Why Use Tensors in GR: Benefits & Potential Pitfalls
  • Thread starter ta66505477
  • Tags
    Gr Tensor
In summary, Tensors are a mathematical tool that ensure covariance under coordinate transformations in physics equations. They are important for relativistic gravity because they allow for easy parallel transport. Without tensors, a physical theory may not be independent of the coordinate system used to model it.
ta66505477
I think that is a fundamental question of why we need Tensor when dealing with GR?
Quoting from the textbook (Relativity, Gravitation and Cosmology: A Basic Introduction)
Tensors are mathematical object having definite transformation properties under coordinate transformations. The simplest examples are scalars and vector components. The principle of relativity says that physics equations should be covariant under coordinate transformation.
To ensure that this principle is automatically satisfied, all one need s to do is to write physics equation in terms of tensors.
So, what is, if I say don't have definite transformation properties?
Any example about if I am not going to choose Tensors as my tool, what trouble will I get?
Thanks
Thanks
Your theory likely won't be covariant if you don't use tensors - which means that its physical predictions won't be independent of the choice of observer and/or coordinate system.
You can express a covariant theory without tensors, but as the text says, tensors make it automatically covariant.
tensors are in a sense an organizing tool even if you decided to work things out using different methods you'd be doing the same math as is done by the tensors.
As a comparison, linear algebra is an organizing tool that makes it easier to solve systems of equations. You can solve for x in one equation and substitute into the next one and eventually work out a solution or you can use the rules of linear algebra to get there faster.
In SR, there are arguably quite a few cases where three-dimensional language is the better tool for the job. In Rindler's SR book, he has a preface where he expresses this point of view and explains that the initial part of the book will be in three-dimensional language, and only later will he introduce four-vectors.
But for GR...just the thought of trying to do it with non-tensorial tools makes my head hurt. We have rules in GR for how to parallel-transport a tensor. We don't have rules for how to parallel-transport a non-tensorial quantity.
This doesn't only apply to relativity. Trying to do classical continuum mechanics of solids or fluids without tensors isn't fun, either, for the same reason: the behavior of the physical system is independent of the mathematical coordinate system you use to model it.
Try working with an arbitrary anisotropic material whose orientation varies at different points in space, without a tensor equation like ##\sigma_{ij} = C_{ijkl}\epsilon_{kl}## (plus some symmetry conditions on the three tensors) to connect stresses and strains. If you prefer to write down 21 separate equations to describe how to transform the 21 independent coefficients in the 81 terms in ##C## from one coordinate system to another, go right ahead...
Of course you can just about survive without tensors for isotropic materials, by writing the independent terms in ##\sigma## and ##\epsilon## as vectors, and ##C## as a 6x6 matrix. But even in that simple case the "rules" for transforming ##\sigma## and ##\epsilon## between different coordinate systems are a mess, and engineers give themselves headaches even in 2D, trying to remember how to do it geometrically with Mohr's circle, etc.
It seems to me this question is analogous to why use vectors in Newtonian mechanics or electromagnetism? You may eventually need to pick a coordinate system to calculate something, but up to that point being tied to a coordinate system just obscures the physics.
It may be instructive to look at Maxwell's original equations for electromagnetism, as discussed in this article
http://www.ieeeghn.org/wiki/index.php/STARS:Maxwell%27s_Equations
Recognition of a symmetry sometimes suggests a notation or
maybe even a more-complicated mathematical structure that captures it.
I remember reading that up til 1911, Einstein was still using scalars for the gravitational field, but scalars proved insufficient for the model, so he moved to tensors.
Correct me if I am wrong.
Consider the math entity defined as V=(1,0) in every 2-dimensional vector space. This is a perfectly valid mathematical entity. It can not be a physical entity because (1,0) in inches and (1,0) in miles can not be the same physical thing. In other words, its definition does not allow it to transform correctly under coordinate transformations. Tensors can represent physical entities that exist, whether there is a human to define coordinate systems and units or not. When you know that something physically exists like force and acceleration, you want a way to represent it so that the equations you right down, like F = mA, will make sense without regard to choice of coordinate system. That is why Tensors have to have "definite transformation properties under coordinate transformations." They are mathematical constructs that can represent physical entities.
I don’t disagree with this (side note, MTW has a nice exercise showing why relativistic scalar (precession of Mercury’s perihelion wrong) and vector theories don’t work as theories of gravity, these could still be considered tensor theories of rank-0 and rank-1 tensors). I just took the question to mean something different, I took it to mean something like why use tensor methods.
Thx a lot. I understood something in here.
And thanks all of you.
I will keep on trying to learn more from the textbooks and go back here to check my understanding.
All of the textbooks using Tensor from the beginning and tell you that Tensor is a wonderful tool in general relativity. But none of them, even though my professor cannot not show me the difference about using or not using.
Like Remainder Theorem
f(x)=x^101+x^91 what is the remainder when divided by (x-1)
In here, it is convenience that just substitute x=1 to get the remainder.
If I don't to that, I will get a horrible things to be divided.
Hence, you know that Remainder Theorem is powerful through this example.
I hope I can get an example like that.
Once again, thanks all of you.
In a same manner someone can ask about vectors... Vectors have some specific transformation properties and that's why we use them to describe some physical quantities. If you'd try to describe these quantities by scalars instead of vectors, you'd eventually get really weird results (if you get any result at all). For example, a vector under rotations of the axis will have a transformation law like:
[itex] \vec{w} \rightarrow \vec{w'}= R \vec{w} [/itex]
with [itex]R[/itex] being a rotation matrix. In general you have that [itex]|\vec{w}|^{2}=|\vec{w'}|^{2}[/itex]
Things that in nature transform like this, are recognized as vectors and we use them as such.
In the same manner, in Riemannian geometry, you have to introduce tensors because they follow some certain transformation laws, which keep some quantities (eg the 1st fundamental form, or else put [itex]ds^{2}[/itex]) invariant under these transformations. You'll eventually have to use tensors.
You don't in general use tensors in GR...for example the Christofel Symbols (or connections) are not tensors, but they are used in several GR formalism (mainly in creating tensors, like the Riemann tensor). One really interesting fact for tensors, is that if they are 0 in one reference frame, they'll be zero in all others (due to transformation laws). So in fact you can always choose a ref.frame which will be much easier to compute the quantities involved.
This isn't as fundamental a question as you might think.
I can easily just ask you: "why use vector calculus to formulate Maxwell's equations? Why not just write them all out explicitly in terms of partials like Maxwell originally did? Hell why not just write out Einstein's equation explicitly?" This is all simply a matter of calculational fluidity and, perhaps to a lesser extent, aesthetics.
Do you want to go the pedestrian, masochistic route and prove that ##\xi^2 \xi^{\nu}\nabla_{\nu}\psi^{\mu} = (\xi^{\delta}\psi_{\delta})\xi^{\nu}\nabla_{\nu}\xi^{\mu} \Leftrightarrow \xi_{[\delta}\nabla_{\mu}\xi_{\nu]} = 0## for time-like and axial Killing fields ##\xi^{\mu},\psi^{\mu}## by specializing to some coordinate system and writing out a mess of terms involving coordinate dependent quantities (Christoffel symbols, partials etc.) or do you want to take the more elegant, efficient route and just prove the above using the abstract index formalism?
The latter is always faithful whereas the former is only pragmatic when synchronous or locally inertial coordinate systems can be utilized and even then you're still making use of the relationship between general covariance and tensor fields, and more generally spinor fields.
1. What are tensors and why are they used in general relativity?
Tensors are mathematical objects that represent physical quantities and their transformations in space and time. In general relativity, tensors are used to describe the curvature of spacetime and the gravitational field, as well as the motion of matter and energy.
2. What are the benefits of using tensors in general relativity?
Using tensors allows for a more elegant and concise mathematical description of the complex phenomena involved in general relativity. They also provide a framework for understanding the geometric nature of gravity and its effects on matter and energy.
3. Are there any potential pitfalls to using tensors in general relativity?
One potential pitfall is the complexity and abstract nature of tensor mathematics, which can make it difficult to grasp and apply. Another challenge is the need for advanced mathematical and computational techniques to work with tensors and solve equations in general relativity.
4. How do tensors help us understand the theory of relativity?
Tensors help us understand the theory of relativity by providing a mathematical framework for describing the curvature of spacetime and the effects of gravity. They also allow us to make predictions and perform calculations that can be experimentally tested.
5. Can tensors be applied to other areas of physics besides general relativity?
Yes, tensors are used in many areas of physics, including electromagnetism, quantum mechanics, and fluid dynamics. They are a powerful tool for describing the relationships between physical quantities and their transformations in various systems and fields of study.
