Can Orbiting Bodies Slow Down Over Time?
In summary: Yes, we can say that planets are in perpetual motion. However, if you're expecting the planets to crash down due to some effect, ask yourself why.
micropulsar
We see in our solar system the planets orbiting the sun, but why doesn't with all of the other forces in play the perpendicular velocity seemingly not decrease(or does it?). And if the perpendicular velocity of the planets slow down would that result in static planets not moving around the sun?
Just like an ideal pendulum in a vacuum could go on forever, a planet orbiting can go on forever. A planet in our solar system will be constrained to orbiting the sun, just like a pendulum is constrained by the cable that it hangs from. A planet will speed up (slightly) as it heads toward a far away gravitational body, just like a pendulum will speed up as it heads toward the Earth. The planet will slow down (slightly) as it swings around the Sun and heads away from that gravitational body. Unlike a pendulum, the planets have enough velocity to continue all the way around the sun in an orbit without being slowed to a stop by a far off body. So a planet orbits instead of swinging back and forth like a pendulum. This can continue forever.
All the other forces are either affecting everything in the solar system just as much as they affecting the Earth (gravitational interactions with other stars, galaxies, etc), or don't affect the Earth the because their range is too small or the Earth is neutral (the other 3 forces of nature).
The only way to decrease their total kinetic energy is through very small effects, like converting it into gravitational waves or EM-waves (heating though tidal forces).
Have you heard of gravity?
Well, I imagine given enough time the combination of friction from interstellar particles/gas and many-body effects, even without counting the possibility of some rogue body entering the system and altering its equilibrium, would slow down orbits and make the planets spiral down and fall into the sun or crash into each other. And by 'enough' I mean many times over the actual time the system will last before the Sun goes red giant and vaporises the Earth anyway.
What do you mean by pendicular velocity? If you mean the component of the velocity perpendicular to a line passing through the sun and the planet, it does change. If you're expecting the planets to slow down due to some effect, ask yourself why.
A force perpendicular to the direction of motion merely changes the direction, not the speed. Moreover, energy is conserved, so the only way for orbits to slow down is by radiating something, such as gravitational waves, which are really, really, really weak.
Right. But it's very rare that the force is perpendicular to the direction of motion.
When an orbiting planet slows down it's kinetic energy decreases, but the potential energy of the planet-sun system increases. And vice-versa. It's happening in our solar system as we speak.
In general can we say that planets are in perpetual motion and as man made perpetual motion devices fail after some time of workout, the planets will also crash down after calculated time depending on all of the forces in action even if sun does not blast?
In theory nothing prevents a conservative system to move perpetually as long as nothing extracts energy. In practice of course this is never perfectly true - planets exchange energy with the environment in small ways (including stuff like meteor impacts), so I suppose on the long, long, LONG run they will lose their orbits. Not a "calculated" time because there's nothing strictly predictable about it. Yes, the orbit's stability itself is somewhat of an approximation since the exact solution to the many-body problem isn't known, but that doesn't mean that the planets ought to crash - the energy is there and if nothing takes it away then the orbits' shapes might change but the total energy should be conserved, and therefore something would probably keep orbiting more or less forever.
There are tidal forces that generate a conversion of mechanical energy to thermal energy.
Right, didn't think of that. So there's that too. Also orbiting bodies radiate gravitational waves I believe? So if we go from Newton to Einstein we have another source of energy loss which prevents orbits from being eternal.
1. Why do orbits not slow down?
Orbits do not slow down because of the law of inertia, which states that an object will remain in motion unless acted upon by an external force. In the case of orbits, the external force that keeps them moving is the gravitational pull of the object they are orbiting around.
2. Can orbits eventually slow down?
Yes, orbits can eventually slow down if there is an external force acting upon them that is stronger than the gravitational pull of the object they are orbiting around. This can happen due to factors such as atmospheric drag or gravitational interactions with other objects.
3. Do orbits always maintain the same speed?
No, orbits do not always maintain the same speed. When an orbiting object is closer to the object it is orbiting around, it will move faster due to the stronger gravitational pull. As it gets farther away, the speed will decrease due to the weaker gravitational pull.
4. How do orbits stay in motion without slowing down?
Orbits stay in motion without slowing down because of the balance between the object's inertia and the gravitational pull of the object it is orbiting around. The object's inertia keeps it moving forward, while the gravitational pull keeps it from flying off into space.
5. What would happen if orbits did slow down?
If orbits were to slow down, the orbiting object would eventually stop and fall towards the object it is orbiting around. This can happen if there is an external force acting upon the orbit, or if the gravitational pull of the object being orbited around becomes stronger due to factors such as changes in the object's mass.
  • Other Physics Topics
  • Astronomy and Astrophysics
