Why glass is transparent
  • Thread starter hagopbul
28
Main Question or Discussion Point
hello
my question is why glass is transparent why the photon are traveling in it with out being absorb
use equation & explanation ,
please this Q? for high level Physicist not for any one so pleas if you cant use proper equations DONT REPLY
and why its path are so specific and strait ?
Answers and Replies
alxm
Well, a "high level physicist" should already know that there is no single equation that will directly explain the absorbance spectrum of glass or any other material, that such spectra can't be calculated analytically to begin with, and that explaining how to calculate an absorbance spectrum from first principles would require at least a book's worth of text.
I don't think anyone's going to write a textbook for you, so I'd suggest that you either accept a simplified, non-rigorous answer or don't ask.
28
{Well, a "high level physicist" should already know that there is no single equation that will directly explain the absorbance spectrum of glass or any other material, that such spectra can't be calculated analytically to begin with, and that explaining how to calculate an absorbance spectrum from first principles would require at least a book's worth of text.
I don't think anyone's going to write a textbook for you, so I'd suggest that you either accept a simplified, non-rigorous answer or don't ask. }
ok i said equations not equation , then you can simplify it i didnt say write it all
28
and it is easy to say that i dont know write ?
alxm
Fine, here's your equation:
[tex]\hat{H}\Psi = E\Psi[/tex]
Solve the electronic Schrödinger equation for the molecular Hamiltonian of whatever your type of glass is, with whatever its atomic coordinates are, using a unit cell and periodic boundary conditions because it's a solid.
After spending a day or two of supercomputer time figuring that out, note that the band gap is larger than the visual range, and that the thing therefore does not absorb visual light to any significant degree because there's no atomic/molecular transitions that correspond to that particular energy range.
28
thank you this is what i was talking about ....any one else [i know that eq, every one knows it]
28
no answer ??????
Related Threads on Why glass is transparent
  • Last Post
  • Last Post
  • Last Post
18K
  • Last Post
  • Last Post
