Winch design question
  1. Jun 11, 2009 #1
    I need to calculate the tension on a cable. cable comes off a winch, travels up at a 45 deg angle over a pulley which is 2m above the height of the winch. The cable goes down at a 45 deg angle and connects to a 7m pipe 2m from a hinge point directly below the pulley. the pipe weighs 7kg/m.
    This unit is going to be used in remote heliportable wireline work in northern alberta. The 7m pipe has a cable system on the end that is used to lift pressure control equipment on to the well.
    I want to put some engeneering support to the design so we can be confident of the cable size and winch capacity prior to building the system.
  3. Jun 11, 2009 #2
    What you describe is not quite clear. Can you post a figure?
  4. Jun 11, 2009 #3
    Word doc with simple drawing
  5. Jun 12, 2009 #4
    berkeman
    Staff: Mentor
    You don't go to a web forum for engineering design advice that can affect worker safety and the safety of others. You hire a licensed and qualified engineer to do the calculations for you.
    Thread locked.
