Why does the earth rotate?
  1. Jan 7, 2005 #1
  3. Jan 7, 2005 #2
    Astronuc
    Staff Emeritus
    The rotation is a consequence of the rotational momentum/kinetic energy that existed at the time the formation of the Earth and Solar System.
    We live in a dynamic universe.
  4. Jan 7, 2005 #3
    russ_watters
    Staff: Mentor
    Since our solar system came from a collapsed cloud of gas and dust, the tiniest asymetry in the structure of the cloud would cause the entire system to rotate about its center. The rotation caused some of the matter to end up in orbit around the sun - no rotation and all of that matter would have fallen into the sun. Similarly, the condensing of the earth in an asymetric way caused the earth to rotate.
  5. Jan 7, 2005 #4
    Gokul43201
    Staff Emeritus
    The short answer is : to conserve angular momentum (as astronuc has stated).
    The long answer is to go through the various stages of the formation of the solar system (which russ has summarized above) and see what the dynamic evolution would have to be like if it satisfied all the conservation laws.
  6. Jan 7, 2005 #5
    Then why does Venus not (barely) rotate?
  7. Jan 7, 2005 #6
    dextercioby
    But it does,the 'other way around' as the other planets,yet it does.The magnitude of the angular velocity is however impossible to predict from theory,because the equations that would govern,let's say,the dynamics of the particle cloud that eventually became "Earth" are nonlinear,which means non integrable.
    It's just like the equations which describe the dynamics of the atmosphere.Assuming thy were linear and integrable,we could predict weather without having those satellites into orbit.
    Daniel.
  8. Jan 7, 2005 #7
    Andrew Mason
    Here's a good question:, since angular momentum is conserved, how do you 'create' angular momentum from an original system containing zero angular momentum? (ie: you can't). So where does angular momentum come from?
    AM
  9. Jan 7, 2005 #8
    dextercioby
    What do you mean "original system containing zero angular momentum??
    Which system??The initial cloud of particles from which our Solar system evolved??
    Daniel.
  10. Jan 7, 2005 #9
    Andrew Mason
    Any isolated system containing 0 angular momentum.
    Is it possible that the cloud of gas from which the solar system was formed started out with 0 angular momentum?
    AM
  11. Jan 7, 2005 #10
    Astronuc
    Staff Emeritus
    It would be unlikely.
    There was probably some initial angular momentum. How much depends on the particular theory of the formation of the solar system.
    Furthermore, with assymmetry in mass distribution and under the influence of gravity (not everything converging at an equal rate to the same center of mass), the consequence is non-zero angular momentum.
  12. Jan 7, 2005 #11
    dextercioby
    The simplest analysis which i can imagine would start from the Boltzmann equation and would yield only in the simplest possible case (frition proportional to gradients of velocity field) the Navier-Stokes equations in which the gravity term would appear given by Newton's law.Essential would be turbulence (with vortices) and how would initial nonhomogeneities in density would evolve under the influence of gravity and strog rotational velocity fields.
    Daniel.
  13. Jan 7, 2005 #12
    The mere fact that the mass of the solar system is not completely at it's centre but instead is orbiting it, signifies that the system as a whole had an significant angular momentum as of it's birth.
    Assuming no external torque forces the total angular momentum of the solar system is still the same. As the norm is positive orbit and positive spin for the majority of the bodies planets, astroids, moons, the retrograde spin is an exception true only for Uranus Pluto and Venus and an odd small moon perhaps.
    The axial tilt of Uranus of almost 90 degrees suggests that a obliquity swing though the 90 degrees may have been possible in the chaotic motions of certain resonances. That would indicate that the planet may have been born with a normal prograde spin.
    Pluto is in tidal lock with it's moon Charon, indicating that much transfer of momentum had taken place, enough to change prograde spin into retrograde.
    So, again, remains Venus, what about it's enimatic retrograde spin of 247 days versus an orbit of 225 days?
    Oh and
    Odd that the physical truth adapts to a particular theory :wink:
  14. Jan 7, 2005 #13
    I think this is a bit of an overstatement. If you were to examine everything i am sure you will get it right but this is waist of time...pardon the french here but really :rolleyes: :rolleyes:
    The best explanation has been given quite some times. It is possible for a system to have net zero momentum but due to internal inhomogeneous distributions of (for example) matter forces will start to act on these distributions because they are a deviation of the lowest and most stable energystate. This is what will lead to a generated local angular momentum that is nonzero. Due to the conservation of momentum the opposite value of this generated momentum needs to be present in the system and therefore something else will happen besides these disturbances in distribution of matter. Hence the rotation of the earth...
    regards
    marlon
    ps : this is just one way to look at it but the essence is there : conservation of momentum
    :tongue:
  15. Jan 8, 2005 #14
    Andrew Mason
    Exactly. Since angular momentum cannot be created or destroyed the solar system still has the original angular momentum of the gas cloud from which the solar system formed (assuming no outside forces have acted on it in the last 4 billion or so years).
    Has anyone determined what the total angular momentum of the known part of the solar system is? It would be interesting to see what the amount of mass that exists beyond Pluto would be if one assumed that the total angular momentum is 0.
    AM
  16. Jan 8, 2005 #15
    What would the earth be like if it did not rotate?
  17. Jan 8, 2005 #16
    Andrew Mason
    If the earth did not spin at all there would be more mountains because the earth surface would contract. The moon would be closer. We would weigh more (except at the poles). We would have semi annual rather than semidiurnal tides. And we would all have to live as nomads because if we stayed in the same place, we would have days and nights that last for 6 months at a time where the days would be very hot and the nights unbearably cold. Nights would be very dry and calm and days would be very cloudy and turbulent.
    If the earth did not spin we would probably not be asking that question, because we would probably not be here.
    AM
  18. Jan 9, 2005 #17
    FZ+
    Huh?
    If the Earth did not spin, then it would have been shaped differently throughout its formation - in short it would be rounder. I don't see why there would be more mountains, though.
  19. Jan 9, 2005 #18
    Astronuc
    Staff Emeritus
    Mountains are formed when the earth's crust is force upward (up-thrust) as two tectonic plates collide (put fingers tip-to-tip, and push inward) and the intersection pushes up. Also, one plate may overide the other - e.g. subduction zone.
    Mountains may also form as a result of volcanic action - e.g. Cascade mountain range in US.
    Elsewhere, the tectonic plates are pushing apart - e.g. mid-Atlantic ridge.
    The earth is a very dynamic body - the ground is not as solid as some might think, but like glass - the ground can flow, be it slowly. Even concrete creeps! The earth's rotation and gravitational interaction (e.g. tides) are also factors.
  20. Jan 9, 2005 #19
    Andrew Mason
    The earth radius is 6377 km at the equator which is about 22 km greater than at the poles. Work out the area of a sphere 6355 km in radius and then subtract that from the known area of the earth surface. That is how much real estate you would lose if the earth stopped rotating. Where would it go? The only place is up.
    Which raises an interesting point. The earth used to have an 18 hour day about 2 billion years ago. So it must have had a greater equatorial bulge and, therefore, a greater surface area. The loss of that area by the reduction in earth rotation seems to be to be a better explanation for the mountains than continental drift.
    AM
  21. Jan 9, 2005 #20
    russ_watters
    Staff: Mentor
    That mass would go to the poles, and the earth would turn into a more perfect sphere. That's it.
