How do helicopters remain stable, despite the potential for tipping over?
  • Thread starter jostpuur
  • Tags
    Stable
In summary, the conversation discusses the stability of helicopters and how they are able to avoid tipping over. It is explained that the center of mass and rotor play a crucial role in keeping the helicopter stable. The concept of angular momentum is also mentioned, and it is suggested that the use of gyroscopes may contribute to the stability of helicopters. The conversation also touches on the topic of aircraft stability in general and how advancements in technology have allowed for more unstable designs. Additionally, the Sukhoi Su-47 Berkut, a forward swept wing aircraft, is mentioned as an example of this.
jostpuur
2,116
I just realized couple of days ago that I had never known why helicopters were stable, and avoided tipping over. When you look at a helicopter, it creates an intuitive impression that it is stable, because the center of mass is below the rotor. It seems as if it the helicopter's body is hanging from the rotor, so that if the helicopter was going to tip over, then it would do it about an axis which intersects the rotor, and because the center of mass is below the rotor, therefore the helicopter remains stable. This thinking is wrong, however. Objects which are in the air unsupported, always behave as if they were hanging from the center of mass. If they tip over, they will tip over about an axis that intersects the center of mass!
So if the rotor is not perfectly directed away from the center of mass, and a physical rotor will never be perfectly directed away from any point, the rotor's thrust will create a torque that tends to force the helicopter to tip over. So why are the helicopters so stable then?
I succeeded in coming up with one explanation, and it is that helicopters don't tip over easily for the same reason why spinning tops don't tip over. The rotor has lot of angular momentum in it, and it keeps the helicopter stable. If the helicopter would tip over, it would do it very slowly, like spinning tops fall very slowly too, and hence pilots have plenty of time to adjust the direction of the rotor.
I'm almost convinced that this gyroscope explanation is the right one, but there are some things which still bother me. There are also helicopters, whose rotors don't contain large angular momentum, because they have two rotors rotating in opposite directions. Like these ones:
http://en.wikipedia.org/wiki/File:Spanish_Army_Chinook.jpg
http://en.wikipedia.org/wiki/File:Kamov_Ka-50_MAKS_2005.jpg
Why are these helicopters stable too?
Helicotpers are (generally) unstable, you need to look at a stability analysis of the poles of the linearized dynamics on a root locus diagram.
Aircraft are also unstable in the lateral dynamics (sometimes also longitudinal), but the degree of instability makes it acceptable for piloting.
Do you remember when jets had wings swept back? That was done for better stability but at a cost in speed. Now, with military jets flown mainly by computers, some instability is acceptable for better performance and wings are swept forward.
Well, forward wingsweep is still very much at a NASA technology demonstrator stage. A lot of the X-29 data is still classified. But you are correct about stability augmentation systems (SAS).
I don't know of any forward swept wing aircraft in production.
Look in the first chapter or so of 'Chickenhawk' - by Robert Mason. It's about a pilot learning to fly helicopters for the Vietnam War. It describes, in a very graphic way, just how difficult it is to fly a manual helicopter. There are at least three controls, each of which affects the other two. It's more unstable than you could ever imagine; you change the tilt and that changes the lift which changes the heading so you correct for the lift and then you're turning in a direction you didn't want to go and find you're rising or falling and then . . . And I haven't even mentioned the precession problem.
Even helicopters with electronic control are not easy.
Again, you have to do a stability analysis looking at the poles on the root locus. Jostpuur, the question you are asking requires a graduate level understanding of helicopter dynamics. It's really not a simple answer.
If you really want to know, you need to get this book:
https://www.amazon.com/gp/product/1575242095/?tag=pfamazon01-20
That's right, there is significant coupling in the lateral and longitudinal dynamics.
Look at the Sukhoi Su-47 Berkut. It is a forward swept wing design and is the gnarliest looking airplane Sukhoi has come up with.
mkay?
Cyrus said:
mkay?
I saw forward swept wing and got excited. . .
Sexy.
The use of compressed nitrogen to increase control at high angles of attack is very interesting! I never knew about the VFC until today.
Not a production aircraft.
Role Technology Demonstrator
Manufacturer Sukhoi
First flight 25 September 1997
Introduced January 2000
Status Experimental
Primary user Russian Air Force
Number built 1
:wink:
Manufacturer Sukhoi
Status Experimental
Number built 1
:wink:
It reminds me of the Ferrari F250GTO. Le mans said they had to build at least 500 to be a production car and be allowed to race. Only 36 ever got built (clearly a violation of the rules), but are now worth millions.
If you look up military helicopter videos on YouTube, you will find a bunch of Russians bragging about how the Kamov Ka-50 helicopter is "superior" to the AH-64 Apache. It sounds very impressive until you realize that less than two dozen of them were ever built. The US has produced over 1100 Apaches.
Didn't know it needed to be production to be incredulously awesome.
Thank you for mentioning that book. I'll look for a copy. I flew fixed-wing about 35 years ago, but have become interested in choppers within the last few years (owing in large measure to Fred Garvin's input and my ex buying me a flight at a local airshow a couple of years ago). I'm pretty sure that I could get a simple one off of the ground and back down again, but I wouldn't want to try anything fancy like leaving my back yard.
By the bye, I applied to the US Air Force to go to Nam as a fighter pilot. Being a 17-year-old Canadian citizen who needed glasses, I was rejected. I'm disappointed that I never got my mitts on a Phantom, but more glad to still be alive. (And no, I did not understand the politics of the situation at the time. Once that became obvious, I was dead-set against the 'war'.)
https://www.youtube.com/watch?v=aVagmBvFLig
What a nice little toy!
What do that kind of toys actually contain inside them? Does it have a gyroscope and a small computer getting readings from it?
Can't some simple and rough deductions of stability be made without the detailed analysis?
A hinged rotor certainly looks like it contributes to stability in the same fashion dihedral does for aeroplane.
Edit: good grief, I didn't know this post was dated, but still...
Must be my fault...
I was thinking that I have right to return to my own thread whenever I want :smile:
Originally I didn't respond to Cyrus' posts frankly because I didn't know what poles and root locus are. I've tried to look about them a little bit on Wikipedia now... but this isn't very serious. I'm just spending my time.
No problem. It's still an open question.
1. Why do helicopters stay in the air?
Helicopters stay in the air due to the principle of lift, which is generated by the rotation of the helicopter's main rotor blades. This lift force is greater than the weight of the helicopter, allowing it to stay airborne.
2. How do helicopters maintain their stability?
Helicopters maintain their stability through a combination of design features and pilot control inputs. The main rotor system is designed to counteract the torque created by the engine and keep the helicopter level. Pilots also use cyclic and collective controls to make adjustments and maintain balance.
3. What makes helicopters more stable than other aircraft?
Helicopters have a unique design that allows for more stability compared to other aircraft. The ability to hover, combined with the use of a tail rotor to counteract the torque, helps to maintain stability. Additionally, the main rotor system provides more control and maneuverability than other aircraft.
4. Can helicopters fly in all weather conditions?
While helicopters are more versatile than fixed-wing aircraft, they still have limitations in certain weather conditions. Strong winds, fog, and low visibility can make flying a helicopter more challenging and potentially unsafe. Pilots must assess the weather conditions and make decisions based on safety precautions.
5. How do pilots control the stability of a helicopter?
Pilots control the stability of a helicopter through various control inputs. The cyclic control adjusts the angle of the rotor blades, allowing the helicopter to move in different directions. The collective control manages the lift force, while the directional pedals control the tail rotor. Pilots must constantly make adjustments to maintain the helicopter's stability in flight.
  • General Engineering
12K
  • Classical Physics
  • Classical Physics
  • Mechanics
