Why does rust not dissociate in water?
  • Thread starter wasteofo2
  • Tags
    Rust Water
In summary, bonds between metal and non-metal are partially covalent and not always ionic. Dissolution of ionic substances in water depends on the strength of the bond and the size of the molecules/atoms involved. In the case of rust (Fe2O3), the bond is too strong for water to break, thus it does not dissociate. This can also be seen in other ionic substances such as Al2O3 and Ca(OH)_2.
wasteofo2
478
From my rhudimentary Chemistry education, I've been led to believe that any bond between a metal and a non-metal is an ionic bond, and that ionic bonds will dissociate in water. Rust is certainly a combination of a metal and a non-metal, and unless I'm horribly mistaken, it is also ionic. And yet, rust does not dissociate in water. Why is that?
Does it have something to do with the unusual way in which rust (Iron (III) oxide, if I'm correct) forms?
Thanks,
Jacob
Chemistry news on Phys.org
There is no such thing as 100% ionic bond, there is no such thing as 100% covealent bond. Every bond between metal and non-metal is partially covalent - sometimes less, sometimes more. So your first assumption is wrong.
Your second assumption - that every ionic substance should dissolve in water - is also wrong. It happens only if dissolution is favorable - there are at least two processes responsible, one is destruction of the bonds (mostly ionic), second is solvation of ions. Sometimes effects of solvation prevail, sometimes bonding.
Water is a polar molecule, right? Well each molecule only has so much pull, or only so much force that it can apply to rip an ionic molecule appart.
Look @ it this way, assuming Fe2O3 the Fe ion is in the +3 state, whilst the O is in the -2 state, so for water to dissolve it, the individual water molecules would have to collectively have a stronger pull than both the Fe+3 ions, and the 0-2 ions. Water just doesn't have enough attraction to rip them appart from one another. It really comes down to the strength of the bond(s), the size of the molecules/atoms involved.
For instance, Al2O3 (Aluminum oxide, clear Sapphire) cannot be dissolved in water either (it has a much stonger bond than Fe2O3, btw) however, it CAN be dissolved in molten (ie no water) Na3AlF6 (Sodium Aluminum Fluoride, AKA Cryolite) the Cryolite melts @ ~1000 Degrees C, and this is how Aluminum is produced commercially, using electrolysis with the Aluminum oxide (Al2O3) dissolved in the molten cryolite, because water doesn't have enough strength to rip the bonds between the Al+3, and the O-2 appart.
yet another example of an ionic compound that will not dissolve in water is [tex]Ca(OH)_2[/tex]
There is more of an attraction between the electronegative Ca and OH ions then there is attraction of the ions to the dipoles of water (water is highly polar, which is why some ionic substances dissolve at all, but not quite polar enough to break up everything).
1. Why does rust form in the first place?
When iron or an iron alloy is exposed to oxygen and water, a chemical reaction occurs that produces rust. This chemical reaction is known as oxidation, and it is a natural process that occurs when certain metals are exposed to oxygen.
2. What is rust made of?
Rust is primarily composed of iron oxide, which is a compound made up of iron, oxygen, and water molecules. It can also contain other minerals and impurities, depending on the environment in which it forms.
3. Why does rust not dissociate in water?
Rust does not dissociate, or break down, in water because it is a stable compound. The iron oxide molecules in rust are tightly bonded and do not easily separate in the presence of water.
4. Can rust be prevented from forming in water?
While it is not possible to completely prevent rust from forming in water, it can be slowed down or minimized by using methods such as coating the metal with a protective layer, using anti-corrosive chemicals, or controlling the pH levels of the water.
5. Is rust harmful to our health?
Rust is not typically harmful to our health, as it is a natural compound found in the environment. However, rust can weaken the structural integrity of metal objects and may cause them to break or fail if not properly maintained. Ingesting large amounts of rust can also cause digestive issues and irritation.
  • Chemistry
33K
  • Atomic and Condensed Matter
