Exploring the Role of Zero in Math and Science
In summary: The integers I use were made by Peano just a couple of years after KroneckerIn summary, the number zero is important because it is necessary for completeness in mathematical systems such as groups and rings. It allows for the definition of the additive identity and is crucial in operations such as subtraction and division. Without zero, many mathematical concepts and calculations would be much more difficult, if not impossible. While it may be possible to create a number system based on multiplication instead of addition, it would present many challenges and limitations. Overall, the discovery and understanding of zero has greatly advanced mathematics and science.
Why do we have the number zero? What makes it important? Can we create math like system that don't use zero but are nonetheless useful. What limits or biases does having or not having zero create when we do science?
Mathematics news on Phys.org
Calculus would be hard without the limit as stuff goes to zero.
  • Number representations would be hard (just try do do calculations in the roman number system which has no zero)
  • Group theory (and everything based on it) would not exist
  • Since equality is defined as "difference equals zero" in several mathematical systems, equality would be hard to define
... and so on.
One way to define numbers in a pragmatic, constructive way is as actions. This especially gives you meaning for the negatives. For example the number +3 indicates incrementing in the positve direction 3 steps, -3 is the reverse action and 0 is the identity, the do-nothing action. The zero is necessary for completeness when numbers are used in this way (as elements of a group under addition). It is in fact referred to as the additive identity for this reason.
God gave us the Whole Numbers. He did not give us zero because he did not need to. Humans are smart enough to find what zero means, using our own efforts.
I'd say 0 is a lot more important than, say, 362. It would be easier to get rid of that one.
When did you last look for ##f(x) = 362##?
Likes DrewD and {~}
If you didn't have 0, then I guess every football match would have to start at 1-1? Who would be credited with scoring those goals?
Likes billy_joule, Samy_A and Dr. Courtney
What good is the additive identity in symbolic math? Is it actually necessary? Why can't our number system be based on multiplication rather than addition and use 1 as the identity to which transformations are made to get other numbers? I think I read somewhere that that would work under group theory. Why does group theory require zero?
What does it mater which number the football game starts at? If it is the same number isn't it still a fair match?
Rings, fields, vector spaces need aan additive identity.
While anecdotical, this example shows that without 0, you have to devise tricks for the simplest of things,
What world are you living in that you want to replace addition with multiplication? They are different you know!
Back to football, if you start at 1 and multiply by 1 every time you score a goal, the score would always be 1-1. There's a certain fairness in that, I guess.
Likes billy_joule
It does not, You can create a group using multiplication as the operation - but you will soon run into problems. First - you cannot use the integers, since that would not give you an inverse, You have to use the rationals - and you will run into a lot of problems. But feel free to try!
No number system using addition would be closed under it : how would you define a-a in such system? It may be an interesting exercise to show that
0 (the right type of 0 object) is the only viable definition for the expression a-a.
...And God created zero and permitted man to discover it, and this pleased God that it was good.
Would you please leave the religious references for...a religious forum?
I'm pretty sure symbolipoint is speaking tongue in cheek...
Ah, good deal, my non-religious refuge here at PF is safe, phew.
My higher-level human feelings were active on this, so what I said was not any quotation from religious sources. The remark I made comes from the sometimes quoted statement that God gave us the integers,...
"God made the integers, all else is the work of man."
Leopard Kronecker, 1886
The integers I use were made by Peano just a couple of years after Kronecker wrote that.
Likes SammyS
Isn't Kronecker one of the Mathematicians that pushed Cantor to a breakdown because of his insults and accusations?
Yes. And Kronecker still remains a brilliant mathematician.
Made? Peano just defined a very useful set of axioms. He did not construct or make anything however.
How would you describe this part of his work? Or is it your point that the integers, or rather the natural numbers, can not be considered constructed by the Peano axioms without Dedekind's isomorphism proof?
Just not too decent of a person, it seems.
Many mathematicians weren't for some reason.
No zero? Means no difference quotient, which means no differentiation, which means no integration, which means an extremely difficult way to calculate area between the x-axis and a curve/line, which means no calculus, which means I have nothing to learn in seventh grade in math.
also, zero is both a real number and an imaginary number because it can be written as 0 and 0i. so it is also a complex number 0 + 0i. There would also be basically no definition for e (for the Taylor series) which is the sum from ZERO to infinity (or sometimes thought of as x/ZERO where x is positive) x^n/n! with n being the variable and x being the exponent in e^x. Plus, it would be impossible to define the x and y-axis on the coordinate plane if a point was on those axes.
All in all, without zero everything would fall apart.
It seems to me slope is computed as a ratio. I don't see how this explicitly requires zero. In modern calculus the rise and run both approach zero but zero itself is a no go for the denominator at least. I don't see why we can't keep the numerator and denominator largish but increasingly more precise, perhaps by multiplying both by some common factor related to how precise an increment we are talking about. Probably I am mad but I don't see specifically why it wouldn't work.
In a structure where you allow for subtraction ( as , maybe, the operational inverse of addition, as a group), how would you define, for any element x, the expression : x-x , or x+(-x) ?
Likes symbolipoint
Consider f(x) = 1, a function whose graph is a horizontal line.
##f'(x) = \lim_{h \to 0} \frac{f(x + h) - f(x)} h = \lim_{h \to 0} \frac{1 - 1} h = \lim_{h \to 0} \frac 0 h = 0##
The line is horizontal, thus we would expect its slope (i.e., f'(x)) to be zero.
Likes symbolipoint
What is zero and how is it used in math and science?
Zero is a numerical value that represents the absence of quantity or value. In math, it is used as a placeholder to indicate a position in the place value system. In science, it is used to represent a starting point for measurements and as a reference point for calculating changes in values.
Why is zero important in math and science?
Zero is important in math and science because it allows for the representation of values that are less than one and greater than negative one. It also serves as a reference point for calculations and equations, making it an essential part of problem-solving in these fields.
How does zero affect calculations and equations?
Zero can affect calculations and equations in a variety of ways. For example, when multiplied by any number, the result is always zero. When added to any number, the result is that number. Additionally, dividing by zero is undefined and can lead to mathematical errors.
What is the history of zero and its significance?
The concept of zero has a long history dating back to ancient civilizations such as the Babylonians and Egyptians. Its significance lies in its ability to represent a lack of value and its integral role in the development of the decimal system and modern mathematics and science.
How is zero used in real-life applications?
Zero is used in various real-life applications, such as measuring temperature, calculating distances, and determining the balance of chemical equations. It is also essential in fields such as engineering, physics, and economics, where precise measurements and calculations are necessary.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Discussion
