Wilds for each digit? (c++)
  1. Jul 11, 2010 #1
    I am using c++ and trying to parse two characters from a string into a single hexadecimal number.
    For example part of the string goes 'AB'. I want to state that A is 8, and B is 0xc (0xc), but then assign both of these into a single value to form a unique number: 0x8c
    This is because I am trying to save space with a 1 byte char (8 bits), having the parser effectively write to each 4 bit block (nibble) to be considered separately later.
    If I cannot do this using c++ can it be done using assembly?
    Thanks in advance for any help.
  3. Jul 11, 2010 #2
    mgb_phys
    Use strtol or sscanf to convert the hex character to a byte then split the byte using bitmasks and shifts
  4. Jul 12, 2010 #3
    Mark44
    Staff: Mentor
    I'm curious: what does the title of this thread, "wilds for each digit", mean?
  5. Jul 12, 2010 #4
    My first reaction to reading this was that posted already by mgb_phys. But then I realized that I'm totally lost here:
    You've got a string with two bytes interpreted as chars:
    01000001 (65, 'A')
    01000010 (66, 'B')
    And now, you want to somehow associate "A" with 8?
    01000001 => 00001000 ?
    And then assign B to 0xC, AKA 12?
    01000010 => 00001100 ?
    I would understand if you wanted to make "A" => 4, or "A" => 1 (reading only the first half of the byte or the last half of the byte), or if you wanted "A" => 10 (since that's the human-readable definition of "A"), but 8? Similarly for B, I would understand "B" => 4, or "B" => 2, or B => 11, but I don't understand making it 12?
    So, all told, it's:
    01000001 01000010 => 10001100 ?
    I guess I'm a little lost on the example.
    DaveE
  6. Jul 12, 2010 #5
    Yes, I want to "decipher" them into numbers I have decided upon.
    Pseudocode:
    When you read an A, interpret it as an '8'. // Parse 1
    When you read B, interpret it as 'c' // Parse 2
    char My_new_number = 0x$$ // each $ is what I call a 'wild' for lack of a better term.
    Take the answer from Parse1 and replace the first wild with it.
    Take the answer from Parse2 and replace the second wild with it.
    Result:
    My_new_number = 0x8c
    What mgb_phys mentioned seems promising, I am still investigating.
  7. Jul 12, 2010 #6
    Hurkyl
    Staff Emeritus
    A sanity check:
    Are you sure this really is something important for your application, and worth devoting your time to?
    Anyways, the main thing, I think, is to stop thinking of the entire thing as string manipulation -- you should start thinking of some of it in terms of arithmetic. (Well, I suppose bit shifts and masking can be reasonably thought of as string manipulation as well -- just with a different alphabet)
  8. Jul 13, 2010 #7
    Mark44
    Staff: Mentor
    "wild card" is a better term.
  9. Jul 13, 2010 #8
    Depending on how fast you need it to be, and how many resources you can take, there are a few ways to do it.
    The best way would be arithmetic, assuming you can find a few patterns that does the trick. That'd probably minimize the computing power and time needed-- you just need to find a pattern that works.
    A fast way to do it (if you have to repeat this a LOT of times in a row) that uses more memory would be to effectively build a hash. An array of 256 single bytes-- the 65th is set to 8, the 66th is set to 9, etc. For each character you'd like to translate, set the Nth value in the array to the translated hex number, where N is the ASCII value of the character. Then, read in the 1st character, fetch the translation from the array, then bitshift the resulting value over by 4. Then read in the 2nd character, fetch the translation, and OR it with the result of the 1st character, yielding the total value.
    Downside is that you're using a 256-byte array, which may be more than you want to take, especially if this is only happening a couple times in your program.
    Otherwise, I'd probably set up a nested if...else clause (better performance than a switch, I think), and test each character to get the translation, and again OR-ing the results together to get the full translated byte. Makes for an ugly bunch of code, but it should be reasonably quick.
    DaveE
