Why can't we see sound waves?
  • Thread starter Dremmer
Dremmer
92
Answers and Replies
phinds
Insights Author
2021 Award
17,917
10,157
why would you EXPECT to be able to see sound waves ???
jbriggs444
11,301
5,883
We can, to the extent that dense air refracts light. This is visible in the shock waves resulting from exploding bombs.
Low volume sound waves in air move fast, don't refract much and have even less effect when viewed from the direction of either source or receiver, so you cannot expect to see the sound of your own voice with your own naked eyes.
dipole
555
150
The short answer is you can, but the sound has to be very loud.
boneh3ad
Insights Author
1,116
Google "schlieren" and you can see even some minute sound waves. If the waves are powerful enough to cause large density gradients we can see them through the light they refract. Slightly weaken and we can use schlieren or shadowgraph techniques to see them.
nonequilibrium
1,437
In a sense we can see sound, we just call it "hearing".
Or do you also wonder why we can't hear light?
Vorde
788
phinds had it right though. There is no reason to assume we can.
dipole
555
150
Yes there is. Sound waves are density waves, and the index of refraction of air changes with density, so you should be able to see the wavefront as an interface between two regions of different density, which you can, if the amplitude is high enough, or if you use the methods boneh3ad posted.
phinds
Insights Author
2021 Award
17,917
10,157
Yeah, I was just assuming he meant voice-level sound waves. I knew really strong density waves would be visible, as you say.
I don't think anything that would not break your eardrums if you were anywhere near it would be strong enough to see.
AustinJones
25
Have you ever seen a jet break the barrier for the speed of sound?
Vorde
788
But we see that second hand, I assumed the OP meant directly.
OmCheeto
2,696
I think it is because air is fairly transparent.
If you could see air, then you would probably be able to see sound waves, of certain magnitudes and frequencies. Kind of like sitting and staring at your audio speakers. You can see the woofers moving, but the tweeters just sit there, and make your ears hurt.
AustinJones
25
remember that a wave is only "how energy travels" sound waves are more of a slight amount of energy exerted from initial contact, or an after effect of disruption in the air traveling outward.
you disrupt the water by dropping a stone, you see waves.
you disrupt the air by clapping your hands, you hear a wave.
your only going to see sound waves that are large relatively in comparison to yourself
Drakkith
Staff Emeritus
6,049
While the above replies make it clear that we can see sound waves in specific circumstances, I feel they don't really answer the question. I would say that we can't see sound waves because our eyes aren't designed to be able to do so. The eye uses a lens that focuses light onto the retina where special cells that are sensitive to light reside. These cells detect the light and send signals to your brain. The end result is sight.
Sound waves do not activate any part of the visual system and so we cannot see sound waves directly, only when light interacts with a sound wave in a certain way. Instead our ears are designed to detect sound waves.
phinds
Insights Author
2021 Award
17,917
10,157
No, have you? I have HEARD it several times but there has never been anything to see.
ZapperZ
Staff Emeritus
Education Advisor
Insights Author
35,995
4,711
Discussions on here have the tendency to stretch things out way outside of the scope of the question. The OP hasn't come back to respond and clarify the question. I suggest we all sit back and be patient till that occurs before tripping all over ourselves on what the question really is asking for (I doubt the OP was thinking about seeing the refraction of light due to variation in air density).
Zz.
A.T.
2,900
https://www.youtube.com/watch?v=gWGLAAYdbbc
Suggested for: Why can't we see sound waves?
