Why is the value of s = 1/3?
  1. Oct 23, 2014 #1
    a mass weighing 24 pounds, attached to the end of a spring, stretches it 4 inches. Initially, the mass is released from rest from a point 3 inches above the equilibrium position
    2. Relevant equations
    F = ks
    3. The attempt at a solution
    24 = k*(1/3)
    why is it 1/3 inches and not 4 inches?
  3. Oct 23, 2014 #2
    It isn't "1/3 inches"- it is 1/3 feet. What are the units for k? Since k times a distance is equal to a force, k must have units of "force divided by distance". If k has units of "pounds per inch" then "4 inches" would be correct. But if k has units of "pounds per foot" then 4/12= 1/3 feet is correct..
  4. Oct 23, 2014 #3
    Ahh, I see. I'm not sure what the units are, these are just some questions assigned by my differential equations teacher. I'll have to ask and verify, but what you said makes sense.
  5. Oct 23, 2014 #4
    Also, the answer key has initial conditions. x(0) = -1/4 , x'(0) = 0.
    Where does that come from?
  6. Oct 23, 2014 #5
    Simon Bridge
    ... yah: I was gonna say: why did you write down 1/3 if you don't know what it means?
    If you want to use 4", why not use 4"? It's allowed.
    If it's part of an answer key, then it's someone elses work: why are you writing down someone elses work? Do it the way you'd do it, and then compare results.
    I see this is a math course - in physics, as you just found out, numbers have units to give them physical meaning. You'll have seen this in other examples by now - but it does take a bit of practice to get used to.
    Comes from the problem statement ... translate those math expressions into English sentences and see. x(0) is x(t) at t=0, and x'(0) is the 1st derivative of x(t) at t=0.
  7. Oct 23, 2014 #6
    Yes, I just realized that 1/4 foot is 3 inches. These units are confusing me. I actually did have my work right but the answer key made me think otherwise.
    I've taken physics courses, in fact completed all my requirements for physics. My differential equation teacher likes to use random units without telling me what she is using. I get very confused.
  8. Oct 23, 2014 #7
    Simon Bridge
    The initial problem statement did not include a question - what was the wording of the task?
    If you are not told the units, you can use what you like as long you specify at the start.
    If you are self-marking it can be tricky, but your teacher appears to have been consistent in the question to use the f-p-s standard units.
    Is it possible that your teacher expects you to use this standard when units are not specified - just like others prefer SI (m-k-s) units by default?
  9. Oct 23, 2014 #8
    I am going to verify, but it appears to be true.
Have something to add?
Draft saved Draft deleted
