Why light beams attract or repel each other even when they don't have charge
In summary: It's also a shame that there are single books covering all branches of theoretical physics but no single books covering all branches of experimental physics.
SunRay-dvsh
Hi,
Can someone please explain as to why light beams attract or repel each other even when they don't have charge. Seems like it behaves like two current carrying parallel wires. There is very little material about this which goes completely above the head.
Thanks
Is that good or bad ?
Can you indicate where you got this idea about light beams that attract or repel each other ?
Perhaps he is talking about bunching and anti-bunching in quantum optics. If so, it is caused by specific entanglement between photons in a light beam.
Likes SunRay-dvsh and BvU
SunRay-dvsh said:
Hi,
Thanks
There is a gravitational effect see
(https://www.physicsforums.com/threads/parallel-light-beams-converge.473694/)
Likes SunRay-dvsh
Parallel light beams going in the same direction don't attract each other gravitationally. Parallel light beams going in the opposite direction do attract gravitationally, about 4x as strong as one gets by a naive calculation.
Likes bhobba and SunRay-dvsh
Before we determine why something is true, we need to determine if it is true.
Likes SunRay-dvsh
Hello,
I couldn't find any reference to bunching or anti-bunching. I hope this article helps: http://discovermagazine.com/2010/jan-feb/083
Thank You
Well, you should refer to the true "story", which in this case can be found here:
https://www.nature.com/articles/nature07545
https://www.researchgate.net/publication/23501103_Harnessing_optical_forces_in_integrated_photonic_circuits
All this has nothing to do with gravitational interaction between light beams of course but is about the forces of electromagnetic fields on charged particles/matter.
Likes SunRay-dvsh, BvU and Demystifier
SunRay-dvsh said:
Thank you all for your replies. Please see this article:
https://en.wikipedia.org/wiki/Optical_force
Now I get it. This is not a force between light beams as such, but a force between waveguides of the light beams. The light beams induce the dipole moments in the guides, and those dipole moments cause the force. The effect is very similar to the Casimir effect. For more details see http://lanl.arxiv.org/abs/physics/0509073
THANK YOU VERY MUCH FOR THESE REFERENCES ! Its easier to understand, though i still don't get how the transverse force is measured.
Thanks,
They have explained it very well, the original research paper in nature didn't really explain it nicely.
Basically, if someone is shooting a Really powerful laser at you, you can use a tiny weak laser to deflect it ?!
No.
SunRay-dvsh said:
Thanks,
That's why you need to read theoretical papers, not experimental ones. :wink:
Likes Zafa Pi, bhobba, vanhees71 and 1 other person
:thumbup:
Expository articles about old experiments can be fun and informative. It's a shame modern experimentalists can't do the same with their own work.
Hm, the introductory textbooks for the experimental-physics course do not too bad a job. Of course, theoreticians, sometimes have problems to understand these books due to a lack of math in these books ;-)).
Likes bhobba
To avoid repeating, see your post #21 and my reply #24 in the old thread above.
1. Why do light beams attract or repel each other?
Light beams attract or repel each other due to the wave-like nature of light. Light is an electromagnetic wave, and when two light beams intersect, the electric and magnetic fields interact with each other, causing the beams to either attract or repel each other.
2. How can light beams attract or repel each other without having charge?
Light beams do not have charge in the traditional sense, but they do have an electric and magnetic field. When these fields interact with each other, they can create attractive or repulsive forces between the beams, even though they do not have any net charge.
3. Is this attraction or repulsion between light beams the same as the force between charged particles?
No, the attraction or repulsion between light beams is not the same as the force between charged particles. Charged particles interact through the electromagnetic force, which is much stronger than the force between light beams. The interaction between light beams is a result of the electric and magnetic fields of the light waves, rather than the particles themselves.
4. Can light beams with different wavelengths attract or repel each other?
Yes, light beams with different wavelengths can attract or repel each other. This is because the wavelength of light determines the strength of its electric and magnetic fields, which in turn affects the strength of the attractive or repulsive force between the beams.
5. Are there any real-life applications of this phenomenon?
Yes, there are several real-life applications of the attraction or repulsion between light beams. One example is the use of optical tweezers, which use the repulsive force between focused laser beams to manipulate and move small particles. This technology has many applications in biology, chemistry, and physics research. Another example is the use of lasers to cool and trap atoms, which also relies on the repulsive force between light beams.
  • Quantum Physics
  • Quantum Physics
