wasteofo2
- 478
- 2
For no apparent reason, my winamp agent started timing songs in reverse fashion. So for a 3:00 song it'll start at 3:00 and count down until the end of a song. Does anyone know how to correct this?
To fix reverse timing in Winamp 5, go to the "Preferences" menu and select "Playback". Under the "Advanced" tab, check the box next to "Enable time stretching". This will fix any issues with reverse timing in Winamp 5.
This issue can occur if the "Enable time stretching" option is not checked in Winamp 5. Without this option, songs may play in reverse or with incorrect timing.
Yes, you can adjust the reverse timing in Winamp 5 by changing the "Time stretch ratio" under the "Advanced" tab in the "Preferences" menu. A lower ratio will result in slower playback, while a higher ratio will result in faster playback.
No, fixing the reverse timing in Winamp 5 will not affect the quality of your music. The "Enable time stretching" option simply adjusts the playback speed without altering the audio quality.
Yes, you can permanently fix reverse timing in Winamp 5 by going to the "Preferences" menu and selecting "Playback". Under the "Advanced" tab, click on the "Time stretching" button and select "Save as default". This will ensure that the "Enable time stretching" option is always checked for future use.
