4-vector takes the appropriate constant. Squaring the vector we get [tex] \frac{E^2}{c^2}-p^2=m^2c^2 [/tex], which is the general form of E=mc^2.
-Dan
have a look please at
http://arxiv.org/abs/physics/0505025
comments appreciated
I've always wondered why its c squared. Apart from the fact that mathematically it works out that way, is there any understanding for why you would want to square a velocity to find energy? Or why it appears again in other relativity equations: sqrt(1 - v^2/c^2) ?
The kinetic energy of a moving object is equal to (m*v^2)/2
m= mass
v= velocity
So, it is not *strange* to relate energy with the square of velocity.
Leandros
In both non-relativistic and relativistic mechanics, kinetic energy is derived via the work-energy theorem: the change in an object's kinetic energy equals the work done by an external force.
[tex]\Delta K = W = \int {Fdx} = \int {\frac {dp}{dt}} dx[/tex]
In the relativistic case you have to use relativistic momentum [itex]p = m \gamma v[/itex], which brings in the [itex]\gamma[/itex] factor that you mention above.
In turn, the relativistic momentum can be derived by analyzing a collision carefully, taking length contraction and time dilation into account. This is how [itex]\gamma[/itex] gets into the relativistic momentum.
Finally, to see how the [itex]\gamma[/itex] factor comes about in the first place, see (for example) the common derivation of the time-dilation equation using a light-beam clock:
http://www.phys.unsw.edu.au/einsteinlight/jw/module4_time_dilation.htm
I'm sure there are other ways of doing all this, but this is probably the most common chain of logic that you'll see in introductory "modern physics" textbooks.
Ok, but what I mean is, for example, if we square a distance its pretty easy to understand what that means. But I can't understand what squaring a velocity means, or how it has anything to do with energy.
Physically, it's the same as force times distance and again, getting the units/math to work out is the entire point here. The word "energy" doesn't have some mystical meaning, we use the word to describe a useful mathematical expression.
Also - how does squaring a distance make sense where squaring a velocity doesn't?
1. Why is C used in the equation E=MC^2?
C is used in the equation E=MC^2 because it represents the speed of light in a vacuum. This is a fundamental constant in the universe that plays a crucial role in understanding the relationship between energy and mass.
2. What does the C stand for in E=MC^2?
In this equation, C stands for the speed of light. This is the maximum speed at which all forms of energy and matter can travel in the universe.
3. How does the speed of light relate to energy and mass?
The speed of light is a fundamental constant that relates to energy and mass in the equation E=MC^2. This means that the amount of energy contained in a mass is equal to its mass multiplied by the speed of light squared.
4. Why is the speed of light squared in E=MC^2?
The speed of light is squared in this equation because it is being multiplied by itself. This is due to the fact that energy and mass are directly proportional to each other, so the speed of light must be squared to maintain this proportionality.
5. What is the significance of E=MC^2?
E=MC^2 is one of the most famous equations in physics and has significant implications for our understanding of the universe. It shows that energy and mass are essentially interchangeable, and that mass can be converted into energy and vice versa. This equation also forms the basis of Einstein's theory of relativity and has been confirmed by numerous experiments and observations.
13K
