davidge
- 554
- 21
Why manifolds in General (and Special) Relativity have to be open? Would this be because an open manifold have a continuous interval? (i.e. an interval with no interruptions)
What a boundary would mean? I was reading a book that I found on the university library and that book says that a open region ##D## in ##\mathbb{R}^n## means you have an open sphere (that is, the sphere consist of all points ##x < r##) centered at some point ##x_o## of ##D## and contained in ##D## for some ##r##. Of course, such space have to have a metric so that we can define ##d(x,x_o)##, the distance between ##x## and ##x_o##.Demystifier said:Because you don't want to mess with boundary.
A lot of the proofs in GR rely on the fact that you can pick any point in the manifold and construct a neighborhood around that point which looks like R4 locally. That is true for any point in an open manifold, but not true for points on the boundary of a closed manifold.davidge said:Why manifolds in General (and Special) Relativity have to be open? Would this be because an open manifold have a continuous interval? (i.e. an interval with no interruptions)
And what is the definition of a open manifold?Dale said:A lot of the proofs in GR rely on the fact that you can pick any point in the manifold and construct a neighborhood around that point which looks like R4 locally. That is true for any point in an open manifold, but not true for points on the boundary of a closed manifold
Yes, I mean as a topological space. Why is it always open and closed? What I said in my post #2 is valid to define a open space?martinbn said:What do you mean by open? Open as a topological space?
See https://arxiv.org/abs/gr-qc/9712019 chapter 2.davidge said:And what is the definition of a open manifold?
Yes, I actually want to know if the definition that I mentioned in my post #2 is correct for the case of Relativity.Dale said:Shouldn't you have started with this question? Your question in the OP presupposes that the questioner understood this terminology already.
davidge said:Yes, I mean as a topological space. Why is it always open and closed? What I said in my post #2 is valid to define a open space?
Ok. He explains what a open set mean, but he does not explain why Relativity requires open setsDale said:See chapter 2 in Carrolls notes
It doesn't - at least in general. The tools continuity, differentiability, atlas and so on do. A boundary means, you will have to do everything twice: for inner points and for points on the boundary which you can approach from only one side. So you double the work, probably more as boundaries can be more difficult, without gaining anything. This doesn't mean that boundaries don't play a role at all. They do if you apply Stoke's theorem, consider cohomologies and so on. But for the analytic investigations what's going on on a manifold, you simply don't need them, at least at the start.davidge said:Ok. He explains what a open set mean, but he does not explain why Relativity requires open sets
Ah, ok. Are there cases in Relativity where we cannot consider the manifold to be open? Maybe inside a Black Hole or so.fresh_42 said:It doesn't - at least in general. The tools continuity, differentiability, atlas and so on do. A boundary means, you will have to do everything twice: for inner points and for points on the boundary which you can approach from only one side. So you double the work, probably more as boundaries can be more difficult, without gaining anything. This doesn't mean that boundaries don't play a role at all. They do if you apply Stoke's theorem, consider cohomologies and so on. But for the analytic investigations what's going on on a manifold, you simply don't need them, at least at the start.
The concept of manifolds comes into play as one investigates differential equations like EFE, mainly because we want to know their geometric qualities and most important: without having them embedded in some surrounding space where they could have boundaries, or are boundaries of some set itself, like spheres are. As such they are a tool to describe solutions and their behavior. It has nothing to do with physical places, as they are a mathematical instrument. In addition it is a local concept, i.e. what happens at certain points. E.g. do the solutions of a system of differential equations build an attractor or repeller somewhere, what happens if we follow a flow and such. Therefore the consideration of a nicely behaving neighborhood of such a point is needed. And nicely means open, because otherwise you run into terribly many special cases without gaining something from it. And as in the example of a sphere: the manifold itself might be closed in a surrounding space, but the concept of a manifold means: we are on the sphere and there is no outside. So if there is no outside, only the surface of a sphere and nothing else, then it is open. And given the fact, that even an event horizon of a black hole isn't a physical place, it's hard to imagine what a physical boundary should look like.davidge said:Ah, ok. Are there cases in Relativity where we cannot consider the manifold to be open? Maybe inside a Black Hole or so.
The Schwarzschild spacetime has no pathologies. The central singularity isn't a point in the manifold, and there's no difficulty finding an open ball around any point "near" it. Likewise, there's no problem finding an open ball around any point on the event horizon; Schwarzschild coordinates refuse to map these points, but that's a problem with the coordinates not the manifold.davidge said:Are there cases in Relativity where we cannot consider the manifold to be open? Maybe inside a Black Hole or so.
If it isn't a point, what it is then? Please can you say wheter I'm wrong in the following reasoning:Nugatory said:The central singularity isn't a point in the manifold
davidge said:If it isn't a point, what it is then?
davidge said:shouldn't the central singularity of a BH be a point?
Open manifolds play a crucial role in the study of relativity because they allow for the incorporation of boundary conditions, which are necessary for understanding the behavior of space-time in the presence of matter or energy.
An open manifold is one that does not have a boundary, while a closed manifold has a well-defined boundary. In relativity, open manifolds are more relevant because they allow for the inclusion of matter and energy, which have an impact on the curvature of space-time.
Yes, open manifolds can exist without the presence of matter or energy. In fact, they are often used as a mathematical model for empty space in relativity. However, closed manifolds are not as useful in the study of relativity because they do not allow for the inclusion of matter or energy.
In the theory of general relativity, open manifolds are used to describe the behavior of space-time in the presence of matter and energy. They allow for the inclusion of these factors, which leads to a more accurate understanding of the curvature of space-time and the effects of gravity.
Yes, understanding open manifolds in relativity has practical applications in fields such as astrophysics and cosmology. It allows scientists to make more accurate predictions about the behavior of space-time in the presence of massive objects, such as black holes, and to better understand the evolution of the universe.
