Why won't my equation work?
  1. Sep 11, 2015 #1
    So given a problem where you have a triangle. One angle in the triangle is 4 times larger than another angle. How big are each of the angles?
    So i set up the equation 4x+x+180-5x=180
    One angle is 4 times large than another, hence 4x. The angles must add up to 180 because it's a triangle. The last one has to be 180 minus the the two others(4x+x). I see that the equation wont work because the x's cancel out, but i don't understand why this is not correct. I feel like im missing out on something very basic and obvious but i cant seem to figure out what it is. Could someone help me out?
    Btw i wasnt sure whether to put this here or in the homework section, Perhaps you mods could move it if it doesen't belong here?
  3. Sep 11, 2015 #2
    RUber
    It is because you don't have enough information.
    You could have (1, 4, 175), (2, 8, 170), etc.
  4. Sep 11, 2015 #3
    RUber
    To better explain, you have what is called an underdetermined system.
    ## \left\{ \begin{array}{l l } x + y + z = 180 \\ 4x - y = 0 \end{array} \right. ##
    Note that you have 3 variables and only two equations.
    You can narrow down the possibilities, by constraining x, y, z to be positive values. Then you have 0< x < 36, giving 0 < y < 144, but still unless you know something else about the system, you will not find an answer.
    In your equation that you built, you essentially used the same constraint equation twice. This gave you a tautological (always true) equation, 180 = 180.
    Using x + y + z = 180 to define z = 180-x - y, and then substituting back into the same equation gives x + y + 180 - x -y = 180, just like you found. If you could find another relationship, you could hope to solve for one, and thus all, of the angles.
