Why study SUSY?
  1. Apr 26, 2015 #1
    Supersimmetry, by itself, is a neat, elegant concept; I've read somewhere else (think Griffiths' Introduction to Elementary Particles, if memory serves me right) that it allows the various running couplings of the Standard Model to converge to a single value at high enough energies; however, besides that, what are the theoretical/experimental motivations to study this complication of standard QT? I'm under the impression that this theory haven't been garnering much love from the non-string physics community, of late.
  3. Apr 26, 2015 #2
    Orodruin
    Staff Emeritus
    2017 Award
    Supersymmetry is popular in large parts of the particle physics community, not only with string theorists. The main reason for this is that it would provide possible solutions to some problems with the Standard Model. For example, it would solve the hierarchy problem (assuming the SUSY scale is low enough) and it provides viable dark matter candidates.
  4. Apr 27, 2015 #3
    One point of supersymmetry seems that the additional particles it introduces somehow "solve" the "problem" of a unification of couplings. If this is really a problem is a first question - it is, of course, a problem for GUTs, which unify all forces into some simple gauge group, which requires that at some fundamental scale of unbroken symmetry the interaction coupling has to be the same for all parts.
    One can argue that it could be also a problem for an effective theory, which assumes a common critical length scale where the field theory breaks down into some sub-theory, say some "atomic ether" or so. In this case, one would reasonably expect that all the effects should have a similar order at this scale.
    My question is a different one. Suppose one simply has some usual field theory, containing all what the SM contains but in different numbers - say, more fermions, more scalar fields, above with masses. Computing the corresponding functions for the couplings should be, I would guess, something already done in a quite general form, so that it could be sufficient to put in the numbers of the additional particles, their spin, their masses, I would guess also the representations of the SM gauge groups acting on them, to find out if in this theory the couplings unify or not.
    Any suggestions where such things can be found?
  5. Apr 27, 2015 #4
    Orodruin
    Staff Emeritus
    2017 Award
    You cannot simply add an arbitrary number of fermions to the SM without caring for anomaly cancellations. In the SM, the gauge couplings are such that the anomalies cancel generation by generation.
    What you can do is to add extra Higgses. This does change the running behaviour of the gauge couplings and using an appropriate number of extra Higgs doublets (if I remember correctly, the required number was seven additional doublets, but do not quote me on that) you can get the couplings to unify.
  6. Apr 27, 2015 #5
    Thanks, I know.
    But I don't care much about this anomaly stuff, for a reason which is possibly completely wrong:
    My understanding is that the problem they cause is non-renormalizability. But in this case, this would be a non-problem for an effective field theory with some explicit cutoff. There, the non-renormalizable terms would be those which descrease faster than the renormlizable ones in the large distance limit, so they would disappear automatically if the cutoff is sufficiently small, even if they would have comparable order at the critical distance. Roughly speaking, one could leave problems with non-renormalizability to the long distance limit. Or is this completely off, and there are other problems with them?
    What I would like to add (for completely different reasons) is a single scalar field for each electroweak doublet. The triplets for quarks would be colored, those for leptons would not interact with gauge fields at all.
    Now, naive counting gives equal numbers for bosons and fermions: 8+3+1 gauge bosons, 3 x (1+3) new scalars against the 3 x (1+3) electroweak doublets. So, it seems to make sense to look if some of the advantages of supersymmetry - whatever they are - would be present - by accident - in this theory too.
  7. Apr 27, 2015 #6
    Orodruin
    Staff Emeritus
    2017 Award
    This is inconsistent. You cannot have an electroweak doublet that does not interact with gauge fields.
  8. Apr 28, 2015 #7
    But I can have scalar fields which do not interact with gauge fields, and they can be associated with electroweak doublets.
    This association would be a correspondence for numbers (there will be one scalar field for every electroweak doublet). Moreover, each scalar field borrows its gauge charges from one preferred component of "its" electroweak doublet. In the case of leptons, this preferred component will be the right-handed neutrino, for quarks the right-handed anti-down-type quark (EM charge 1/3).
  9. Apr 28, 2015 #8
    Orodruin
    Staff Emeritus
    2017 Award
    Why dont you write down your intended Lagrangian? It will be more effective (haha) than trying to describe your idea in words.
  10. Apr 28, 2015 #9
    I don't think this would simplify something. The Lagrangian of scalar fields interacting with gauge fields would be nothing, new, thus, only a misdirection of interest (one would think there is something interesting in this formula) and what matters would be anyway the description of the number of fields and their charges.
  11. Apr 28, 2015 #10
    Orodruin
    Staff Emeritus
    2017 Award
    Exactly, and I am not getting a clear picture of exactly what you want to do, which fields you want to couple to the scalars and how. This would be much simpler if you just wrote down the (interaction) Lagrangian you had in mind.
  12. Apr 28, 2015 #11
    If $$\mathcal{L}= \frac12 D_\mu \phi^*_{ga} D^\mu \phi_{ga} - \frac12 m^2_{ga} \phi^*\phi$$ with $$D_\mu = \partial_\mu + i A^b_\mu T^b$$ makes you happy. Here g is the generation index, a is from 0 (for leptons) to 3 (for the three quark colors), b goes over the SM gauge fields, and the ##T^b## describe the representation I have to describe in words anyway: It acts trivially on the ##\phi_{g0}## and by the standard three-dimensional representation of U(3) (obtained by factorizing out weak interactions ##SU(2)_L## and ##\mathbb{Z}_3## from the SM gauge group) on the three-dimensional space of the ##\phi_{gi}## with ##i=1,2,3##, g fixed.
  13. Apr 28, 2015 #12
    ChrisVer
    That's true from my case since both Dark Matter scenarios (supersymmetric WIMPs) as well as the Hierarchy problem solutions of SUSY become less favorable as you go to larger energies. As already mentioned the hierarchy problem could be solved by SUSY if the scale of it was around the TeV scale. Obviously we haven't yet found anything in the LHC and the parameter space for the theory to exists gets tighter. On the other hand they always try to save SUSY models like MSSM, either by extending it or I don't know exactly , say that it might still be invisible at the LHC.
    I still like SUSY but the normal things the theory could solve, have been cornered a lot.
    The unification of the coupling constants is (for me) an aesthetic need of some people and I don't really like it (as a reason)
    Check eg. this figure :
    http://scienceblogs.com/startswithabang/files/2013/05/running_coupling.gif
    The left is the SM and the right is the MSSM.
    I don't personally find any reason to have the lines changing at only 1 given energy (at around 10^3 GeV ~ 1 TeV scale).
    If you don't care about these problems and don't care about experiments (like string theorists) then you can allow for SUSY to exist at any energy.
  14. Apr 28, 2015 #13
    Orodruin
    Staff Emeritus
    2017 Award
    So what are your Yukawa couplings?
    If your fields transform non-trivially under any of the gauge groups, they are going to have gauge couplings so what is the point of having the covariant derivative there at all?
  15. Apr 28, 2015 #14
    The coupling constants are the same as those of the quarks.
  16. Apr 28, 2015 #15
    Orodruin
    Staff Emeritus
    2017 Award
    Which coupling constants? The Yukawa couplings are coupling constants between fermions and scalars. If you have gauge coupling constants your scalar fields interact with the gauge fields. Or are you saying that you want to have a scalar field that does not have any quantum number? What is going to stop this field from coupling to every fermion in the SM?
  17. Apr 28, 2015 #16
    Yes, these scalar fields are not intended as Higgs fields which have to give any fermions any mass.
  18. Apr 28, 2015 #17
    Orodruin
    Staff Emeritus
    2017 Award
    It is not a matter of having to give fermions mass, it is a matter of which terms are allowed in your Lagrangian. If they are allowed, they will be there or you need to explain why they are not. If you have a singlet scalar ##\phi##, what stops me from writing down the interaction term ##\phi \bar q_R q_R##?
  19. Apr 28, 2015 #18
    So ok, you are free to add whatever you want or think it is somehow unpreventable. I have seen no justification or necessity to write down such terms, so I do not write them down by Ockham's razor, that's all.
    edit: Thinking about this a little bit more, such a Yukawa term, which would connect the scalar field with the corresponding electroweak doublet, would be quite natural.
  20. Apr 28, 2015 #19
    ChrisVer
    Whatever you are allowed to... If you are allowed to write something, then you have to write it, otherwise explain how this thing went on missing.
    If you could discard terms like this in the Lagrangian, then there would be no strong-CP-problem and there would be no "bad" proton decays in several other theories.
  21. Apr 28, 2015 #20
    Orodruin
    Staff Emeritus
    2017 Award
    Ockham's razor would actually go in the other direction. If you do not prohibit the coupling using some symmetry, it is generally going to be generated by running at one scale even if it is zero at another scale.
  22. Apr 28, 2015 #21
    Orodruin
    Staff Emeritus
    2017 Award
    And I almost forgot: Regardless of how "natural" this would seem to you, it would induce flavour changing neutral currents.
  23. Apr 28, 2015 #22
    What would be the problem with this?
  24. Apr 28, 2015 #23
    Orodruin
    Staff Emeritus
    2017 Award
    That flavour changing neutral currents are not observed in Nature?
  25. Apr 28, 2015 #24
    In this case, please explain in more detail how all this happens.
    I start with a scalar particle which does exactly nothing, except of having a mass. You tell me, that it is somehow unavoidable that there appear some terms of some Yukawa-like interaction ##\psi* \psi \phi ##. Ok, maybe, so what, and I have not a big problem with accepting such terms, they look not that unproblematic if that scalar is connected with the fermions of its own associated electroweak doublet. Anyway, except for the right-handed neutrino they are all connected with each other by gauge fields. Now you tell me that this leads somehow to some process you have named "flavour changing neutral current" which does not exist in the SM/is not observed in Nature.
    Sorry, but this is already too much mystery, so please details. In particular, why (AFAIU, correct me if not) everything is fine if the Higgs particle somehow interacts in some terms with all fermions, but everything is fine with this, but if my completely innocent scalar field is doing the same thing all is unavoidably wrong.
    The second point I don't understand the terminology. How would you name neutrino oscillations - AFAIU they change the flavour of the neutrino, and whatever happens there is neutral, not?
  26. Apr 28, 2015 #25
    Orodruin
    Staff Emeritus
    2017 Award
    A flavour changing neutral current gives rise to processes such as ##e + X \to \mu + X## or ##e^- + e^- \to \mu^+ + \mu^-##. There are strong constraints on this type of processes. Even if you introduce one scalar per type of particle and per generation, you will likely run into problems with lepton/quark universality (which is essentially saying that all leptons/quarks interact with the same strengths.
    Yes, this is the point. The Higgs interactions define what flavour is. Anything else you do in the scalar sector is likely to screw this up unless you engineer your model in a way that ensures that it does not, the general idea here is that what gives rise to the Higgs Yukawa couplings also gives rise to other interactions which could potentially be flavour violating.
    Adding scalars is not something that is easy and essentially no scalar field is "innocent" as far as interactions go. The point is that your scalar fields would have a structure which is different from the flavour structure imposed by the Higgs Yukawas and therefore induce flavour changing neutral currents.
    No, neutrino oscillations are due to charged current interactions (this is how you create and detect neutrinos). It is no stranger than flavour changing charged currents in the quark sector and is precisely based on the Higgs Yukawas not being diagonal in the interaction basis. The SM is fine with flavour changing charged currents and they are observed in Nature. The reason you get oscillations is that the neutrino mass eigenstates, unlike the quark mass eigenstates, have very small mass differences, leading to interference terms when you compute certain processes.
