Why this equation can't solve
  • Thread starter jacky_pcs
I would like to solve equation with x=a-1*b but when I inverse matrix A . It is bad solution to solve (I use mathematica to solve it)(Attach matrix A in excel file).
I want to know why matrix A is bad solution when I inverse???????
If I want to solve this equation. How i can do?
  • Matrix A.xls
  • Matrix B.xls
Answers and Replies
statdad
1,495
35
Is your matrix a square? If not - no inverse. (Although being square is not itself sufficient for an inverse to exist.)
-I use Pseudo method but answer is bad solution
x=(aT*a)-1*B
statdad
1,495
35
Okay, for which item are you trying to solve.
your equation was
[tex]
x = a - 1b
[/tex]
That has nothing to do at all with your "solution" - your result doesn't follow from the equation.
hunt_mat
1,742
Roger Penrose worked on the inverses on non-square matries before relativity.
6,705
your equation was
[tex]
x = a - 1b
[/tex]
I believe the OP meant x = A-1b.
Then he/she revised the above to this: x=(aT*a)-1*B,
which I believe means this: x = (ATA)-1b.
statdad
1,495
35
Aha - good catch. Of course, this means that the original equation is nowhere to be seen, so it remains impossible to see why this approach fails.
hotvette
996
Need to pay attention to dimension. The matrix A has 35 rows and 20 columns (i.e. 35 x 20) and B has 35 rows (i.e. 35 x 1). ATA is a 20 x 20 matrix and so is (ATA)-1. Multiplying a 35 x 1 matrix by a 20 x 20 matrix isn't valid.
This smells like a least squares problem, which means the solution would be x = (ATA)-1 ATb.
HallsofIvy
41,833
964
What in the world do you mean by this? Roger Penrose wasn't born until 26 years after relativity was developed! Do you mean he worked on them before they were used in relativity?
289
Penrose worked those inverses before he worked on relativity
Related Threads on Why this equation can't solve
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
