- #36
- 32,820
- 4,715
kote said:Huh? It's simple HUP. When particles have a defined location, they don't have a defined momentum... all that good stuff. I suppose I should clarify spin in a certain direction rather than just spin in general, but that's beside the point. Unless you are arguing that particles always have a defined spin in every direction, I don't see how you could disagree with the statement that some particles have undefined spin (in a given direction).
See http://arxiv.org/abs/quant-ph/0110102 for some published rigor on complementarity. Also http://arxiv.org/abs/quant-ph/9905042. As for particles in QFT: http://arxiv.org/abs/quant-ph/0103041. I don't claim to be a QFT expert, but I thought we were pretty set on HUP when it comes to particle properties, no? If it's about "essential properties," fine, that's a philosophical concept that my claim relies on. Hence the "so the argument goes" above.
I'd be happy to follow to the QM forum if you'd care to explain where I'm wrong here.
This is a common misunderstanding of the HUP.
If I have ONE particle, and I measure it's position to the precision that's allowed by my instrument, I can then determine its momentum with arbitrary precision, again, that's allowed by my instrument. The accuracy of each of those measurement, one after the other, has nothing to do with the HUP. This is NOT the HUP.
I've described an example of this using the single-slit example a few times. The HUP says nothing about the accuracy of one measurement of position and one measurement of momentum. The uncertainty in each of those measurement is the instrumentation uncertainty, not the HUP. So to say that "... particles have a defined location, they don't have a defined momentum... " is incorrect. Each of those particle can have well defined position and well-defined momentum. It is the spread in the values of the positions and the values of the momentum, measured under identical conditions, that is governed by the HUP. If the spread in the values of the position is small, then the spread in the values of the momentum will be big. This means that your ability to predict what the next value of the momentum is is not very accurate.
One needs to carefully look at the mathematical expression for the HUP. This is not some handwaving argument. It is deeply rooted (as is with the rest of physics) in some underlying mathematical description. And if one does that, one can see the statistical nature of the HUP.
Zz.
