questions_uk
- 74
Hi. How would you go about doing negative powers on the windows calculator? For example if you wanted to calculate 10 x 10 ^ - 3 x 2 for example what input would you use on the windows calculator? Thanks.
jacksonpeeble said:Are you sure that works on all versions of Windows?
The Windows calculator (calc.exe) hasn't changed its appearance for many releases of Windows (maybe back to Windows 3 or before), and I doubt that its inner workings have changed, either. It would be very surprising to me to find that you got a different result on two different Windows versions.jacksonpeeble said:Are you sure that works on all versions of Windows?
The Windows Calculator is a basic calculator application that allows users to perform simple mathematical calculations such as addition, subtraction, multiplication, and division.
Yes, the Windows Calculator also has advanced functions such as square root, percentage, and trigonometric functions like sine, cosine, and tangent.
The Windows Calculator uses 64-bit precision, making it extremely accurate for most calculations. However, for more complex calculations, it may have some margin of error.
Yes, the Windows Calculator has several customization options such as changing the color theme, changing the number of decimal places displayed, and adding keyboard shortcuts for faster calculations.
Yes, the Windows Calculator is a built-in application and is available on all versions of Windows, including Windows 10, 8, and 7.
