Why Do Molecules Move: Exploring the Physics Behind It
  • Thread starter prj45
  • Tags
    Molecules
In summary: I'm not sure how that helps.In summary, a single molecule of hydrogen gas at room temperature would be travelling at 6000 feet per second due to its internal vibrations. If you reduced the temperature to 0K, then warmed it up again, the molecule would still move off in a random direction. Head on collision with another with exactly the right circumstances would be necessary to stop its movement.
  • #36
ZapperZ said:
...the concept that you are using such as "particle" may be the one at fault...
Oh, most definitely Zapper. I think "particle" has caused a whole heap of problems.
Thanks for trying Astronuc.
  • #37
Don't just quit! Now it's getting interesting. Electrons and any other charged particles are moved by electromagnetic and other fields, oscillating and non-oscillating, fields - and there are plenty around in space and vacuum. We all seem to be victims of Dr. Brown's observation of pollen quivering on the surface of a drop of water under his microscope as a result of the surrounding irregular bombardment by by water molecules. What a nonsense when you consider the difference of mass between an oscillating water molecule and the asteroidal mass of the pollen it pounces on. Then consider the zillions of water molecules in the immediate boundary layer of water enveloping the pollen. Then consider Stokes' law which would prohibit the small pollen particle to move at the observed speed through water. Then submerse a 0.8 micrometer diameter particle in water and observe its random motion "through" the water vehicle. Its velocity is now so much faster than that of the much larger pollen, thus defying Stokes' law even more. Our pool ball collision kinetics seems to be totally outdated.
Now, what kicks the molecule off your 0 K pedestal, accelerates it from zero to meters per second speed for ever if nothing else bumps into it? If we feed it with the photon's energy, why would this energy have to manifest itself as kinetic energy in the molecule and not in any other form of energy? I would say, the molecule would simply stay on its pedestal and enjoy the swallowed energy from the photon as potential energy. Period.
Why do molecules move? They follow field gradients. The field quiver.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
