Why in the steady flow of a fluid, the fluid cannot move through the wall....?
In summary: This is because the wall is essentially a barrier that the molecule cannot pass through.In summary, the molecules of fluid in a flow tube have chaos movements, so they cannot move through the wall of the flow tube. This is because the wall is essentially a barrier that the molecule cannot pass through.
fxdung
388
23
Because of temperature, molecules of fluid have chaos movements.So I do not understand why in steady flow,the molecules of fluid can not move through the wall of flow tube?I think two layers of fluid exchange molecules while they move.How do we understand when saying: fluid can not move through the wall flow tube(made of flow lines) as every textbook saying?
It's the other way around.
fxdung said:
in steady flow
I suppose you refer to laminar flow of a continuous medium (*) in a cylindrical tube ?
If so, then:
From symmetry considerations there can not be flow in radial direction
(*) this term means you don't look at the individual molecules​
I think we must consider at the individual molecules,because if we dye(making color) some layers, then the color does not spread from one layer to another layer when they flow?Then it seem that two layers do not exchange the molecules.But it is impossible because molecules have chaos movement.
What is it you want to ask ?
Can you post a passage from your 'every textbook' that is confusing to you?
Mixing up molecular descriptions and continuous media descriptions might to be your hangup: of course they are linked, but properties like viscosity and diffusion constants are specifically meant for the latter.
And: yes, the origin of these phenomena is molecular.
Likes davenn
Now owe you I can clarify between the two descriptions.But please explain to me why the color of two layers of fluid do not mix while they still exchange molecules if they(two layers)move relative each other.
Who says they can’t and don’t?
I see in figure in the textbook that they flow separately,and the color don't mix?E.g fig 12.19, fig 12.20 page 379, University Physics of Young and Freedman ,14ed.
Is that correct that in short time we neglect the exchange molecules between layers comparing with the macro flowing?
Well, it takes time/distance for the diffusion to occur. But, it will occur.
Ah, found your flow tube fig 12.18. And as the author says:
The flow lines passing through the edge of an imaginary element of area, such​
as area A in Fig. 12.18, form a tube called a flow tube. From the definition of a​
flow line, in steady flow no fluid can cross the side walls of a given flow tube.​
So it's by definition. Thinking about a flow tube on a molecular scale seems pointless to me ( I grant you the authors of this book do not emphasize the difference between continuous media and 'ensembles of many molecules' -- they more or less bypass it, e.g. when discussing pressure).
Re diffusion: diffusion constants are usually very small. From school, I vividly :wink: remember a demo with a measuring cylinder filled with water with a lump of CuSO4 thrown in. It would take many days for the blue to move upwards in the cylinder.
So yes, it's correct we can neglect... as you say.
But, as Chet writes and you suspect, diffusion does take place...
You can see a more intuitive demo in this screenshot of an artist's technique. Of course the paint colors mix due to diffusion, but the paint dries before the mixing becomes visible.
If we are talking about lateral pressure between adjacent flow tubes then any diffusion across the boundary is irrelevant. The same momentum is transferred whether the molecules in the two flow tubes bounce off one another, pass silently past one another or bounce off an imaginary boundary between the tubes. Regardless of which description is used, the effect is that of a simple pressure between the tubes. One may as well adopt the simple, albeit non-physical, model of strict separation.
However, if the flows are at different velocities one wants to include the resulting shear force then the rate of diffusion enters in as viscosity.
A typical undergraduate textbook covering fluid mechanics is not generally considering flows of multiple fluids, i.e. they ignore diffusion. The question about dye here is effectively becoming more complicated due to this fact.
In a continuous medium, we ignore the action of individual molecules. This means that a fluid particle (which is not true physical particles but an abstraction that allows us to work with a continuum) cannot cross a streamline. By definition, a streamline is everywhere parallel to the velocity vector. This works because we ignore individual molecular motion. Those molecules can and do cross streamlines, but on average, the same number will be crossing in the opposite direction, so the continuum properties of the fluid particles don't change and we see no difference at that level of abstraction.
Now if you throw the dye part of the question into the mix, you need to consider whether diffusion is important. Food coloring in water is a diffusion-dominated problem, so you either have to consider the molecules (less common) or model that process based on a two-fluid continuum process (more common). On the other hand, if you have something like food coloring in corn syrup, diffusion is a much slower process and could often be ignored in most contexts. For example, see the video below where diffusion is so slow that the food coloring effectively stays in place and can be "unmixed."
Likes BvU
1. Why does the fluid not move through the wall in a steady flow?
In a steady flow, the velocity of the fluid is constant and there is no acceleration. This means that there is no net force acting on the fluid particles, so they are unable to move through the wall.
2. How does the wall prevent the fluid from moving through it?
The wall acts as a physical barrier that creates a boundary for the fluid. The molecules of the wall are tightly packed and do not allow the fluid particles to pass through them.
3. Can the fluid eventually move through the wall in a steady flow?
No, in a steady flow, the fluid particles follow a continuous path without any change in velocity. As long as the conditions remain the same, the fluid will not be able to move through the wall.
4. What happens to the fluid when it reaches the wall in a steady flow?
When the fluid reaches the wall, it exerts a force on the wall due to the collision of the fluid particles with the wall's surface. This force is equal and opposite to the force exerted by the wall, resulting in a balanced system.
5. Why is it important to understand why the fluid cannot move through the wall in a steady flow?
Understanding the behavior of fluids in steady flow is crucial in various engineering and scientific applications. It allows us to design structures and systems that can withstand the force of the fluid without any leakage or damage.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Thermodynamics
  • General Engineering
  • Classical Physics
