Will it bend?
  1. Feb 23, 2012 #1
    It may sound like a silly question but I really need some help. Not with the maths, I know that's beyond me I'll plug the numbers into an online calculator when I know what it is is I should be doing and that's where I need you.
    The set up:
    A random length of 25mm square tube with a wall thickness of 1.5mm is held rigid at one end.
    The question:
    At what point along the piece of square tube will the average person weighing 70kg, be able to stand before the bar bends to the point of plastic deformation?
    Do I have to specify a length to find out the moment of turning force in newtons and then see if this is with the parameters of the material, or can I do a dircect calculation using the 70kg weight?
    What stats do I need about the material (plastic modulus, inertia etc) and how do these stats relate to the question?
    For your info I've stood on the length of tube and it's around 650mm
  3. Feb 23, 2012 #2
  4. Feb 23, 2012 #3
    Thanks xxChrisxx
    I'll give it a try and post my progress if that's okay?
    Got to go and help a student make a giant sewing needle, no physics there I can't handle.
    All the best
  5. Feb 23, 2012 #4
    I know you said no math, but it might help somebody else looking at this thread:
    1. Find the material yield stress (google)
    2. Set the material yield stress equal to the equation for bending stress, which is:
    σ = (M*y)/I , where:
    M = moment = force * distance
    y = distance from center to edge of beam (the overall height of the tube divided by two, don't make it harder than it is)
    I = 2nd moment of intertia (for a square tube) = [(height)^4 - (inner height)^4] / 12
    3. So now you should have:
    σ (material yield stress) = (F * x) * y / I
    Solve for x, which is the distance at which the material will fail due to the persons weight.
    EXAMPLE:
    1. Lets just say the material is Aluminum 6061T6, which has a yield of 34,000 psi. This converts to 23.93 kg/mm^2
    2. 23.93 kg/mm^2 = (70kg * x) * (25mm/2) / 13031 mm^4
    3. Solving for x: x = 356.32 mm
    So one of the key factors is what type of material it is made out of. From there you just need to google the yield stress of that material.
    I hope this all makes sense... if not let me know.
  6. Feb 23, 2012 #5
    Okay BTown
    a bit scary I wish this language were a familiar to me as to you guys. But I'm not a lost cause, I will try to employ these formula, it will give me a mathmatical pedestal to stand on a survey lesser mortals (currently me)
  7. Feb 23, 2012 #6
    Okay so here's my first stumbling block.
    How can I find the 'moment' if I do not know the distance the the person will be standing at yet. Am I missing something?
  8. Feb 23, 2012 #7
    In this case, M is the output of the formula.
    σ = (M*y)/I
    In this case we are finding a stress for a known moment.
    (σ*I)/y = M
    In this case, we are finding the moment for a known stress.
    We know the stress we want (yield stress).
    I is calculated.
    Y is the distance from the neutral axis to the edge (half the height of the tube).
  9. Feb 23, 2012 #8
    metalworker,
    You're exactly right, you don't know the moment. However remember that moment is equal to force * distance, and you know force, it is the weight of the person.
    When I solved for x (which is the max distance the person can walk out before the beam yields), I was breaking moment into its two components, force and distance.
    So you'll notice in my final equation for x, which again is the max distance this 70kg person can walk out, there is no 'M' for moment, because it has been broken apart so you could solve for 'x'.
  10. Feb 23, 2012 #9
    Dear BTown
    I can't believe it I really think I understand what you're talking about, you kept the two parts apart and left x unknown in the equation!
    Now I need to read your post again and do some more thinking.
    Off home now but will post again soon
    Slowly a light is glimmering at the end of the tunnel, it could be a train hacking towards me though !!!!!!!!!
  11. Feb 23, 2012 #10
    metalworker,
    you got it man :) let me know if you have any more questions.
  12. Feb 24, 2012 #11
    I've got my figures together and wondered if you would be so kind as to check this equation, then hopefully help me work through solving it?
    250N/mm2 (steel yeild strength) = (70kg * x)*(12.5mm /1.56cm4 (second moment area as stated in tube specs)
    Do I have to convert the 1.56cm4 (second moment inertia) into mm?
    Also, I'm assuming a couple fo things does * mean multiply and does / mean divide (have to be clear)
  13. Feb 24, 2012 #12
    It always helps to keep units consistent, you should convert cm^4 to mm^4.
    The answer will be a magnitude of 10,000 out if you don't.
    Also the 70 kg mass should be Newtons.
  14. Feb 24, 2012 #13
    A magnitude incorrect of 10,000 is about right for me:
    How does this look
    250N/mm^2=(686N*x)*(12.5/15.6mm^4)
  15. Feb 24, 2012 #14
    1.56 cm^4 is 15600 mm^4
  16. Feb 24, 2012 #15
    Man I really thought I was getting somewhere!!!!!!!!!!
  17. Feb 24, 2012 #16
    You are, it's just a conversion thing, the formula you've written is right.
  18. Feb 24, 2012 #17
    Okay bear with me, the cogs are whirring
    right I've pumped all of these figures into an online calculator and have got the staggering answer of x=1726649842565500
    that seems like a pretty big number to me can you help me make more sense of it?
  19. Feb 24, 2012 #18
    It makes no sense becuase the number is wrong :)
    250 = (12.5*686x)/15600
    250*15600 = 12.5*686x
    3900000/(12.5*686) = x
    3900000/8575 = x
    x= 454mm
  20. Feb 24, 2012 #19
    You make it look so easy. I wonder why the online calculator didn't work? I was looking for an idiot proof way of solving the equation and got an idiotic answer.
    I think my basic maths is missing, I've never had much success with quadratic equations. I won't pester you any more, better I go away and learn some more maths.
    Thanks for all you hard work and perserverance.
  21. Feb 29, 2012 #20
    I'm back
    but this time I'm trying to understand more fully the equation.
    If below is correct what is the term given to 'half the thickness of the tube? is it youngs modulus?
    Yield strength = (moment of turning force) x (half the thickness of the tube ÷second moment of inertia)
