Is the product of two hermitian matrices always hermitian?
  • I
  • Thread starter Happiness
  • Tags
    Hermitian
  • Featured
In summary, the conversation discusses the contradiction between the fact that the product of two Hermitian matrices is Hermitian only if they commute, and the case of ##p^4## not being Hermitian for hydrogen states with ##l=0## when ##p^2## is Hermitian. The discussion also touches on the implications of this for the hydrogen radial wave functions and their differentiability. It is concluded that while ##p^2## is approximately Hermitian, it is not exact, and the error function makes the difference in the case of ##p^4##.
Happiness
679
30
Why is ##p^4## not hermitian for hydrogen states with ##l=0## when ##p^2## is?
Doesn't this contradict the following theorem?
The product of two hermitian matrices, A and B, is hermitian if and only if they commute, AB=BA.
Likes atyy
Where have you read this? If ##p^2## is Hermitian, so is ##p^4##. I suspect that ##p## is a different one in the two cases.
Intro to QM, David Griffiths, p269
This is not very much context you give us. I read it as:
"We use Hermiticity of ##p^2##, although ##p^4## is not Hermitian ...",
i.e. he knowingly accepts an error in the specific ##l=0## case.
Yes, this is more or less an obvious fact. You could as well simply write:
\left(\overline{P}^\tau \right)^4=\left( \overline{P}^\tau \right)^2 \cdot\left( \overline{P}^\tau \right)^2 = \left( P^2 \right)^2 =P^4
##P^4## is Hermitian if ##P^2## is. The Hermiticity of ##P^2## has some implications which Griffith explains or wants you to solve. This does not include the ##l=0## case, since then ##P^4## is not Hermitian and neither can ##P^2## be in these specific states.
He is saying ##p^2## is hermitian but ##p^4## is not for the same pair of states, f and g, both with ##l=0##.
Mathematically we have: ##P^2## Hermitian ##\Longrightarrow \; P^4## Hermitian. So either he made a mistake, or ##P^2## isn't Hermitian in ##l=0## states, or ##P^4 \neq (P^2)^2##. I don't know what ##P^4## means, as ##P^2## doesn't look like a square either. What would be ##P## to get ##P^2= -\dfrac{\hbar^2}{r^2}\dfrac{d}{dr}\left( r^2\dfrac{d}{dr} \right)##?
##p## is the momentum operator as seen from [6.52].
##p^4=(p^2)^2## and ##p^2## is hermitian as seen from [6.51].
I actually find it weird to talk about “an operator is hermitian for these states”. I assumes it means ##\langle x|p y\rangle = \langle p x| y\rangle## for these states, but is that a standard nomenclature? In this case I think
fresh_42 said:
Mathematically we have: P2P2P^2 Hermitian ⟹P4⟹P4\Longrightarrow \; P^4 Hermitian.
is not obvious, since it applies to hermitian operators in the sense of the relation above holding for all states.
Well, the domain, i.e. where the operators are defined play an important role here. Only if they are all the same, then does the implication ##\overline{P}^\tau = P \Longrightarrow \overline{P^2}^\tau = P^2## hold.
In other words: Are the kets still differentiable such that ##P^4## can be applied?
Likes Demystifier
##p^2## is hermitian does indeed hold for all states, including ##l=0##, but not ##p^4##.
Yes they are since hydrogen radial wave functions all have the ##e^{-r}## term.
Hm, it is anyway only proven for ##\psi_n## scaling like ##\exp(-r)##, my point was that ##p^2 \psi_n## is not scaling like that anymore, so in ##\langle x,p^2 p^2 y\rangle## you can not even make use of this hermiticity for ##p^2##. Can you show your work for the boundary terms for ##p^4##? I do agree with Griffith they are not vanishing.
It is, because no matter how many times you differentiate ##e^{-r}##, multiplying and dividing by ##r^2##, in whatever order of these 3 operations, the result is still proportional to ##e^{-r}##.
It will always stay proportional to ##e^{-r}##, but you can have other terms depending on ##r## multiply that. Just do compute all terms in ##p^2 \psi_n## explicitly (you don’t really need all in the ##r\to 0## limit, but you must make sure to get the most important one).
Yes the boundary term does not vanish, indeed. But how can this be? All the hydrogen radial wave functions are infinitely differentiable. Doesn't it contradict the theorem?
Where did anything become not differentiable?
Post #7 explains it. We do not have exact Hermiticity, only approximately:
\langle f|p^2g \rangle = \underbrace{-c(r,n)}_{\approx 0} + \langle p^2f|g \rangle
whereas
\langle \psi_n|p^4\psi_m \rangle = \underbrace{d(n,m)}_{\not\approx 0} + \langle p^4\psi_n|\psi_m \rangle
So the error function makes the difference. Neither is Hermitian, but ##p^2## is approximately Hermitian.
I don’t understand this comment. What is your ##c(r)##?
Edit: If it is supposed to be the boundary term in #7: That is actually exactly 0. You have to evaluate the term at the boundaries, e.g. at 0 and infinity (or in the respective limits). There is no approximation involved.
Everything involved is always differentiable.
Taking ##f=\psi_{200}=(2-\frac{r}{a})e^{-r/2a}## and ignoring all constant factors,
$$r^2\frac{df}{dr}=(4r^2-\frac{r^3}{a})e^{-r/2a}$$
$$\frac{1}{r^2}\frac{d}{dr}r^2\frac{df}{dr}=(\frac{r}{a}-\frac{2}{a}+\frac{16}{r})e^{-r/2a}$$
fresh_42 said:
but ##p^2## is approximately ate ##r=0##.
c(r) has the factor ##r^2##, so it is exactly 0 at r=0.
Yes, I made a mistake and corrected the error terms, resp. the dependent parameters ##r,n,m##.
I'm not sure how to interpret ##r,n,m##, i.e. the integral since it isn't mentioned and I'm only a mathematician, who stumbled upon a seemingly contradiction in a standard textbook. However, with exact statements, this contradiction isn't one any longer. One error tends to or is zero, the other does not.
fresh_42 said:
One error tends to zero, the other does not.
All operators for observables must be hermitian. If ##\hat{p}^4## is not hermitian, then what would you obtain when you measure ##p^4## or ##E^2##? Would you get complex-valued measurements? What would it mean?
There is no “error tending to zero”. There are boundary terms that either are or are not exactly 0.
##p^2## is hermitian then. The contradiction still persists.
If it equals zero for ##p^2## and does not for ##p^4##, then ##p^4\neq (p^2)^2##, simple as that.
Likes Klystron and jim mcnamara
Does this mean that a measurement of ##p^2## is only approximately real valued? What does that even mean?
The question is: What is the value of ##\left.\left( r^2 f\dfrac{dg}{dr} - r^2g\dfrac{df}{dr} \right)\right|_0^\infty## for ##f=\psi_{n00}## and ##g=\psi_{m00}?##
For ##g=\psi_{100}## and ##f=\psi_{200}##,
##\left.\left( r^2 f\dfrac{dg}{dr} - r^2g\dfrac{df}{dr} \right)\right|_0^\infty=\left.\left(\frac{1}{8\sqrt{2}\pi a^5}r^3e^{-3r/2a}\right)\right|_0^\infty=0##, where ##a## is a constant.
  • #32
And if the expression in post #7 is correct, then we have ##\langle \psi_{100}|p^4\psi_{200}\rangle = c + \langle p^4\psi_{100}|\psi_{200}\rangle## with ##c\neq 0##. Hence ##p^4## isn't Hermitian, but ##\langle f|p^4g \rangle \neq \langle f|(p^2)^2g\rangle##, so ##p^4\neq (p^2)^2## on ##\psi_{n00}##.
And as in post #31, the domain matters!
  • #33
This is weird because I get the error expression for ##p^4## in post #7 by assuming ##p^4=(p^2)^2##.
Ignoring the constant factor ##-4\pi\hbar##,
##\langle f|p^2(p^2g) \rangle=\left.\left( r^2 f\dfrac{d(\hat{p}^2g)}{dr} - r^2\hat{p}^2g\dfrac{df}{dr} \right)\right|_0^\infty+\langle p^2f|p^2g \rangle=\left.\left( r^2 f\dfrac{d(\hat{p}^2g)}{dr} - r^2\hat{p}^2g\dfrac{df}{dr} \right)\right|_0^\infty+\left.\left( r^2 \hat{p}^2f\dfrac{dg}{dr} - r^2g\dfrac{d(\hat{p}^2f)}{dr} \right)\right|_0^\infty+\langle p^2p^2f|g \rangle##
The terms that don't vanish are ##\left.\left( r^2 f\dfrac{d(\hat{p}^2g)}{dr} \right)\right|_0^\infty## and ##\left.\left(r^2g\dfrac{d(\hat{p}^2f)}{dr} \right)\right|_0^\infty##.
  • #34
I see the first two equalities, but not your conclusion. Remember that ##\hat{p}^2f## means ##\hat{p}^2(f)##. So why should the two terms in the middle be zero?
Did you work with the approximations for ##\psi_{n00}## or do you have an exact expression?
  • #35
fresh_42 said:
If it equals zero for p2p2p^2 and does not for p4p4p^4, then p4≠(p2)2p4≠(p2)2p^4\neq (p^2)^2, simple as that.
What exactly do you mean by ##(p^2)^2##? I assumed ##p^4 f = p^2 p^2 f = p^2 (p^2 f)##.
Of course one would conclude from this that ##p^2## is not hermitian either (or only on some set that is not closed under its application, if that makes sense). So I am a bit confused myself.
Btw. I arrive at the same conclusion as @Happiness, just with the caveat that the notation is not really clear, the ##p^2## in the terms you complain about is only applied to the immediately following g/f.
  • Quantum Physics
  • Quantum Physics
14K
  • Linear and Abstract Algebra
  • Quantum Physics
