Making Foreign Diacritics on Windows XP
  • Thread starter zoobyshoe
  • Tags
    Windows
In summary, to use the alternate accent codes on a PC for French, you must press ALT + the corresponding number at the same time.
zoobyshoe
6,510
1,290
I haven't run into any instructions for how to make foreign diacritical marks such as the lovely German Umlaut or the French accent aigu. I used to be able to do most of these with WebTV, and the instructions were easy to find. Where does windows xp keep this info?
Did you try going to tools > languge and try to set the langaue?
Where's "tools"?
It's in the menu bar at the top of the screen.
Heheheheheheh.
OK, I found it. It's damned complex and inconvenient.
start->all programs ->accessories -> system tools ->character map
In "character map" there is a huge chart of all kinds of foreign language characters and other symbols. You click on the symbol you want, then click "copy" then you can paste it here in the usual way (ctrl+v).
Very, very tedious. Or têdiöuş.
press the 'any key' I can't find the anykey! E-machines told me to go F' myself! I love that commercial.
Not "anykey", "åņŷЌЄΫ".
αήγκεγ کۂۆۉۘۑ ۩۝۞ ЕИЌЉ ∙♫♪
Я говорю по русқии.
Math Is Hard said:
Zooby, try some of these shortcuts:
http://www.french.uiuc.edu/courses/100/accents.htm
No, these aren't working for me. This is very similar to the way I used to be able to do it with web TV. That site says it's good for Windows 95, 98, and 2000. Must not work with XP.
What are you using to compose messages? I usually do this in Microsoft Word, if it is a foreign language.
Alternate accent codes on PC for French
Press ALT + the corresponding number at the same time.
use that table.
e.g. alt+ 0228 = ä
It's for here, for composition in the box after hitting the quote button, or "Reply To Thread".
use that table.
e.g. alt+ 0228 = ä
I tried this, as well, but strangely PF doesn't like it and has taken me someplace strange each time I try it, like to a page that says:
This forum requires that you wait 30 seconds between searches. Please try again in 29 seconds.
Wow, if you have a PC its so hard to use the computer. I'm scared!
şĕŋξЖǾǾſЊ ҚђЮП¶®!
Press alt and the numbers, it will work. You're not pressing something right.
Nope. I'm pressing alt + 0228 and it takes me to that page again.
Even before I get there, pressing just alt, then the zero, get me the windows "thunk" noise, meaning you're doing something wrong.
you are not actually pressing the '+' key are you? Don't do that. The numbers have to be on the keypad.
How about... uhm. I don't know.
make sure you're using the number pad, and not the numbers above the letters or have num lock on. i believe that's your problem.
To use - hold down ALT key while typing in the numbers 0### on the key pad (with NUM-lock activated as Gale indicated) or type on numbers across the top of the keyboard. Keep this list handy, as it should word in MS Word, rather than ALT-I, S which inserts special characters. Sometimes language support is necessary in browser or application.
0192 À
0193 Á
0194 Â
0195 Ã
0196 Ä
0197 Å
0198 Æ
0199 Ç
0200 È
0201 É
0202 Ê
0203 Ë
0204 Ì
0205 Í
0206 Î
0207 Ï
0208 Ð
0209 Ñ
0210 Ò
0211 Ó
0212 Ô
0213 Õ
0214 Ö
0215 ×
0216 Ø
0217 Ù
0218 Ú
0219 Û
0220 Ü
0221 Ý
0222 Þ
0223 ß
0224 à
0225 á
0226 â
0227 ã
0228 ä
0229 å
0230 æ
0231 ç
0232 è
0233 é
0234 ê
0235 ë
0236 ì
0237 í
0238 î
0239 ï
0240 ð
0241 ñ
0242 ò
0243 ó
0244 ô
0245 õ
0246 ö
0247 ÷
0248 ø
0249 ù
0250 ú
0251 û
0252 ü
0253 ý
0254 þ
0255 ÿ
This is not the problem.
OK, now we're getting somewhere.
The "number lock" has to be "on" and, instead of the regular numbers that are across the top of the letters, you have to use a separate set of numbers that are, apparently, second functions of keys already used in other capacities. You people are calling this second set "the key pad".
This information is in the "help" section of the character map:
Then, with NUM LOCK on, hold down the ALT key while using the number pad keys to type the Unicode character value."
except it fails to explain what "the number pad keys" are.
Thanks for the list, Astro. I'll print it out and try to keep it around.
The key pad set is usually on the right side of the keyboard, and basically mimics on old simple accounting machine set of keys.
Usually Num Lock is a button at the top, with / and * and - and + nearby.
Numbers are arranged
7 8 9
4 5 6
1 2 3
0 .
They might also serve as cursor arrows on some keyboards.
The the right side of then numbers might be arranged -, + and enter.
On mine, Ins and Del are the functions associated with buttons 0 and .
where . is a decimal point for real numbers vs integers.
I also use a powerful text editor "TextPad" which has a character list with the decimal and key equivalents built in.
astronuc explained the traditional keypad, if you have a lap top its pretty different, but you have keypad there too. did you figure everything out?
Ïch denke daß Îch habe es ausgefigured, yes.
Yeah, these second function numbers are activated by pressing a dedicated key designated by the letters fn enclosed in a box printed in blue ink and then pressing a key labeled "num lk" in blue letters under a first function labeled in white called "scroll". Doing this causes a blue LED to light indicating the number lock is on. This allows me to punch in the codes from Astro's list on the keys that are marked in blue with these second function numbers, all the while pressing "alt".
Now, when I press alt + any of these keys when the number lock is not engaged, I get a "thunk" noise and nothing happens. So, there is no real reason this I can see to have to turn the num lk on in the first place. It should always be engaged, since nothing's going to happen unless you press "alt" first. That is the very easy way the WebTv foreign language marks worked, except just about every key on the board had a second function that you found in a list in the help menu.
The "Character Map" has a bi-racial choice of smiley faces: ☻☺. But they both have weird little nubbins on the top of their heads.
  • #31
With WebTV if I wanted to put an ® all I needed to do was press "alt" + r, and it was done.
Here I either have to hunt up the character map, select the ®, copy and paste it, or, hunt up the 4 digit code, engage the num lk, press "alt", then the four digit code, and be sure to remember to disengage the num lk. before trying to type normally, cause if you don't disengage it all the "keypad" letters come out as numbers.
In so many ways this $1000.00 laptop is simply a 10 step way of doing what was a one step process with the $129.00 WebTv, and, on top of it, the laptop has consistantly poorer, more obscure instructions to get you through the extra, unnecessary steps.
I am not going to go into the trouble I've had with my printer and scanner.
1. How do I enable foreign diacritics on Windows XP?
To enable foreign diacritics on Windows XP, go to the "Control Panel" and open "Regional and Language Options." Then, click on the "Languages" tab and check the box next to "Install files for complex script and right-to-left languages (including Thai)." Click "Apply" and then restart your computer for the changes to take effect.
2. How do I type foreign diacritics on Windows XP?
To type foreign diacritics on Windows XP, you can use the "Character Map" utility. Go to "Start" > "All Programs" > "Accessories" > "System Tools" > "Character Map." Select the desired diacritic and click "Copy." Then, paste it into the document or application you are working on.
3. Can I change the keyboard layout to include foreign diacritics on Windows XP?
Yes, you can change the keyboard layout to include foreign diacritics on Windows XP. Go to "Control Panel" > "Regional and Language Options" > "Languages" tab > "Details" button. Then, click on "Add" and select the desired keyboard layout from the list. You can switch between keyboard layouts by clicking on the language bar in the bottom right corner of your screen.
4. How do I change the font to display foreign diacritics on Windows XP?
To change the font to display foreign diacritics on Windows XP, open the document or application you are working on and go to the font settings. Select a font that includes the desired diacritics, such as Arial or Times New Roman. If the font does not include the diacritics you need, you may need to download and install a font that supports them.
5. How do I troubleshoot issues with displaying foreign diacritics on Windows XP?
If you are having issues with displaying foreign diacritics on Windows XP, make sure that you have the necessary language support installed and that you are using a font that supports the diacritics. You may also need to check the language settings in your document or application to ensure that the correct language is selected. If the issue persists, you may need to consult with a technical support specialist or refer to online resources for further assistance.
  • Computing and Technology
  • General Discussion
  • Classical Physics
46K
14K
