Why for a group homomorphism
  • Thread starter quasar987
quasar987
I suspect it is quite simple and works by contradiction, but I can't see why for a group homomorphism f, ker(f) = {e} ==> f is injective. Any help?
matt grime
9,394
That's the definition isn't it? Oh, you mean f(x)=f(y) implies x=y... well, if f(x)=f(y) then what is f(xy^{-1})?
AKG
2,559
Suppose f is not injective, i.e. for [itex]x \neq y,\ f(x) = f(y)[/itex]. Then:
[tex]f(x)(f(y))^{-1} = e'[/tex]
where e' is the identity of the codomain of f (e is the identity of the domain of f).
[tex]f(xy^{-1}) = e'[/tex]
[tex]xy^{-1} \in \mathop{\rm Ker}(f)[/tex]
Suppose [itex]xy^{-1} = e[/itex], then [itex]x = y[/itex], contradicting the assumption that they are unequal. So some element Ker(f) contains some element different from e, so it's not {e}.
mathwonk
10,730
908
its called "subtraction".
quasar987
Nice AKG. :smile:
(What is called "substraction"?)
matt grime
9,394
another unnecessary proof by contradiction. a good exercise for you would be to make it a shorter non-contradiction proof, quasar, it's a one liner.
mathwonk's hint is that proving A=B is the same as proving A-B=0, ie take it all onto one side. you presumalby know that a linear map M is injective if the only solution to Mx=0 is x=0, well, this is exactly the same, only the operation isn't addition/subtraction but general group composition.
quasar987
Meanwhile, there's another one I don't get:
f: G-->G' is an homomorphism. If H' is a normal subgroup of G', show that [itex]f^{-1}(H')[/itex] is a normal subgroup of G.
I've shown that it's a subgroup, but can't show it's normal. What I tried:
If H' is normal, then for all g' in G', g'H' = H'g'. In particular, for g' 's such that there exists a in G such that g' = f(a), we have f(a)H' = H'f(a). This means that for all x in [itex]f^{-1}(H')[/itex] and a in G, f(a)f(x) = f(x)f(a) <==> f(ax)=f(xa). But this does not imply that ax=xa unless f is injective. Inversely supposing that [itex]f^{-1}(H')[/itex] is not normal leads to no (obvious) contradiction because it would means that there exists a* in G and x* in [itex]f^{-1}(H')[/itex] such that a*x* [itex]\neq[/itex] x*a*, which does not imply that f(a*x*) [itex]\neq[/itex] f(x*a*).
matt grime
9,394
why would you want ax=xa anyway? that is not the condition of normality of a subgroup. H is normal if for gx in gH there is an element y of H such that yg=gx, there is no requirement that x=y.
i think it's quite straight forward, if H is the inerse image of H', then gx in H implies [tex]f(gx) \in f(gH)=f(g)H'=H'f(g)[/tex] which implies that there is a y in H such that f(yg)=f(xg) so that, pulling back by f gx is in Hg too.
did you redo the proof of the last problem to be a one line proof NOT by contradiction? it would be helpful to your understanding to do it.
quasar987
I hadn't realised that.
May I have a hint?
AKG
2,559
quasar it's very simple. You want to start with the antecedent, and in one line find a bunch of implications, so you have a chain like A --> B --> C --> ... ---> Z, where A is the statement that Ker(f) = {e}, and Z is the statement "f is injective." Do you know how to express the antecedent symbolically? Do you know how to express the consequent symbollically? If so, then it's just some easy symbol manipulation.
(A <--> B) --> (A' <--> B')
(A <--> B) is the symbolic statement that Ker(f) is trivial, and (A' <--> B') is the statement that f is injective, and follows immediately if you know that f is a homomorphism, and you know how to do basic group multiplication (which results in something that looks like subtraction).
matt grime
9,394
As with a lot of proofs by contradiction the fist line "assume that something is not..." is not necessary.
f injective iff ker(f)={e} ( the => is easy since it is a special case of the the general property of being injective: f(e)=e so if anything else satisfies f(g)=e thetn g=e and ker(f)={e})
f(x)=f(y) implies f(xy^{-1}=e, which, by hypothesis means xy^{-1}=e as we required to show.
so we don't prove it by assuming the opposite and getting a contradiction since the proof is actually direct. the same can be done for cantor's diagonal argument.
quasar987
Ooh, I see :smile:.
(I haven't seen multiplication yet AKG)
mathwonk
10,730
908
my calling it "subtraction" might make it sound trivial, but it is a thoroughly proven technique in mathematics to change every problem into the problem of proving something is zero. it is usually done by subtraction.
the reason is that proving something is zero is usually easier.
e.g. in the mean value theorem to show there is a point c where f'(c) = [f(b)-f(a)]/(b-a) one subtracts the function f(a) + (x-a)[f(b)-f(a)]/(b-a)
and applies the Rolle theorem, i.e. the case where we want f'(c) = 0, which is easier to prove.
or for checking a function ahs a maximum, we first take a derivative and see if it is zero (same argument really as rolles).
or for showing some surface is flat we define a "curvature" \and show it is zero.
or for showing all non zero functions in a given region have a complex log, we define the fundamental group of the region and show it is zero.
the list is endless.
AKG
2,559
quasar987 said:
Ooh, I see :smile:.
Sure you have. The basic group operation is often called multiplication unless otherwise specified. But if the use of the word "multiplication" confuses you, ignore that word and replace that part of my post with:
"...and you know how to do (the) basic group operation..."
quasar987
k, I thought you meant the 'product of groups', which is the subject of the next section of my book.
quasar987
matt grime said:
i think it's quite straight forward, if H is the inerse image of H', then gx in H...
You probably meant "gx in gH".
matt grime said:
...implies [tex]f(gx) \in f(gH)=f(g)H'=H'f(g)[/tex] which implies that there is a y in H such that f(yg)=f(xg)
You probably meant "such that f(yg) = f(gx),
matt grime said:
...so that, pulling back by f gx is in Hg too.
I've thought a lot but can't figure it out. What do you mean by "pull back by f" ?
AKG
2,559
Since H' is normal, G'/H' forms a group. Define a function f' : G --> G'/H' by:
f'(g) = f(g)H'
It is easy to check that f' is a homomorphism. What my book calls the First Isomorphism Theorem will tell you that the kernel of a homomorphism is a normal subgroup of the domain, and in particular, Ker(f') is a normal subgroup of G.
Ker(f') = {g in G : f'(g) = H'} = {g in G : f(g)H' = H'} = {g in G : f(g) in H'} = f-1(H')
mathwonk
10,730
908
did you appreciate post 13? it is a general principle vastly more useful than this one question, or perhaps equally useful, if you can see the ocean in a drop.
quasar987
Sweet proof AKG, but unfortunately I haven't seen that First Isomorphism Theorem that you use and would like a proof using only what I know. If matt could just clarify what he meant that'd be great . :smile:
mathwonk, no I didn't appreciated it very much, I'm sorry. I was aware of that principle/trick but do not see how it could apply here. :-/
AKG
2,559
Although I used part of what is called the First Isomorphism Theorem, I used a simple part of if that's very easy to prove. You can prove for yourself that Ker(f) is normal for any homomorphism f. It's extremely easy to prove, so I won't give any hints. The theorem says other things, however, such as the fact that if f : G --> G' is a homomorphism, and K is its kernel, then G/K is isomorphic to f(G), and that the mapping h : G/K --> f(G) defined by:
h(xK) = f(x)
defines an isomorphism between the domain and co-domain. So you can do this proof using my approach if you wanted without referring to the theorem because the part that you'd use is something you can easily prove yourself.
As far as what matt's doing, he's saying that we know that f(gx) = f(yg) for some y in H. You know that you can write gx in the form y'g for some y' in G (y' = gxg-1). Suppose y' is not in H, then f(y') is not in H', so:
f(gx) = f(y'g) = f(y')f(g)
but we know f(gx) = f(yg) = f(y)f(g)
So f(y')f(g) = f(y)f(g), f(y') = f(y), but f(y') is not in H', and f(y) is, which is impossible, so f(y') is in H', so y' is in H, and so gx = y'g in Hg, so gH is a subset of Hg. Similarly, you can show that Hg is in gH. You will have that the left and right cosets of H coincide, and hence you will know that H is normal. I might used a few extra lines above, since I also wasn't sure what matt was doing at first. It seems to me that there was no need to introduce a y, so maybe had an idea for a more efficient proof using it. An even simpler, one line proof:
x in H. If H is normal, then gxg-1 should be in H. Well:
f(gxg-1) = f(g)f(x)f(g)-1 in f(g)H'f(g)-1 = H'f(g)f(g)-1 = H', so gxg-1 is in H, so H is normal.
matt grime
9,394
to be honest what i wrote was the first thing that popped into my head so it probably wo'nt be very accurate (the corrections wer correct in quasar's post) or elegant and may need tweaking to work properly. i can't even remember my thought processes from working it out.
matt grime
9,394
actually it is a one liner
if H is the preimage of H'
f(gHg^{-1])=f(g)f(H)f(g^{-1}) = f(H) thus gHg^{-1]=H
if you don't like doing it with groups then just do it with h in H instead of all of H at once.
edit, sorry, just reread AKG's post where he proves this first.
mathwonk
10,730
908
a subgroup is normal if it is the kernel of a homomorphism, i.e. the things that go to zero.
if H' is normal in G' then G'/H' is a group, so H = f^(-1) (H') is the kernel of the composition
G-->G'-->G'/H'. qed.
another application of my basic principle. i.e. change what you are looking for into zero (the identity).
this is exactly AKG's "sweet proof" in post 17.
quasar987
I'll take the one liner, thank you. :wink:
quasar987
Suppose K is a group. Then K is an infinite cyclic group iff K is isomorphic to the integers under addition.
I've shown everything except that if K is isomorphic to Z, then K is cyclic. Anyone got an idea?
Related Threads for: Why for a group homomorphism
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
