Wierd occurrence with Pepsi
  1. Feb 28, 2005 #1
    About 5 years ago I bought a can of Pepsi Max. It sat at the back of a cupboard since. Whilst tidying out the cupboard, I found the can. It was however half empty. The wierd part is that the can was never opened. About 150ml of Pepsi had to have leaked out, but visible on the shelf was a light brown stain.
    There are a couple of questions here:
    1) How did the Pepsi get out? I'm assuming slow diffusion. Corrosion is troubling to consider.
    2) Apart from it probably being flat, would it be unhealthy to drink the remaining Pepsi? Would you expect a high concentration of corroded aluminium ions in the drink?
    3) What would drinking aluminium ions do to you?
    4) Would you expect this to be unique to the can (a material defect), the product range (Pepsi Max) or acidic/low pH carbonated drinks in general?
  3. Feb 28, 2005 #2
    That is very interesting and strange. I've never heard anything like that!
    In an attempt to answer your questions:
    1) I would also assume slow diffusion, but corrosion can't be ruled out entirely...do you know that coke can clean away rust among other things?
    2) I might expect a higher concentration of aluminum ion levels...it only makes sense since its been in there for 5 years. Although I'm not sure it would be harmful to you...but then agan I'm not a medical professional so I wouldn't advise you in actually ingesting it.
    3) I have no bloody clue what they might do to you.
    4) I would think it would be either a product range thing or a material defect in the can.
  4. Feb 28, 2005 #3
    brewnog
    It would have to be a failure of the can. Either a manufacturing defect caused incomplete sealing between the can base and sides, or (more likely, in my opinion) the lining within the can was not properly applied. Pepsi Britvic use steel cans (Coca Cola use aluminium) so if the steel was exposed then corrosion of the can would have been not only possible, but also pretty likely.
    Why don't you dissect the can, clean it out, and have a look?
  5. Mar 2, 2005 #4
    I suspect this is a result of simple evaporation. Coupled with heat cycles. As the Can heats it would force gas out through the tab. I'm willing to bet the concentration of the syrup would be higher and replacing that 150 ml with water would bring it close to the original formula.
    Could Be wrong though Who knows.
  6. Mar 2, 2005 #5
    brewnog
    Oooo but how to account for the brown stain?
    That's the dilemma I face every morning.
    (Sorry, I couldn't help myself.)
  7. Mar 4, 2005 #6
    Mk
    Maybe the atoms in the pepsi aligned perfectly with the atoms in the bottom of the can, so that the liquid fell through the bottom? :biggrin:
  8. Mar 5, 2005 #7
    According to my mom, drinking from aluminum cans gives you alzheimer's. Apparently that's why I have such a bad memory. She explained why, but I forget the details.
  9. Mar 5, 2005 #8
    you can rule out corrosion AND alzheimers. All of the metal soda containers are lined with a thin layer of plastic. Don't beleive me? next time you open a can, look at the tab closely, and you will probably be able to see some plastic frays around the edge of the lid. If they didn't line the interior, I think it would be exceptionally dangerous to drink and bloody disgusting to boot.
  10. Mar 5, 2005 #9
    brewnog
    But if the liner contained a flaw caused by a manufacturing defect, corrosion would be probable, especially over such time periods.
