Why Does Energy Exist?
  1. Mar 21, 2015 #1
    Does anyone know why energy exists?
  3. Mar 21, 2015 #2
    I don't think so, but there is reasonable argument that there is such a thing as energy and negative energy.
    In which case one can imagine that the total energy of the universe is zero.
    If that is so, then we live in a part of the whole universe where more of what we interpret is positive energy.
    The sort of stuff we are made of.
    Just so that nobody gets confused about what I said, this has nothing to with ideas about 'good' or 'bad' energy.
  4. Mar 21, 2015 #3
    DaveC426913
    Science does not attempt to answer 'why' questions. Science simply attempts to describe the universe as it is observed to be.
  5. Mar 21, 2015 #4
    Drakkith
    Staff Emeritus
    First it may help to understand just what energy is.
    Put simply, energy is the ability to perform work. Work is defined as the application of a force over a distance. If you apply a force to an object, and that object accelerates in response to that force, you have performed work. So you can say that energy is potential work. A bullet flying through the air has a lot of kinetic energy because it performs work, either the air through compression and friction, or upon the target and itself upon impact. Once it has lost all of its kinetic energy it simply sits there inert upon the ground or embedded in a target.
    The concept of energy exists because it is much easier to understand physics and solve many problem if you think in terms of how much potential work an object can perform. It doesn't matter exactly how the object performs this work, it can only perform a set amount of work in a given circumstance. A bullet performs exactly the same amount of work whether it hits a target three feet away from the barrel or flies three miles before hitting the ground. So we say that the bullet has a certain amount of a quantity that we have labeled as 'energy' that can be converted or used in many different ways.
    So in this way you can think of energy as 'bookkeeping'. We invent a quantity to help us with our physics and then we track that quantity as it gets converted to different forms and given to different objects. It exists simply because we have labeled this potential to perform work as an independent quantity itself.
  6. Mar 22, 2015 #5
    Andrew Mason
    Energy is related to mass, distance and time. Time is a measure of the rate at which something changes. If nothing changed, time would not haven any meaning. Mass is the measure of how resistant matter is to changing its motion (which is related to distance and time). Distance is a measure of a change in position in a frame of reference. So long as matter is moving, there will be a concept of energy.
    Put another way: Your question is one that can be asked only in a universe in which energy exists.
    AM
Similar Discussions: Why Does Energy Exist?
  1. Does energy exist? (Replies: 4)
  2. Why does gravity exist? (Replies: 75)
  3. Why does torque exist? (Replies: 8)
Loading...
