Will Smart Car Protect you in a High-Speed Accident?
In summary, the ability to protect someone in a crash is based on multiple factors, not just the strength of the frame. The longer a vehicle can make the impact last, the less harm it does to passengers. This is related to the equation F=MA, where a high acceleration means a high force. Safety features such as seatbelts and airbags are designed to prolong the application of force and reduce acceleration. The point of collision also plays a role, as a head-on collision is easier to survive than a side impact. Additionally, being in a larger, heavier vehicle is generally safer. Overall, there are too many factors to reliably answer the question, and it is best to look at safety ratings for the vehicle.
jpelletero
Good day,
I'm curious about the Smart Car's commercial. It says it can withstand up to 3 tons of weight.
Now, I want to know if it can protect the passengers in it if a vehicle weighing 1 ton running at 150 kph crash into it?
May I know what's the formula to answer my question?
Thanks in advance.
It's hard to say. The ability to protect someone in a crash is based on a great number of factors, not just the strength of the frame.
The simplest way to put it is that the longer the vehicle can make the impact last, the less harm it does to you. (It will make sense in a moment.) Consider the equation F=MA. This relates force applied to an object, to the mass of an object times it's acceleration. So in an accident, the LESS the acceleration (or deceleration, as it is actually negative acceleration) the less the force is.
Consider a vehicle impacting a solid concrete wall that is very thick and doesn't give at all. The vehicle, and anyone inside it, will go from their initial velocity to zero velocity in a VERY short amount of time, which means that the acceleration is VERY high. As the equation above tells us, a high acceleration means a high force. This is bad.
Now, consider a car impacting a wall made of, say, jello. Jello gives fairly easily, so the car would have a low acceleration, meaning a low force is applied by the wall. It takes longer to stop the car, but it is more gentle, making it much safer.
There are many different safety features designed to prolong the application of the force and reduce the acceleration of the occupants. (As a high acceleration is actually what kills people, IE your skull quickly decelerating as it impacts part of the vehicle and your brain squishing against it) Some of these features are safety belts, airbags, collapsible steering columns, etc. However one of the major factors is point of collision. Impacting head on with something is easier to survive than being hit from the side at the same speed, as there is much more room for the car to buckle and collapse and spread the force out, increasing the time it takes to stop the vehicle and reducing the acceleration. Also, being in a large, heavy vehicle is inherently safer than a small lightweight one, all other factors being equal.
Honestly I think there are too many factors to consider and too many unknowns to be able to reliably answer your question. It appears to me that they have put effort into making the vehicle as safe as possible, but in the end it's still up to you to decide what you want to do. Have you looked for any safety ratings for the vehicle yet? Those would probably be a much better way of answering your question than trying to figure it all out here.
Hi Drakkith,
Thanks for your response. Sorry if my initial question is too broad.
I'm not actually looking to buy one. I'm just curious on how much force can the strength of it's frame withstand if they say that it can withstand a weight of 3 tons.
Thanks again.
jpelletero said:
Hi Drakkith,
Thanks again.
Let's see, 3,000 kg * 9.8 m/s2 is 29,400 Newtons of force.
"A ton of weight" is not necessarily a good measure of protection. Advertisers have to be accurate in what they tell you but it may not be very relevant to survival in an accident. Where can this ton be applied and where can't it?
Check the crash test ratings.
In a high speed accident it's not the strength of the car that matters. The human body can only withstand limited g forces. Too much and your internal organs are damaged when they hit your ribs.
Essentially in a head on the car has to decelerate from speed (U) to stationary (V=0) in the length of the crumple zone (S). Let's say you have a 1m crumple zone and are doing 150kph. Using the standard equation of motion..
V2=U2 + 2as
V2 = 0
so
a = -U2/2s
Now 150kph = 42m/s
so
a = 422/2 = 882m/s2 = 90g
I believe 46g is considered just about survivable ?
That's it. A real smart car should be quicker than humans in predicting dangerous situations. Even so, I am sure that unless it flies it will be impossible to avoid a collision in certain circumstances, due to the limited possibilities for escape. And once a 1 t vehicle crashes into yours at 150 mph, you are dead for sure, no matter how smart your vehicle and you are.
Alkin, when he said 'smart car' he meant THE smart car (www.smart.com). He said 150 kph and not 150 mph. 150kph is about 95mph. People have survived faster head-on car crashes but obviously it depends on the specificis of the situations.
I can't tell you if you will live or not, but I can tell you that the smart does have some nice modern safety features and they are CITY CARS (park anywhere!), and by and large, people do not drive around cities at 150 kph.
The car is just not very comfortable at high speeds on long inter-city roads. The wheelbase (EU definition, distance between front and rear axle) is too short, which makes it very bumpy.
Only 70 MPH but survival would be highly unlikely.
It's pretty clear that the bigger the crumple zone the lower the g force you are subjected to and unfortumately that means big cars with long bonnets/hoods win.
What safety features does a Smart Car have to protect you in a high-speed accident?
Smart Cars typically have a reinforced steel frame, multiple airbags, and advanced braking systems to help protect passengers in the event of a high-speed accident. Some models also have electronic stability control and lane departure warning systems.
Are Smart Cars safe to drive at high speeds?
While Smart Cars may not have the same size and weight as larger vehicles, they are designed to be safe at high speeds. The reinforced steel frame and advanced safety features help to absorb impact and protect passengers in the event of an accident.
Can a Smart Car survive a high-speed collision with a larger vehicle?
In most cases, a Smart Car may not fare well in a high-speed collision with a larger vehicle. However, the advanced safety features and reinforced frame may help to protect passengers to some degree. It is always important to follow traffic laws and drive safely to avoid accidents.
How does a Smart Car's size affect its ability to protect passengers in a high-speed accident?
The small size of a Smart Car may make it more vulnerable in a high-speed accident with a larger vehicle. However, the reinforced frame and advanced safety features are specifically designed to protect passengers in these situations.
What should I do if I am involved in a high-speed accident in a Smart Car?
In the event of a high-speed accident, it is important to remain calm and follow standard safety procedures. This includes checking for injuries, contacting emergency services, and exchanging information with other parties involved. It is also important to seek medical attention and contact your insurance provider as soon as possible.
  • Mechanics
  • Mechanics
