Why is the partition for Fermions a sum of Boltzman factors?
In summary, the partition function is a sum of probabilities of being in various states and is derived by plugging in the chemical potential to account for non-constant particle number. The factor e^-βE is motivated by reasoning that the probability of a particular split of energy is proportional to the number of ways to make that split, and is determined by a constant Z(β). In quantum physics, both the Boltzmann and Bose-Einstein distributions are correct and talk about different things, with the Boltzmann factor representing the probability of a quantum state and the Bose-Einstein factor representing the average number of particles with a certain momentum.
Philip Koeck
673
182
The partition function should essentially be the sum of probabilities of being in various states, I believe. Why is it then the sum of Boltzmann factors even for fermions and bosons? I've never seen a good motivation for this in literature.
I'll reformulate my question: To derive for example the FD distribution textbooks usually start with the partition function for the Boltzmann distribution with constant particle number, which is simply a sum of Boltzmann factors. Then the chemical potential is plugged into account for non-constant particle number. From this the FD-distribution is derived as the expectation value for the number of particles on each energy level.
How is this procedure motivated? Why would one even think of trying to derive the FD distribution from the Boltzmann distribution?
In general, let ##|k\rangle## be the complete set of Hamiltonian eigenstates, ##H|k\rangle=E_k|k\rangle##. The partition function is then
$$Z=\sum_k e^{-\beta E_k}$$
Now let us specify this for free particles. A single free particle with momentum ##{\bf p}## has energy ##E({\bf p})##. The basis of Hamiltonian eigenstates are all states of the form
$$|k\rangle=|n_1,{\bf p}_1;n_2,{\bf p}_2;\ldots\rangle$$
which denotes a state where ##n_1## particles have momentum ##{\bf p}_1##, ##n_2## particles have momentum ##{\bf p}_2##, etc. The energy of this state is
$$E_k=n_1E({\bf p}_1)+n_2E({\bf p}_2)+\ldots$$
so
$$e^{-\beta E_k}=e^{-\beta n_1E({\bf p}_1)} e^{-\beta n_2E({\bf p}_2)} \cdots$$
Hence the partition function is
$$Z=\sum_{n_1,n_2,\ldots} e^{-\beta n_1E({\bf p}_1)} e^{-\beta n_2E({\bf p}_2)} \cdots =
\sum_{n_1}e^{-\beta n_1E({\bf p}_1)} \sum_{n_2}e^{-\beta n_2E({\bf p}_2)} \cdots=
\prod_{{\bf p}} z({\bf p})$$
where
$$z({\bf p})=\sum_{n({\bf p})} e^{-\beta n({\bf p}) E({\bf p})}=\sum_{n} e^{-\beta nE({\bf p})}$$
Hence
$${\rm ln}Z=\sum_{{\bf p}}{\rm ln}\,z({\bf p})=V\int \frac{d^3p}{(2\pi)^3} {\rm ln}\,z({\bf p})$$
It remains to compute ##z({\bf p})##, which depends on whether particles are fermions or bosons. For fermions ##n=0,1## so
$$z_{\rm fer}({\bf p})=1+e^{-\beta E({\bf p})}$$
For bosons ##n=0,1,\ldots,\infty##, so
$$z_{\rm bos}({\bf p})=\sum_{n=0}^{\infty}(e^{-\beta E({\bf p})})^n=\frac{1}{1-e^{-\beta E({\bf p})}}$$
As you can see, in the first equation one has a Boltzmann-like expression which looks similar to that in classical physics. The Bose-Einstein or Fermi-Dirac factor emerges at the end of calculation from a sum over ##n##. I hope this answers your original question. The chemical potential can be added in a similar way, by changing the first equation as ##E_k\rightarrow E_k-\mu N_k##.
Likes Mentz114 and Philip Koeck
Here's a heuristic argument for why the factor ##e^{-\beta E}## comes into play:
Suppose that you have a system with discrete energy levels ##E_i##. It is kept at a constant temperature by keeping it in thermal contact with a "heat bath". A heat bath is a second system that is much larger than the system of interest, and has a much higher energy. (Imagine keeping the first system in a large reservoir of warm water, for example)
Because the first system is in thermal contact with the heat bath, it does not have a constant amount of energy, because it can exchange energy with the heat bath. So the energy of the first system becomes probabilistic. There is a certain probability ##P(E_i)## that the first system will be found to have energy ##E_i##. The question is, how to compute ##P(E_i)##.
A way to reason is this: Let ##W(E)## be the number of states of the heat bath that have energy ##E##. When the first system is placed into the heat bath, the total energy ##E## is divided between the small system and the heat bath, with ##\mathcal{E}## going to the small system, and ##E-\mathcal{E}## going to the heat bath. Then ##W(E - \mathcal{E})## is the number of ways to split up energy ##E## into two parts ##\mathcal{E}## and ##E - \mathcal{E}##. We assume that the probability of a particular split is proportional to the number of ways to make that split. That means mathematically that:
##P(\mathcal{E}) = K W(E - \mathcal{E})##
We compute the constant ##K## by making the probabilities add up to 1: ##\sum_i P(E_i) = 1##. So how do we compute ##W(E-\mathcal{E})##?
We use Boltzmann's definition of entropy of the heat bath: ##S = k log(W)## or in the exponential form, ##W = e^{S/k}##.
Then ##W(E-\mathcal{E}) = e^{S(E -\mathcal{E})/k}##
Now, assuming that ##\mathcal{E} \ll E##, we can expand ##S## in a taylor series and only keep the first couple of terms:
##S(E - \mathcal{E}) \approx S(E) - \frac{\partial S}{\partial E} \mathcal{E}##
A definition of temperature is that ##\frac{1}{T} \equiv \frac{\partial S}{\partial E}##. So we have:
##S(E - \mathcal{E}) \approx S(E) - \mathcal{E}/T##
Plugging this back into the formula for ##P(\mathcal{E})##, we get:
##P(\mathcal{E}) = K e^{(S(E) - \mathcal{E}/T)/k} = K e^{S/k - \beta \mathcal{E}}## where ##\beta = 1/(kT)##.
The factor ##e^{S}## is a constant, which can be absorbed into ##K##. So we have:
##P(\mathcal{E}) = K e^{-\beta \mathcal{E}}##
The constant ##K## is determined via: ##\sum_j e^{-\beta E_j} = \frac{1}{K}##. That's the choice that makes the probabilities add up to 1. If we define that sum to be ##Z(\beta)##, then we have:
##P(E_i) = Z^{-1} e^{-\beta E_i}##
Likes kith, dextercioby, Mentz114 and 2 others
In quantum physics of bosons, both Boltzmann and Bose-Einstein distributions are correct, because those two distributions talk about two different things. The Boltzmann factor ##e^{-\beta E_k}## is (proportional to) the probability of the quantum state ##|k\rangle##. The Bose-Einstein factor ##1/(e^{\beta E({\bf p})}-1)## is (proportional to) the average number of particles having the momentum ##{\bf p}##. Note that ##E_k## and ##E({\bf p})## are different quantities. Their relation is given in my previous post above.
Likes Philip Koeck
So the exponential term simply emerges from the assumption that a small system exchanges energy with a much larger heat bath, no matter what kind of statistics the small system obeys. Is that right?
Likes Demystifier
Yes, the statistics Fermi versus Bose only comes into play in computing how many different states there are.
If you have one-particle states with energies ##E_1, E_2, ...##, and you have ##N## particles (assumed non-interacting), then the possible many-particle states include
  • (for Bosons): For each ##j##, ##N_j = 0, 1, 2, ...## (where ##N_j## is the number of particles with energy ##E_j##)
  • (for Fermions): For each ##j##, ##N_j = 0, 1##
That's what @Demystifier was explaining.
There is a similar "heat-bath" type understanding of the chemical potential.
Instead of the system only exchanging energy with the environment, you can consider a situation in which it exchanges both energy and particles. In that case, the state of the system is characterized by a vector of numbers ##\vec{N}##, where ##N_i## is the number of particles in state ##i##.
If the total number of particles (system + environment) is ##N##, and the total energy is ##E##, then the energy and number of particles available to the environment is: ##E_{env} = E -\sum_i E_i N_i## and ##N_{env} = N - \sum_i N_i##. If you let ##W = e^{S/k}## be the number of possible states of the environment consistent with that energy and number of particles, then we can again do a Taylor series to get: ##W \approx e^{S(E,N)/k - \frac{\partial S}{\partial E} \sum_i E_i - \frac{\partial S}{\partial N} \sum_i N_i}##. By definition, ##\frac{\partial S}{\partial E} = \frac{1}{T}## and ##\frac{\partial S}{\partial N} = -\frac{\mu}{T}## where ##\mu## is the chemical potential. So we have:
##W = e^{S/k - \sum_i \beta E_i N_i + \sum_i \beta \mu N_i}##
(where ##\beta = \frac{1}{kT}##)
We can write this as: ##W = e^{S/k} \Pi_j (e^{-\beta (E_i - \mu)})^{N_i}##
The probability of having state ##\vec{N}## is then given by:
##P(\vec{N}) = (Z(\beta, \mu))^{-1} \Pi_i (z_i)^{N_i}##
where ##z_i = e^{-\beta (E_i -\mu) N_i}## and where
##Z(\beta, \mu) = \sum_{N_1, N_2, ...} \Pi_i (z_i)^{N_i}##
which can be rearranged into
##Z(\beta, \mu) = \Pi_i (\sum_{N_i} (z_i)^{N_i})##
##\mu## accounts for fluctuating numbers of particles in the same way the ##\beta = \frac{1}{kT}## accounts for fluctuating amounts of energy.
Likes dextercioby
Sorry for taking up this thread again after such a long time.
I still have conceptual problems with the canonical distribution (Boltzmann factor).
I'm thinking of a large system, such as an ideal gas, that is isolated from the surroundings.
The number of particles is fixed and the total energy is also constant.
The energy levels could be continuous like in an ideal gas or one could imagine a discrete set of available energies.
If I now pick out one particle as a very small system and treat the rest of the gas (or whatever it is) as a heat bath just like in the posts by @stevendaryl, my impression is that I'm making two implicit assumptions:
1. I can distinguish the particles.
2. The particle I designated as the small system can populate any energy level, even one that is already occupied by a particle belonging to the heat bath.
The second assumption is only a problem for systems with discrete energies, as I see it.
Anyway, it seems to me that the canonical ensemble implicitly assumes distinguishable bosons.
To my way of thinking this is problematic if the canonical distribution is then used to construct a partition function that is used to derive state functions and distributions for indistinguishable particles, both bosonic and fermionic.
It looks to me like the initial assumptions are being ignored.
Just for clarification, the discussion that I gave about "heat baths" is just a way to motivate the Boltzmann distribution. It's not intended to be rigorous.
Second, in the discussion, it's not the particles that are distinguished, but entire subsystems. If you have a closed container filled with water, and that container is sitting in a large pool of water, you can distinguish between the two quantities of water, even though you can't distinguish two water molecules.
If you have a system with many indistinguishable particles, then as a first approximation, people often ignore the interaction between the particles. In a certain sense, this is inconsistent, because noninteracting particles will not reach thermal equilibrium (since equilibrium is reached by exchanging energy, which means interacting).
So once again, you have two subsystems, the system of interest and the heat bath. The only thing that is important about the heat bath is that it has a huge number of states associated with each energy (which is necessary for it to have a well-defined temperature).
Likes Philip Koeck
I'm cautiously trying to come to grips with these concepts. Thanks for the help.
So the small system should never be viewed as a single atom or molecule.
Well, there are the two different types of ensemble, one of which allows the interchange of energy between the system and the "heat bath", and the other of which allows the interchange of both energy and particles. The second type doesn't make sense for a single particle, but the first does. But the point is that the total state of the entire system can be factored into the state of the "heat bath" and the state of the system of interest. If the single atom is somehow isolated from other similar atoms, but is able to emit and absorb energy, then I think you can treat it thermodynamically.
I would suggest to first consider something simpler. Imagine that you have two hydrogen atoms in the ground state, one atom on Earth and one atom on the Moon.
1. Can you distinguish those two atoms? What is the wave function for that system of two atoms?
2. Since both atoms are in the ground state, do they populate the same energy level?
Are you saying that the heat bath has low occupancy?
If the small system is just a part of the whole large system, then I would expect it to also have low occupancy.
That would mean the Boltzmann distribution is only valid in the low occupancy case.
Then it's still strange that the partition function constructed from Boltzmann factors can be used to derive the FD and BE distribution.
Let's take the grandcanonical statistical ensemble. Information theory tells us to find the state of maximum entropy under the constraints, i.e., (a) normalization, (b) value of the mean total energy and (c) value of the mean total particle number, leading to
$$\hat{\rho}=\frac{1}{Z} \exp(-\beta \hat{H}+\beta \mu \hat{N}).$$
The partition sum is
$$Z=\mathrm{Tr} \hat{\rho}.$$
Now take a finite cubic volume of length ##L## with periodic boundary conditions (to have a properly defined single-particle momentum) and a free gas. The Hamiltonian reads
$$\hat{H}=-\frac{1}{2m} \hat{\psi}^{\dagger} \Delta \hat{\psi} = \sum_{\vec{p}} \frac{\vec{p}^2}{2m} \hat{a}^{\dagger} (\vec{p}) \hat{a}(\vec{p}),$$
where the ##\hat{a}## are fermionic annihilation operators for momentum eigenstates (for convenience I leave out spin, which can easily be added later). The occupation numbers of ##\hat{N}(\vec{p})=\hat{a}^{\dagger}(\vec{p}) \hat{a}(\vec{p})## are a complete set of observables, and the eigenvalues are ##N(\vec{p}) \in \{0,1 \}## for each ##\vec{p}##. The partion Sum thus is
$$Z=\prod_{\vec{p}} \sum_{N(\vec{p})=0}^{1} \exp[-\beta \hat{N}(\vec{p}) (\vec{p}^2/(2m)-\mu)] = \prod_{\vec{p}} [1+\exp[-\beta (\vec{p}^2/(2m)-\mu)]].$$
Now you can make ##\alpha=\mu \beta## formaly dependent on ##\vec{p}##, and the mean number of particles with momentum ##\vec{p}|## is then given by
$$\langle N \rangle=\frac{\partial}{\partial \alpha(\vec{p})} = \frac{\exp[-\beta(\vec{p}^2/(2m)-\mu)]}{1+\exp[-\beta (\vec{p}^2/(2m)-\mu)]}=\frac{1}{\exp[\beta(\vec{p}^2/(2m)-\mu)]+1},$$
which is the Fermi-Dirac distribution, as it should be.
For bosons everything goes through precisely the same. The only difference is that you have to sum for each ##N(\vec{p})## over all ##\mathbb{N}_0##. Of course this results in the Bose-Einstein distribution function.
There is no need to assume anything about the small system along those lines.
The Boltzmann distribution describes the environment (heat bath), not the small system.
The reasoning doesn't distinguish between bosons or fermions or distinguishable particles. Those distinctions go into computing ##W(N,E)##, the number of states with a given energy and number of particles. For distinguishable particles, swapping two particles results in a different state,while for bosons and fermions, it doesn't.
The following argument is semiclassical, in that it uses discrete energy levels and indistinguishability, but does not use operators as in @vanhees71.
What you do need is for the number of states for two subsystems to be multiplicative. Assume that you have one large system, the heat bath, with ##W_B(N,E)## giving the number of states for a given number of particles and total energy.
You have another system, the system of interest, with its own function ##W_1(N_1, \varepsilon)##. Then the assumption is that the number of states ##W(N,E)## for the combined system is related to these two in the following way:
##W(N,E) = \sum_\varepsilon \sum_{N_1} W_1(N_1,\varepsilon) W_B(N-N_1, E - \varepsilon)##
Now, you assume that ##W_B## is huge compared with ##W_1##, so most of the particles and most of the energy will be with the heat bath, rather than the system of interest. Under this assumption, we can approximate: ##W_B(N-N_1, E - \varepsilon) \approx W_B(N,E) e^{-\beta (\varepsilon - \mu N_1)}##, where ##\beta = \frac{\partial S_B}{\partial E}/k## and ##\beta \mu = \frac{\partial S_B}{\partial N}/k##.
Then we have:
##W(N,E) = W_B(N,E) \sum_\varepsilon \sum_{N_1} e^{- \beta(\varepsilon - \mu N_1)} W_1(N_1,\varepsilon) ##
At this point, no assumption whatsoever is being made about the nature of the small system, other than the fact that it is much smaller than the heat bath. To go further and see where the statistics come into play, let's assume that the small system contains a number of identical particles that will be approximated as non-interacting. Then the many-particle states can be obtained from the single-particle states. Assume that a single particle has a discrete set of states, with energies ##e_1, e_2, ...##. Then the multiparticle state is specified by simply giving ##n_1, n_2, ...## where ##n_j## is the number of particles in state ##j##. The indistinguishability comes into play by the fact that we don't consider two states to be different if you swap two particles, because that leaves the numbers ##n_j## unchanged. For Fermions, each ##n_j## can have value 0 or 1. For Bosons, ##n_j## can be any nonnegative integer.
Given these assumptions, we can compute ##W_1(N_1, \varepsilon)## as follows:
##W_1(N_1, \varepsilon) = \sum_{n_1, n_2, n_3, ...} \Delta(\varepsilon - n_1 e_1 - n_2 e_2 - ...) \Delta(N_1 - n_1 - n_2 - ...)##
where ##\Delta(X)## is a function that is equal to 1 if ##X=0## and is equal to 0 otherwise. (That's actually the Kronecker delta, but I don't want to get the notion mixed up with the Diract delta function). In other words, ##W_1(N_1, \varepsilon)## is just counting the number of states with the correct number of particles and total energy. In terms of this expression, we can now rewrite our general expression above:
##W(N,E) = W_B(N,E) \sum_\varepsilon \sum_{N_1} \sum_{n_1, n_2, ...} e^{- \beta(\varepsilon - \mu N_1)} \Delta(E - n_1 e_1 - n_2 e_2 - ...) \Delta(N_1 - n_1 - n_2 - ...)##
Because of the presence of the ##\Delta##s, the quantity being summed is zero unless ##\varepsilon = n_1 e_1 + n_2 e_2 + ...## and ##N_1 = n_1 + n_2 + ...##. So we can replace ##\varepsilon## and ##N_1## in the exponential by those sums without changing the value of the whole expression:
##W(N,E) = W_B(N,E) \sum_\varepsilon \sum_{N_1} \sum_{n_1, n_2, ...} e^{- \beta(n_1 e_1 + n_2 e_2 + ... - \mu n_1 - \mu n_2 - ...)} \Delta(E - n_1 e_1 - n_2 e_2 - ...) \Delta(N_1 - n_1 - n_2 - ...)##
Now, since the exponential no longer involves ##\varepsilon## or ##N_1##, we can reorder the sums (assuming everything is absolutely convergent, anyway):
##W(N,E) = W_B(N,E) \sum_{n_1, n_2, ...} e^{- \beta(n_1 e_1 + n_2 e_2 - \mu n_1 - \mu n_2 - ...)} \sum_\varepsilon \sum_{N_1} \Delta(E - n_1 e_1 - n_2 e_2 - ...) \Delta(N_1 - n_1 - n_2 - ...)##
The innermost sum is just ##\sum_\varepsilon \sum_{N_1} \Delta(E - n_1 e_1 - n_2 e_2 - ...) \Delta(N_1 - n_1 - n_2 - ...)##. The only nonzero term is the one where ##N_1 = n_1 + ...## and ##\varepsilon = n_1 e_1 + n_2 e_2 + ...##. There is only one value making this true, so the sum just yields 1. So we get a huge simplification:
##W(N,E) = W_B(N,E) \sum_{n_1, n_2, ...} e^{- \beta(n_1 e_1 + n_2 e_2 + ... - \mu n_1 - \mu n_2 - ...)} ##
We can write this in a more tidy way:
##\sum_{n_1, n_2, ...} e^{-\beta(n_1 e_1 + n_2 e_2 + ... - \mu n_1 - \mu n_2 ..)} = \Pi_j \ [ \sum_{n} e^{-\beta n (e_j - \mu)}]##
So we just get: ##W(N,E) = W_B(N,E) \Pi_j Z_j(\beta,\mu)##
where ##Z_j(\beta, \mu) = \sum_n e^{-\beta n (e_j - \mu)}##. As mentioned earlier, for Fermions, ##n = 0## or ##n=1##. So ##Z_j(\beta,\mu) = 1 + e^{-\beta(e_j - \mu)}##. For Bosons, ##n= 0, 1,2,...## so the sum gives ##Z_j(\beta,\mu) = 1 + e^{-\beta(e_j - \mu)} + e^{-2\beta (e_j - \mu)} + ... = \frac{1}{1-e^{-\beta(e_j - \mu)}}##
Taking the natural log of both sides gives:
##S(N, E) = S_B(N,E) + \sum_j log(Z_j(\beta, \mu))##
This shows an amazing, or maybe not so amazing, result, which is that if the particles are non-interacting, then each single-particle state ##j## makes its own independent contribution to the total entropy, ##log(Z_j(\beta, \mu))##.
Likes Philip Koeck and vanhees71
I really liked the derivation in your latest post. (I also like @vanhees71 posts but I need some more background in QM to follow them completely, I'm afraid.)
There's one thing that still doesn't quite click. I believe you say that the heat bath has low occupancy in the quote above. Somewhere else you also say that the Boltzmann distribution applies to the heat bath (it's proportional to the probability distribution for the heat bath). At some point, however, we end up with a probability distribution for the small system, which doesn't necessarily have low occupancy. Where does the derivation switch from talking about the heat bath to talking about the system?
The Boltzmann distribution applies to bosons as well of fermions, if the "typical states" are populated by less than 1 particle on average, i.e., if
$$\frac{1}{\exp[\beta(E-\mu)] \pm 1} \simeq \exp[-\beta(E-\mu)] \quad \text{i.e., if} \quad \exp[\beta(E-\mu)] \gg 1, \quad E-\mu \gg k_{\text{B}} T.$$
This is plausible, because if there's only less than one particle in per phase-space cell of size ##(2 \pi \hbar)^3##, then the indistinguishability of quantum physics can be neglected, i.e., Pauli blocking and Bose enhancement are unimportant.
Likes Philip Koeck
So, again, the number of states for the composite system is:
##\sum_{\varepsilon, N_1} W_B(E-\varepsilon, N-N_1) W(\varepsilon, N_1)##
where ##W_B## refers to the heat bath, and ##W## is the small system. So out of the total energy ##E##, some small amount ##\varepsilon## goes to the small system, and the rest stays with the heat bath. Out of the total number of particles ##N##, some small number ##N_1## goes to the small system. To get all possibilities, you sum over all possible values of ##\varepsilon## and ##N_1##. (Strictly speaking, you should just consider ##N_1 < N## and ##\varepsilon < E##, but that doesn't make much difference.)
My point about the heat bath is that the factor ##e^{-\beta(\varepsilon - \mu N_1)}## comes from approximating ##W_B##, not from any properties of the small system. Defining ##S_B = k log W_B##, we have ##S_B(E - \varepsilon, N - N_1) \approx S_B(E, N) - \varepsilon \frac{\partial S_B}{\partial E} - N_1 \frac{\partial S_B}{\partial N}##. By definition, ##\frac{\partial S_B}{\partial E} = \frac{1}{T}##. That's the thermodynamic definition of temperature. By definition, ##\frac{\partial S_B}{\partial N} = - \frac{\mu}{T}##. That's the definition of chemical potential ##\mu## (I'm not sure why is wasn't defined to be just ##\frac{\partial S}{\partial N}##, but presumably it's more convenient to have the ##T## and minus sign in there.) ##\beta = \frac{1}{kT}## is more convenient to use than ##T##, so we can write ##S_B(E-\varepsilon, N- N-1) \approx S_B(E,N) - k \beta \varepsilon + k N_1 \beta \mu##
So given the temperature and chemical potential of the heat bath, we can approximate ##W_B(E-\varepsilon, N-N_1)## as:
##W_B(E-\varepsilon, N-N_1) = e^{S_B(E-\varepsilon, N-N-1)/k} \approx e^{S_B(E,N)/k - \beta (\varepsilon - \mu N_1)}##
This is a fact solely about the heat bath. The properties of the small system are irrelevant. So we have the approximation (where ##W_C## means composite number of states)
##W_C(E,N) \approx e^{S_B(E-\varepsilon, N-N-1)/k} \sum_{\varepsilon, N_1} e^{-\beta (\varepsilon - \mu N)} W(\varepsilon, N_1)##
So in this expression, ##W(\varepsilon, N_1)## is the number of states of the smaller system as a function of energy and number of particles. We haven't made any assumption at all (yet) about this function. We haven't said that it's bosons or fermions or low or high occupancy. We haven't made any assumptions at all. Except that we're assuming that typically ##W \ll W_B##, that the heat bath has lots more states, compared with the small system.
So the factor ##e^{-\beta (\varepsilon - \mu N)}## does not come from any properties of the small system. It comes from approximating ##W_B##. So ##\beta## and ##\mu## are properties of the large system.
Likes vanhees71 and Philip Koeck
Does that mean that temperature and chemical potential are only defined for a large system with low occupancy?
So for a system that obeys FD or BE statistics the chemical potential and temperature in the distribution function have nothing to do with the system. They only refer to the surrounding heat bath.
Of course, temperature and chemical potential have the same meaning in classical and quantum statistics. They come into the game as Lagrange multipliers to impose the constraints of given average total center-momentum energy and particle number (or more generally conserved charges) in the maximum-entropy principle.
Likes Philip Koeck
Yes, I would say so. You can't talk about the temperature of a single atom. But if that atom is interacting with a "bath" of photons, the bath can have a temperature, and their temperature affects the probability that the atom will be in this state versus that state.
Yes. Although if you have two (or more) large systems that are interacting, at equilibrium, their temperatures and chemical potentials will be equal.
Likes Philip Koeck
It's interesting. You get the same answer (the Boltzmann distribution) in two ways:
  1. You maximize the entropy of the small system subject to the constraint that the average energy and average number of particles are fixed values ##\langle \varepsilon \rangle## and ##\langle N_1 \rangle##. Then the temperature and chemical potential arise as Lagrange multipliers.
  2. You imagine the small system to be sharing energy and particles with a much larger environment. Then the temperature and chemical potential arise as thermodynamic properties of the environment.
You get the same probability distribution in the two cases, but conceptually, they seem very different.
Here are derivations (appended as a pdf, I hope) I mentioned to @stevendaryl in a message. I don't know how to append to a message so I'm sending the file here in the thread. The approach is quite different from the canonical one and the chemical potential makes the particle number constant, not variable.
  • distributions.pdf
In fact they are not different, because both lead to the maximum-entropy principle. The only difference between the classical distribution and the quantum distributions (either bosons or fermions in ##\geq 3## space dimensions or also possibly anyons in 2 space dimensions) comes about the counting of microstates and thus the particular expression for entropy. Of course, nobody has a fully classical answer since it has to be repaired by hand by (a) introducing and arbitrary unit for phase-space volumes (which in QT turns out to be ##h^{3N}=(2 \pi \hbar)^{3N}## for ##N## particles (modulo degeneracy factors from internal degrees of freedom like spin, flavor, color, etc) and (b) the indistinguishability of particles to repair the Gibbs paradox.
For a treatment, not using QFT (which is of course the most straight-forward way, given you have already learned QFT in the first place), but simple stochastics arguments, see Landau&Lifshitz vol. V or my transport lectures:
https://th.physik.uni-frankfurt.de/~hees/publ/kolkata.pdf
A marvelous undergraduate-level text, which uses your arguments and also makes the connection to entropy (in the traditional non-information theoretical approach) is the Berkely Phsics Course, Statistical Mechanics volume, written by F. Reiff.
A more modern excellent text, using information theory (imho the only approach which leads to a real understanding of the meaning of entropy, as is shown by recent experimental realizations in nano-physics, where among other things, the old resolutions of the Maxwell Demon paradox by Szilard and Landauer are empirically verified on the quantum level) is
J. Rau, Statistical Physics and Thermodynamics, Oxford University Press (2017)
I have to get hold of both Reiff and Rau it seems. ( and learn QFT)
When you say Rau "uses your arguments", are you referring to the canonical approach that @stevendaryl gave, or what I wrote in my pdf?
In any case I'd like to point out a few things in my text.
I never distinguish between a system and a heat bath, I just have one system and determine the distrubution among energy levels that can be realized in the most ways (maximizes entropy).
I assume indistinguishability from the beginning and show that you get the FD or BE distribution in general and correct Boltzmann counting and the Boltzmannn distribution for low occupancy. So there's no need to plug in indistinguishability "as an afterthought".
The lagrange multipliers are interepreted using classical thermodynamics without chosing a specific system.
Just like you say I run into difficulties when I start applying the general results to a specific system, such as an ideal gas.
To determine the density of states (g) I have to assume that phase space consists of small units of suspiciously quantum-mechanical size.
To determine an expression for the chemical potential I haven't found a way around using the partition function, which results from the canonical derivation but not really from mine. At least I haven't worked out how.
I do find it interesting that the chemical potential plays such different roles in my derivation and the canonical one.
Do you know where my derivation method comes from? I got it from a book by Arthur Beiser, but does it go back to Boltzmann by any chance? Or is the canonical approach the "original"?
It's easy to see, that the partition sum (or rather its log) plays the role of a thermodynamic potential (the Landau potential). You start from the defining formula
$$Z=\mathrm{Tr} \exp[-\beta \hat{H}+\alpha \hat{N})].$$
Then you get
$$\partial_{T} \ln Z=-\frac{1}{Z} \mathrm{Tr} \hat{H} \exp(\ldots)=-\langle H \rangle=U$$
and
$$\partial_{\alpha} \ln Z=-\frac{1}{Z} \mathrm{Tr} \hat{N} \exp(\ldots)=-\langle N \rangle=\mathcal{N}.$$
The only point is that usually in thermodynamics one uses the chemical potential rather than ##\alpha##, but that's easily solved, because obviously
$$\alpha=\beta \mu.$$
Likes Philip Koeck
1. Why is the partition for Fermions a sum of Boltzmann factors?
The partition function is a key concept in statistical mechanics that helps us calculate the thermodynamic properties of a system. For fermions, which are particles with half-integer spin, the partition function is a sum of Boltzmann factors because fermions follow Fermi-Dirac statistics, which describe the behavior of particles with half-integer spin. These statistics dictate that fermions cannot occupy the same quantum state, leading to the use of the Boltzmann factor in the partition function.
2. What does the Boltzmann factor represent in the partition function for Fermions?
The Boltzmann factor, also known as the exponential factor, is a mathematical term that represents the probability of a particle occupying a particular energy state. In the partition function for fermions, the Boltzmann factor is used to account for the exclusion principle, which states that no two fermions can occupy the same quantum state at the same time.
3. How does the Boltzmann factor affect the partition function for Fermions?
The Boltzmann factor plays a crucial role in determining the total energy and other thermodynamic properties of a fermion system. It affects the partition function by accounting for the exclusion principle and ensuring that the probability of two fermions occupying the same quantum state is always zero. This leads to a different form of the partition function compared to that for bosons, which follow Bose-Einstein statistics and do not have the exclusion principle.
4. Can the partition function for Fermions be derived from first principles?
Yes, the partition function for fermions can be derived from first principles using statistical mechanics and the fundamental principles of quantum mechanics. The derivation involves considering all possible energy states and their corresponding probabilities, taking into account the exclusion principle and the Boltzmann factor. This results in the partition function for fermions being a sum of Boltzmann factors for each energy state.
5. Why is the partition function for Fermions important in understanding the behavior of quantum systems?
The partition function is a fundamental concept in statistical mechanics that allows us to calculate various thermodynamic properties of a system. For fermions, the partition function is particularly important as it takes into account the exclusion principle, which governs the behavior of particles with half-integer spin. Understanding the partition function for fermions is crucial in understanding the behavior of quantum systems, such as atoms and electrons, which obey Fermi-Dirac statistics.
  • Quantum Physics
  • Thermodynamics
  • Quantum Physics
  • STEM Academic Advising
