Why is the Sky Blue? Understanding Rayleigh Scattering and Atmospheric Particles
  • Thread starter jennyjones
  • Tags
    Sky
In summary, the sky appears paler near the horizon because the blue light is scattered more than the other colors.
jennyjones
35
I was practicing for my upcoming optics exams, by making an old exam.
And got stuck on some problems that seem so silly.
1. Why is the sky blue?
My answer:
To answer this problem I first need to mention Rayleigh Scattering, a form of scattering which has a very large wavelength dependance. Only light with a wave length that is about 10% of the size of the particle gets scattered.
White light from the sun must travel trough the atmosphere, the atmosphere contains lots of particles.
Most of these are very small, so only the blue and violet rays from the sunlight can get scattered on these molecules. This scattering from the blue waves, makes the sky almost everywhere you look seem blue.
(This how i would explain it. Does anyone know if this is correct/complete?)
2. Why is the sky near the horizon white/pale?
My answer:
If you look at the sky near the horizon, you are looking through way more atmosphere than when you are looking at the sky above you. particles are scattered multiple times, eventually reds and greens get almost as strong as blue, that's why sky is whiter?
(not sure why and if this is true? why do green and red eventually get as strong as blues? why does it matter if light scatters multiple times?)
i'm especially stuck on 2, not sure why the sky is whiter near the horizon.
thanks,
jenny
I think your explanation is OK.
Why is the sky red at sunset time?
Likes 1 person
Have you tried putting that into a search engine?
sure i have
this is something i found
As you look closer to the horizon, the sky appears much paler in color. To reach you, the scattered blue light must pass through more air. Some of it gets scattered away again in other directions. Less blue light reaches your eyes. The color of the sky near the horizon appears paler or white.
source:http://www.sciencemadesimple.com/sky_blue.html
but still don't get it, sorry
i would think that this would make the sky appear more reddish, since less blue is reaching your eye
I think i get this problem:
if the sun is going down it has to pass trough a thicker layer of atmosphere.
The blue light is almost scattered 'out' when it reaches our eyes, while the green and the red are not yet.
The most red is left(longest wavelength), so the sky appears reddish.
(a mix of mostly red, little green, very little blue)
ahhww, maybe this is not explained to good. Do you know if this is ok?
Google comes up with more complex explanations than that one.
That is a good explanation of why the disc of the sun appears red. But it falls short of explaining why the sky appears reddish. (Because, I think you'll agree, this looks like the same explanation for why the sky appears blue!)
Likes 1 person
thanx, but why then does it appear reddish?
yes, i know but the problem is that i still don't really get why the sky is paler near the horizon!
i don't see how a thicker layer of atmosphere makes the light appear white.
then light has to travel longer trough the atmosphere, so the blue light is almost scattered out, and red and green not? so i would assume here also the sky is reddish. I don't get the difference between sunset and the horizon problems.
From what I remember from waves last semester, scattering is proportional to λ-4 so when the sun is glaring at you from a near 45 degree angle between the horizon, the scattering goes through enough particles so that only we only see the blue light since it has a small wavelength (or violet really, from what I understand our eyes normalize violet to blue because it's easier for them). During sunset, the sun is on the horizon so that path it has to take to get to our eyes is a lot smaller and it passes through a lot less particles. Because of that, the effect of the scattering is decreased and we see orange and red.
The reason we see a paler sky near the horizon is because there is less scattering so more wavelengths are able to be seen. Thus white light.
Likes 1 person
The distance through the atmosphere is a minimum when the sun is overhead; it is a maximum when the sun is at the horizon. Draw a picture - not to scale - and convince yourself.
Also - Rayleigh scattering is not the only factor at sunset/sunrise - Mie scattering is also important because of the presence of dust/aerosols in the troposphere - these are minimized when you look directly overhead, but are maximized for a view at the horizon. Revise your earlier drawing to show the troposphere and stratosphere - just for the two views, and make it to proper scale.
Likes 1 person
So the only way that makes sense then is if scattering makes wavelengths less visible, right? Highly scattered wavelengths are more prominent than less scattered ones? Red is seen at sunset because the blue light is scattered and we don't see it? I just had it completely reversed then right? lol. I had a feeling that was the case, that's why I tried to answer.
When the sky looks white anywhere it is just an issue of low transparency due to high humidity.
The light which you "see" which carries an image - of the moon, a blade of grass, etc., is coming directly from that "object", subject only to reflections and refractions.
Scattered light appears to be coming from "everywhere" within its scattering domain - hence the sun (which is white) appears yellow during the day because the blue is preferentially scattered ... and the sky appears blue during the day because the blue light is scattered "everywhere".
At night the sky is clear - no more blue!
When tiny water droplets are present the sky appears white - all of the light is being scattered, and we call this fog or clouds depending upon how close to the ground it is.
As the sunset approaches the sun slowly changes color as more and more wavelengths are scattered. If you live on the coast you can see these effects clearly along the horizon.
If you are patient, and perhaps lucky, you can even see the "green flash": http://mintaka.sdsu.edu/GF/
I've only seen it once, during a sunset in Florida.
As russ_waters said, the white color of horizon is caused bu humidity, dust and other particles in the atmosphere. The sky looks red on the sunset/sunrise because of the red light from Sun reflecting from the dust particles. That's all.
Likes 1 person
One thing you might want to consider is the human eye response.
In other words, why the sky looks blue rather than purple or UV!
Claude.
A complete explanation of the sky's color requires you solve the hard problem of consciousness...
Oh do behave. :biggrin:
If most people agree that the colour they can see is the same and they choose to call it 'Blue', then that is the 'colour' we are discussing. But a better term might be 'blueish' or 'very pale blue'. If you want to draw a set of spectra out instead of using the well known colours for this thread then you are welcome to. It could be done without the subjective appreciation of colour being mentioned at all but, afaiac, that would be a bit of a waste of effort.
If you want to start a thread about Colourimetry then go ahead. You will find a mixture opinions and levels of knowledge and it could be fun.
if you're going to try to say something edgy you should at least put down the argument though...
My answer:
My answer:
thanks,
jenny
Others have addressed the technical points, but I will comment on your writing style. Technical writing (even practicing on this forum) should be less conversational and more concise. Precisely what wavelength depedence? How much more? Consider your word choices carefully as you write throughout your science education.
ZF
ZF
ZF has a point there. When examiners mark a paper, they work to a mark scheme and can sometimes miss key words which may be lost inside flowery sentences. Or you may even try to use pretty synonyms and metaphors which will not gain the marks because the mark scheme does not include those actual words. People who do Humanities (etc.) exams will prepare specific, long word for word, answers to possible questions. Not what's needed in Science but I always told students to learn and use the expressions and phrases they would find in their textbook - or prepare their own descriptive phrases in advance. (This will guarantee a better understanding, in any case) You can be sure of finding a number of stock questions which call for some appropriately worded sentences. Be ready for them.
The sky appears blue because of a phenomenon called Rayleigh scattering. This is when sunlight enters Earth's atmosphere and interacts with particles in the air, such as nitrogen and oxygen molecules. These particles scatter the sunlight in all directions, but blue light is scattered more than other colors because it has a shorter wavelength. This scattered blue light is what we see when we look up at the sky.
2. What causes Rayleigh scattering?
Rayleigh scattering occurs when light enters a medium with particles that are smaller than the wavelength of the light. In the case of the sky, the particles in the atmosphere (such as air molecules) are much smaller than the wavelength of visible light, which causes the light to scatter.
3. Does the sky always appear blue?
No, the color of the sky can change depending on various factors. For example, at sunset or sunrise, the sky can appear orange or red because the sunlight has to travel through more of Earth's atmosphere, causing more scattering of longer-wavelength colors. Additionally, pollution and other atmospheric particles can also affect the color of the sky.
4. Is the blue color of the sky the same everywhere on Earth?
No, the blue color of the sky can vary depending on location and time of day. For example, the sky may appear lighter or darker shades of blue in different parts of the world due to variations in atmospheric conditions and the angle of the sunlight. The blue color may also change throughout the day as the sun moves across the sky.
5. Can different atmospheric particles affect the color of the sky?
Yes, the color of the sky can be influenced by different types of particles in the atmosphere. For example, pollution and smoke particles can scatter sunlight in different ways and create a hazy or gray appearance to the sky. Volcanic ash and dust can also affect the color of the sky, sometimes causing it to appear red or orange.
  • Other Physics Topics
11K
  • Classical Physics
